When I try to use the PDF button I get a logon page PDF
tecnalb
Post by tecnalb »
Hello, when I use the button to create PDF I get a PDF of the NNA logon page. I'm logged in and using the system, but just get this crazy PDF.
I am running Nagios Network Analyzer • 2R1.0 •
Re: When I try to use the PDF button I get a logon page PDF
Did you enable SSL on the Network Analyzer system?
I found a previous post that may help you out with this issue. Take a look at it and see if this helps.
https://support.nagios.com/forum/viewto ... 3&start=40
tecnalb
Post by tecnalb »
I have not enabled SSL at this point
Are you using a proxy? Have you tried to change the API key to see if this is going to fix the issue? Do you have any "old" PDFs left over in "/tmp"? Do you see any errors in the apache error log? Run:
tail -f /var/log/httpd/error_log
then try to download a pdf. When you see the logon page, stop the tail (Ctrl + c), copy/paste the output.
tecnalb
Post by tecnalb »
Not a lot of good info here:
[root@nna ~]# tail -f /var/log/httpd//error_log
Resolving links (4/6)
Loading headers and footers (5/6)
Printing pages (6/6)
Done
Loading pages (1/6)
Counting pages (2/6)
Done
Loading pages (1/6)
Done
Login to the Network Analyzer, click on your username in the top right corner, Click on the Generate New Key button under the API section and see if that resolves it for you.
tecnalb
Post by tecnalb »
No such button exists... see attached... I am logged in as nagiosadmin
In NA, click on Administration, User Management, edit the nagiosadmin account, enable API access, save it and see if that works for you.
tecnalb
Post by tecnalb »
That was it. I just upgraded from the initial NNA version last week. Had not been using it. I suppose that feature was not there before!
Great!! Thanks for the help!!
