Looking for more detailed explanation of Availability Report
ajanm
Post by ajanm »
Hi!
On the "Availability Report" I've selected a specific host and a Report Period of "Last 24 hours".
When Nagios returns results, at the bottom in the section "Host Log Entries", Nagios shows the logs for the last 3 days. If I select a report period of last 7 days, nagios lists the last 9 or so in the "Host Log Entires."
Is there a reason for this? Are the availability report numbers up at the top accurate or potentially inaccurate?
Thanks!
-AJ
Re: Looking for more detailed explanation of Availability Re
The "Host Log Entries" will just show you the host's state from the last 24 hours if you had Backtracked archives = 0. Try changing the "Backtracked archives" value and click on "Update" to see if the "Host Log Entries" will change.
