I'm a litle bit stuck on another quite complex Logstash filter I'm working on. The Logstash filter is for our Infoblox device. Untill recently I used an input like this:
syslog {
type => 'syslog-infoblox'
port => 5545
}Code: Select all
tcp {
port => 5545
}At the moment I have this:
if [type] == "syslog-infoblox" {
grok {
break_on_match => false
match => [ "message", "\A%{SYSLOG5424PRI}%{SYSLOGTIMESTAMP} %{HOSTNAME} %{SYSLOGPROG}\: %{GREEDYDATA:info}" ]
add_tag => "grokked_syslog_infoblox"
if [program] == "dhcpd" {
grok {
patterns_dir => "/usr/local/nagioslogserver/logstash/patterns"
match => [ "info", "%{DHCPREQUEST:dhcprequest} %{GREEDYDATA:info}" ]
match => [ "info", "%{DHCPMAP:dhcpmap}(: | )%{GREEDYDATA:info}" ]
match => [ "info", "%{DHCPOTHER:dhcpother}(: | )%{GREEDYDATA:info}" ]
remove_tag => "grokked_syslog_infoblox"
add_tag => "grokked_syslog_infoblox_dhcpd"
overwrite => [ "info" ]
grok {
match => [ "info", "on %{GREEDYDATA:dhcpon} to %{GREEDYDATA:dhcptoipv6} \(%{GREEDYDATA:dhcptohostname}\) via %{GREEDYDATA:dhcpvia} relay %{GREEDYDATA:dhcprelay} lease-duration %{GREEDYDATA:dhcpleaseduration} offered-duration %{GREEDYDATA:dhcpofferedduration} uid %{GREEDYDATA:dhcpuid}" ]
match => [ "info", "on %{GREEDYDATA:dhcpon} to %{GREEDYDATA:dhcptoipv6} \(%{GREEDYDATA:dhcptohostname}\) via %{GREEDYDATA:dhcpvia} relay %{GREEDYDATA:dhcprelay} lease-duration %{GREEDYDATA:dhcpleaseduration} uid %{GREEDYDATA:dhcpuid}" ]
match => [ "info", "on %{GREEDYDATA:dhcpon} to%{GREEDYDATA:dhcptoipv6} \(%{GREEDYDATA:dhcptohostname}\) via %{GREEDYDATA:dhcpvia} relay %{GREEDYDATA:dhcprelay} lease-duration %{GREEDYDATA:dhcpleaseduration}" ]
match => [ "info", "for %{GREEDYDATA:dhcpfor} from %{GREEDYDATA:dhcpfrom} via %{GREEDYDATA:dhcpvia} uid %{GREEDYDATA:dhcpuid}" ]
match => [ "info", "from %{GREEDYDATA:dhcpfrom} via %{GREEDYDATA:dhcpvia} uid %{GREEDYDATA:dhcpuid}" ]
match => [ "info", "from %{GREEDYDATA:dhcpfrom} via %{GREEDYDATA:dhcpvia}" ]
match => [ "info", "to %{IP:dhcptoip} \(%{GREEDYDATA:dhcptoipv6}\) via %{GREEDYDATA:dhcpvia}" ]
match => [ "info", "%{GREEDYDATA:info}" ]
remove_tag => "grokked_syslog_infoblox_dhcpd"
add_tag => "grokked_syslog_infoblox_dhcpd_rest"
emergency alert critical error warning notice info debug
kernel 0 1 2 3 4 5 6 7
user 8 9 10 11 12 13 14 15
mail 16 17 18 19 20 21 22 23
system 24 25 26 27 28 29 30 31
security 32 33 34 35 36 37 38 39
syslog 40 41 42 43 44 45 46 47
lpd 48 49 50 51 52 53 54 55
nntp 56 57 58 59 60 61 62 63
uucp 64 65 66 67 68 69 70 71
time 72 73 74 75 76 77 78 79
security 80 81 82 83 84 85 86 87
ftpd 88 89 90 91 92 93 94 95
ntpd 96 97 98 99 100 101 102 103
logaudit 104 105 106 107 108 109 110 111
logalert 112 113 114 115 116 117 118 119
clock 120 121 122 123 124 125 126 127
local0 128 129 130 131 132 133 134 135
local1 136 137 138 139 140 141 142 143
local2 144 145 146 147 148 149 150 151
local3 152 153 154 155 156 157 158 159
local4 160 161 162 163 164 165 166 167
local5 168 169 170 171 172 173 174 175
local6 176 177 178 179 180 181 182 183
local7 184 185 186 187 188 189 190 191Code: Select all
<134>Jul 15 08:53:58 10.23.17.250 dhcpd[10639]: DHCPACK to 10.23.136.206 (f8:b1:56:de:be:4d) via eth2Code: Select all
<131>Jul 15 08:53:58 10.15.17.251 dhcpd[31808]: Unable to add forward map from PRGEN11420.gep.gt.be to 10.15.129.164: REFUSEDSo how can I edit my above filters so Logstash retrieves the correct severity_label from the SYSLOG5424PRI field?
EDIT: I'm using these custom Logstash patterns:
DHCPREQUEST (DHCPACK|DHCPREQUEST|DHCPINFORM|DHCPOFFER|DHCPDISCOVER|DHCPDECLINE|DHCPRELEASE|DHCPNAK|DHCPEXPIRE|RELEASE)
DHCPMAP (Added new forward map|Removed forward map|Unable to add forward map|Added reverse map|Removed reverse map|Addition of reverse map|Addition of forward map|Attempt to add forward map|Unable to add reverse map)
DHCPOTHER (DDNS|Dynamic DNS|icmp_echorequest)Willem
