Unable to see login page
Dear support,
I have not been using the Nagios machine for sometime and when I go into the URL, it shows me this page without seeing the login page.
I have tried to run the repair, however there was segmentation fault and mysqld couldn't start after.
Re: Unable to see login page
Let's take a look at your mysql logs:
Does mysql.sock exist?
SELinux is off?
Check on your disk space:
Let us know the results of the above. Thanks!
tail -n 30 /var/log/mysqld.logCode: Select all
ls /var/lib/mysql/mysql.sockCode: Select all
sestatusCode: Select all
df -hRe: Unable to see login page
Hi Jolson,jolson wrote:Let's take a look at your mysql logs:Does mysql.sock exist?Code: Select all
tail -n 30 /var/log/mysqld.logSELinux is off?Code: Select all
ls /var/lib/mysql/mysql.sockCheck on your disk space:Code: Select all
sestatusLet us know the results of the above. Thanks!Code: Select all
df -h
Thanks for pointing out, I've run out of disk space. Is there a documentation on how I can archive or delete the old records?
Furthermore, I get these errors from the /var/log/messages:
[root@NagiosCentOS6 ~]# tail /var/log/messages
Jul 20 16:12:58 NagiosCentOS6 abrt[2392]: Aborting dump: only 141MiB is available on /var/spool/abrt
Jul 20 16:12:58 NagiosCentOS6 abrt[2395]: Aborting dump: only 141MiB is available on /var/spool/abrt
Jul 20 16:15:29 NagiosCentOS6 snmptt-sys[1864]: MySQL error: Unable to connect to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Jul 20 16:20:29 NagiosCentOS6 snmptt-sys[1864]: MySQL error: Unable to connect to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111)
Well, the tables should be truncated after the number of days specified in the Admin --> performance settings --> databases page. There really is no need to archive these rows as the data is always available in the nagios logs, and the old data is really only used for SLA/Availability reporting (which is parsed directly from the logs).
You need to hunt down where the disk usage is coming from - often we find the main culprits are system logs, XI backups, or unreapable spooler folders.
What is the output of:
du -a / | sort -n -r | head -n 20
find / -type d -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
find / -type f -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}Former Nagios employee
Hi Abrist, there are quite a number of backup files. I have removed them from and stopped cron for now. However, I am not able to start nagios service.abrist wrote:Well, the tables should be truncated after the number of days specified in the Admin --> performance settings --> databases page. There really is no need to archive these rows as the data is always available in the nagios logs, and the old data is really only used for SLA/Availability reporting (which is parsed directly from the logs).
What is the output of:Code: Select all
du -a / | sort -n -r | head -n 20 find / -type d -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {} find / -type f -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
[root@NagiosCentOS6 ~]# service nagios status
No lock file found in /usr/local/nagios/var/nagios.lock
[root@NagiosCentOS6 ~]# /etc/rc.d/init.d/nagios restart
Running configuration check...
[root@NagiosCentOS6 ~]# /etc/rc.d/init.d/nagios reload
[root@NagiosCentOS6 ~]# ps axu | grep nagios
root 19317 0.0 0.0 103252 836 pts/1 S+ 10:47 0:00 grep nagios
nagios 31023 0.0 0.0 8340 860 ? S 10:41 0:00 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
nagios 31305 0.0 0.0 50296 656 ? Ss 10:41 0:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
[root@NagiosCentOS6 ~]# du -a / | sort -n -r | head -n 20
du: cannot access `/proc/6788/task/6788/fd/4': No such file or directory
du: cannot access `/proc/6788/task/6788/fdinfo/4': No such file or directory
du: cannot access `/proc/6788/fd/4': No such file or directory
du: cannot access `/proc/6788/fdinfo/4': No such file or directory
16750433 /
11259960 /store
11259956 /store/backups
11222932 /store/backups/nagiosxi
4259896 /usr
1619884 /usr/share
1290336 /usr/lib64
937080 /var
515732 /usr/lib
423912 /var/cache
422100 /usr/share/locale
419964 /var/cache/yum
419960 /var/cache/yum/x86_64
419956 /var/cache/yum/x86_64/6
418564 /usr/local
413684 /usr/lib64/libreoffice
285940 /usr/bin
270048 /var/lib
230828 /var/cache/yum/x86_64/6/updates
229988 /usr/lib64/libreoffice/programCode: Select all
[root@NagiosCentOS6 ~]# find / -type d -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
find: `/proc/3284/task/3284/fd/5': No such file or directory
find: `/proc/3284/task/3284/fdinfo/5': No such file or directory
find: `/proc/3284/fd/5': No such file or directory
find: `/proc/3284/fdinfo/5': No such file or directory
du: cannot access `/proc/3304/task/3304/fd/4': No such file or directory
du: cannot access `/proc/3304/task/3304/fdinfo/4': No such file or directory
du: cannot access `/proc/3304/fd/4': No such file or directory
