AWK command outputs
AWK command outputs
Im using AWK command in sending mail regarding Warning and Critical Alerts in nagios, everything is working fine, however, the output seems to be not in order. is there a command that can manipulate the output or separating it by columns?.
Re: AWK command outputs
I will be closing this thread as you have another for the same issue here: https://support.nagios.com/forum/viewto ... 731#144968
In the future, please only open one thread per issue.
