Hiding Host on the Network Map
I've added printers to my network, I want to monitor ink levels but I don't want to see them on my network head. Is there anyway to exlude them from the map by default?
- Skynet Drone
Re: Hiding Host on the Network Map
I'm not aware of a way. It may be possible to use custom coordinates and put them out in zombieland somewhere way off your screen. Alternatively you could create a contact that can't see them permission wise, but if I'm not mistaken they still have a place on the map, they just don't show up.
Do either of these options fit the bill? If not, the next best option is probably NagVis.
So there are no options to hide nonessesary hosts from statusmap?
