Hi guys
Questions for anyone who has already used this really.
So the check plugin i'm talking about is found here - https://exchange.nagios.org/directory/P ... ne/details
Got a few questions
-To import it to Nagios XI is it as simple as saving the script page that opens when you click on the link and then importing that?
-When creating the command to use this, how should you structure the command with the arguments etc?
Any help would be brilliant.
Courhar
Using the check_keystone
Re: Using the check_keystone
First, you will need to test the plugin from the command line and make sure it works. Then, you will need to create a command and a check (service). These steps are described in details in the document below:
https://assets.nagios.com/downloads/nag ... lugins.pdf
Let us know if you have any more questions or if you get stuck on something.