du: cannot access `/proc/3304/fdinfo/4': No such file or directory
du: cannot access `/proc/3308': No such file or directory
du: cannot access `/proc/3430/task/3430/fd/4': No such file or directory
du: cannot access `/proc/3430/task/3430/fdinfo/4': No such file or directory
du: cannot access `/proc/3430/fd/4': No such file or directory
du: cannot access `/proc/3430/fdinfo/4': No such file or directory
du: cannot access `/proc/3477': No such file or directory
du: cannot access `/proc/3304': No such file or directory
du: cannot access `/proc/3304/task': No such file or directory
du: cannot access `/proc/3304/task/3304': No such file or directory
du: cannot access `/proc/3304/task/3304/fd': No such file or directory
du: cannot access `/proc/3304/task/3304/fdinfo': No such file or directory
du: cannot access `/proc/3304/task/3304/ns': No such file or directory
du: cannot access `/proc/3304/task/3304/attr': No such file or directory
du: cannot access `/proc/3304/fd': No such file or directory
du: cannot access `/proc/3304/fdinfo': No such file or directory
du: cannot access `/proc/3304/ns': No such file or directory
du: cannot access `/proc/3304/net': No such file or directory
du: cannot access `/proc/3304/net/vlan': No such file or directory
du: cannot access `/proc/3304/net/dev_snmp6': No such file or directory
du: cannot access `/proc/3304/net/netfilter': No such file or directory
du: cannot access `/proc/3304/net/stat': No such file or directory
du: cannot access `/proc/3304/attr': No such file or directory
11G /store/backups/nagiosxi
11G /store/backups
11G /store/backups
11G /store/backups
11G /store
11G /store
du: cannot access `/proc/3968/task/3968/fd/4': No such file or directory
du: cannot access `/proc/3968/task/3968/fdinfo/4': No such file or directory
du: cannot access `/proc/3968/fd/4': No such file or directory
du: cannot access `/proc/3968/fdinfo/4': No such file or directory
du: cannot access `/proc/3971': No such file or directory
16G /
[root@NagiosCentOS6 ~]# find / -type f -print0 | xargs -0 du | sort -n | tail -10 | cut -f2 | xargs -I{} du -sh {}
find: `/proc/8425/task/8425/fd/5': No such file or directory
find: `/proc/8425/task/8425/fdinfo/5': No such file or directory
find: `/proc/8425/fd/5': No such file or directory
find: `/proc/8425/fdinfo/5': No such file or directory
find: `/proc/8465': No such file or directory
find: `/proc/8474': No such file or directory
du: cannot access `/proc/510/task/510/fdinfo/12': No such file or directory
du: cannot access `/proc/510/fdinfo/12': No such file or directory
du: cannot access `/proc/7102/task/7102/fdinfo/128': No such file or directory
du: cannot access `/proc/7102/fdinfo/128': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435461903.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435548302.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435634703.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435721103.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435807503.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435893902.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1435980303.tar.gz': No such file or directory
du: cannot access `/store/backups/nagiosxi/1436066702/mysql/nagios.sql': No such file or directory
du: cannot access `/usr/lib/locale/locale-archive': No such file or directory
du: cannot access `/var/cache/yum/x86_64/6/updates/05a18878446f93dd7c0a47880eda694778ed2bb7a412e2d5ada59be33ed841f6-other.sqlite': No such file or directory
Access your Nagios XI Web GUI and navigate to 'Configure -> Tools -> Write Config Files'. Once there, click the buttons in the following order:
1. Delete
2. Write
3. Verify
4. Restart
After doing so, run a service nagios status on the CLI and ensure that nagios is running. If not, you may have to start it with service nagios start.
Best,
Jesse
1. Delete
2. Write
3. Verify
4. Restart
Best,
Jesse
Hi Jesse,jolson wrote:Access your Nagios XI Web GUI and navigate to 'Configure -> Tools -> Write Config Files'. Once there, click the buttons in the following order:
1. Delete
2. Write
3. Verify
4. Restart
Best,
Jesse
I didn't see the 'Configure -> Tools -> Write Config Files' can I find it in the free version?
Anyways, I have deleted the backups from trash to free up some space and now nagios is back to normal.
My mistake - the actual path is 'Configure -> Core Config Manager -> Tools -> Write Config Files'. I'm glad to hear you have this working though - may I close this thread and mark it as resolved?I didn't see the 'Configure -> Tools -> Write Config Files' can I find it in the free version?
Yes, thank you.jolson wrote:My mistake - the actual path is 'Configure -> Core Config Manager -> Tools -> Write Config Files'. I'm glad to hear you have this working though - may I close this thread and mark it as resolved?I didn't see the 'Configure -> Tools -> Write Config Files' can I find it in the free version?
