We have Nagios XI 2014R2.6 and suddenly I can see that most of our system component are not running and I stopped receiving any notifications.
Components not running:
Database Maintenance [Last Run 13d 6h 25m 14s Ago]
Command Subsystem [Last Run 13d 6h 20m 13s Ago]
Event Manager [Last Run 13d 6h 20m 11s Ago]
Feed Processor [Last Run 13d 6h 20m 14s Ago]
Report Engine [Last Run 13d 6h 21m 13s Ago]
Cleaner [Last Run 13d 6h 21m 13s Ago]
Nonstop Operations Manager [Last Run 13d 6h 21m 13s Ago]
System Statistics [Last Updated 13d 6h 25m 27s Ago]
Please advice.
Inas
XI System Component not running
Re: XI System Component not running
It looks like the crond daemon has stopped running.
Try restarting it by running the following.
After a minute, the indicators should turn green and the system will start processing again.
If not, please post a screen shot of the errors so we can review them.
service crond restartIf not, please post a screen shot of the errors so we can review them.
In addition to what Tom is asking, please run these commands and post the output:
If a filesystem is not full, please try these commands:
Then if you are still having issues, please attach the last 100 or so sanitized lines from your /usr/local/nagios/var/nagios.log.
df -h
service nagios status
service ndo2db status
service npcd status
service postgresql status
service mysqld statusCode: Select all
service nagios stop
service ndo2db stop
service npcd stop
service postgresql stop
service mysqld restart
service postgresql start
service npcd start
service ndo2db start
service nagios start-
inas.labib
Thank you very much for your replies.
Actually I don't have any errors and I rebooted the whole system and I followed your recommendations but still no success.
Regarding the log that you want me to attach it has a private data. Is this issue is visible to all Nagios XI customers?
inas.labib
The required output:
# df -h
/dev/mapper/vg_ngs01-LogVolRoot
92G 7.5G 80G 9% /
tmpfs 2.9G 0 2.9G 0% /dev/shm
/dev/sda1 488M 89M 375M 20% /boot
# service nagios status
nagios (pid 2100) is running...
# service ndo2db status
ndo2db (pid 2123) is running...
# service npcd status
NPCD running (pid 1980).
# service postgresql status
postmaster (pid 1832) is running...
# service mysqld status
mysqld (pid 1775) is running...
then I followed the rest of commands but again not working
# df -h
92G 7.5G 80G 9% /
inas.labib
It is working now.
Thank you very much the issue was that the nagios user password has been expired
That is good to hear, shall I close the post?
