RADIUS service monitoring wizard
ManojNamdev
Post by ManojNamdev »
Dear Team,
How we can monitor RADIUS server, when we are using Monitoring Wizard its asking for following things:
Server Options
Secret: ???????????
The shared secret to use when logging into the RADIUS server.
Username: ??????????
The username used to login to the RADIUS server.
Password: ??????????
The password used to login to the RADIUS server.
Port: ?????????
The port number the RADIUS server runs on.
After giving this input which mentioned above
[pap] login attempt with password "¿³?òd?~?¢??>titý"
[pap] Using clear text password "nagios"
[pap] Passwords don't match
Please how we can monitor RADIUS Server ........?
Also I want to give some more input on this query:
From RADIUS server side we have checked following things please look into it also
[root@radius2 tmp]# ./check_radius_adv -r localhost -u nagios -p nagios -s testing123 -c 1812 -v
Using the following information
username: nagios
password: nagios
shared secret: testing123
server: localhost
path of attributes file :
CRITICAL: Access REJECT. (code = 3) | rtt=1.0035 rttms=1003.5219
But when we are running radtest command, passwords are matching without any error.
ssax
Dreams In Code
Re: RADIUS service monitoring wizard
Post by ssax »
This error (if you're running it from your radius server) CRITICAL: Access REJECT. (code = 3) leads me to believe the nagios user you are trying to authenticate to your radius server with is not allowed for radius authentication.
andarnold
Post by andarnold »
I think that this thread https://support.nagios.com/forum/viewto ... us#p157549 provides a good workaround for checking RADIUS servers.
HTH,
Derek
andarnold wrote:I think that this thread https://support.nagios.com/forum/viewto ... us#p157549 provides a good workaround for checking RADIUS servers.
HTH,
Derek
Thanks @andarnold! Yes, this looks to be the same issue. I had done a lot of testing and concluded it was how the password is sent. Try the work around in that thread mentioned by Scott.
