Configuring XI to send a SNMP trap on port 15162
thernand
Post by thernand »
Can we setup XI to send SNMP notification Host and service checks on port 15162? How do we configure this?
ssax
Dreams In Code
Re: Configuring XI to send a SNMP trap on port 15162
Post by ssax »
You can use the Nagios-XI-SNMP-Trap-Sender-Component to specify the port:
https://exchange.nagios.org/directory/A ... nt/details
thernand
Post by thernand »
We use version 1.4 of the SNMP trap Sender component and I do not see where you can configure the port. Is there a way to do it with this version?
ssax
Dreams In Code
Post by ssax »
There is not, are you not able to upgrade the component to 1.5?
thernand
Post by thernand »
Not at this time because of the way the company does the XI install.
ssax
Dreams In Code
Post by ssax »
We might be able to hack it together, I'll take a look on Monday, if you don't hear from me by midday on Monday, send me a reply on here.
ssax
Dreams In Code
Post by ssax »
Edit this file:
/usr/local/nagiosxi/html/includes/components/snmptrapsender/snmptrapsender.inc.php
Around line 420 you'll see this line:
$trap_command = "/usr/bin/snmptrap -v 2c -c $community $address '' NAGIOS-NOTIFY-MIB::nSvcEvent nSvcHostname s \"%host%\" nSvcDesc s \"%service%\" nSvcStateID i %servicestateid% nSvcOutput s \"%serviceoutput%\"";
Change:
$address
To:
${address}:15162
Then it should work for you.
