NLS API
jb60606
NLS API
Post by jb60606 »
Could you tell me what language(s) NLS is written in? Also wondering if you might be able to point me in the direction of any NLS API documentation out there?
jolson
Attack Rabbit
Re: NLS API
Post by jolson »
NLS is written in many languages - likely most of them if you count each utility being used in the backend. I know for a fact that there is python/ruby/php/perl/bash/C/java involved.
It's hard to say which language is primary. If I had to guess, I would say Java, since Elasticsearch utilizes Java heavily.
What kind of API queries are you looking for? There's an extensive query API, and you can press the small 'i' icon next to any query in your dashboard to pull up an appropriate API call.
Twits Blog
jb60606
Re: NLS API
Post by jb60606 »
Thanks.
jolson
Attack Rabbit
Re: NLS API
Post by jolson »
No problem! Anything else you'd like to see included in the API?
Twits Blog
