Issue in Servicegroup
wiproltdwiv
Post by wiproltdwiv »
Hi ,
We'r facing issue while generating availability report under Legacy report. Once we go to step :1 select Report type we select type : "servicegroup" then click continue to step 2 then it dosen't show any "servicegroup" under drop downlist.
This was working fine before. Today I got this error for this i checked all log from backend. I didn't find any kind of error regarding this.
Please find the screen shot for your reference and also suggest possible reason with solution asap.
Thanks in advacce....
Re: Issue in Servicegroup
Can you view the availability report if you log in Nagios Core?
http://ipaddress/nagios
Can you try to access the servicegroups drop-down menu and show the tail of the apache error log in code wraps?
tail -100 /var/log/httpd/error_log
