File Input on local log server
CFT6Server
Post by CFT6Server »
We have some logs that are stored on an NFS mount. I have mounted the NFS volume on 1 node of our 3 node cluster. I am trying to use the "file" input to pick up the logs as if they are local logs. Nothing seems to be showing.
I am an instance specific configuration on the node:
input {
  file {
    path => "/nfs/shared/servers/logs/*"
    type => "apache"
If I got to that node and look at the inputs, it does not show anything in the #Local Inputs section, even though I see it in GUI.
This should just pick up the logs and dump it into elasticsearch? or would we need additional configurations. Right now only this node has the volume mounted. If I mount the volume on same path on all 3 nodes, would I be able to make this into a global configuration? Logically thinking I am guessing no, since the nodes can't tell each other what has been picked up?
jolson
Attack Rabbit
Re: File Input on local log server
Post by jolson »
What you have posted should work with no additional filters required. Let's do a couple of tests.
Check the file permissions:
ls -l /nfs/shared/servers/log/*
The 'nagios' user will need read access to the above files.
Check logstash configuration:
cat /usr/local/nagioslogserver/logstash/etc/conf.d/*
Verify that the logstash configuration applied properly to the server in question.
Corrrect - there shouldn't be problems with the input you've posted.
Twits Blog
CFT6Server
We have access to these files, here's partial output.
-rw-r--r-- 1 30002 300     10121 Jun  2 23:55 errors.201506022355
-rw-r--r-- 1 30002 300   1029031 Jun  3 23:55 errors.201506032355
-rw-r--r-- 1 30002 300      7405 Jun  4 23:55 errors.201506042355
-rw-r--r-- 1 30002 300      5067 Jun  5 23:55 errors.201506052355
-rw-r--r-- 1 30002 300      5032 Jun  6 23:55 errors.201506062355
-rw-r--r-- 1 30002 300      6485 Jun  7 23:55 errors.201506072355
-rw-r--r-- 1 30002 300      6955 Jun  8 23:55 errors.201506082355
-rw-r--r-- 1 30002 300      5486 Jun  9 23:55 errors.201506092355
-rw-r--r-- 1 30002 300      4634 Jun 10 23:55 errors.201506102355
-rw-r--r-- 1 30002 300     18925 Jun 11 23:55 errors.201506112355
Reviewing the configurations on the node, it doesn't seem like it does not show the instance configuration. I created the input under "per instance" and saved/applied configurations, but no luck.
I also noticed that this node is no longer grabbing changes in the global configurations. Is this because I have instance configurations in place? I've made changes in the global config that are not showing in this node configuration.
jolson
Attack Rabbit
Post by jolson »
Interesting, I recommend running a 'Verify' under your 'per instance' configuration menu. Does it come back clean?
2015-07-22 16_16_37-Instance Configuration • Nagios Log Server - Firefox Developer Edition.png
Twits Blog
CFT6Server
It does, but the local inputs do not show up on the instance configuration.
To get the servers sync'd. I rebooted, removed instance configuration and re-applied global configurations. I then went back and put in the single instance input configuration, and it and didn't apply any local inputs.
local inputs is blank when viewing input file.
jolson
Attack Rabbit
Post by jolson »
It's odd to me that your verify worked properly. Give the following a shot:
      file {
        type => "apache"
Nagios Log Server will input the starting and ending brackets for your configs automatically.
Twits Blog
CFT6Server
I have done that and again verified fine, but again it does not show up when I click on view. Nothing under "#Local Inputs".
jolson
Attack Rabbit
Post by jolson »
Interesting - what version of Nagios Log Server are you running? I recall a similar bug in R1.3, but it's been fixed for some time now. If you're on a later version, I'd be happy to set up a remote session with you to get this working. Let me know!
Twits Blog
CFT6Server
We are on 2015R1.4 at the moment.
jolson
Attack Rabbit
Post by jolson »
Would you be willing to attempt upgrading to R2.1?
Twits Blog
