Perfdata Problem
edoRaul
Perfdata Problem
Post by edoRaul »
In nagios xi,
xml and rrd files have date of 24 July. Today is 27.
I remove files, but it generate data starting from 24 July date.
Thanks-
Re: Perfdata Problem
Try restarting the npcd daemon by running the following.
service npcd restart
If that doesn't fix it, run the following and post the output.
tail -100 /usr/local/nagios/var/npcd.log
Can we move this post from the Core forum to the XI forum?
edoRaul
Post by edoRaul »
Ok, move it.
Who generate the xml files in perfdatafolder?. Thanks
jdalrymple
Skynet Drone
Post by jdalrymple »
Did restarting npcd resolve your issue?
The perfdata XML files are automatically generated by NagiosXI when you create your hosts/services.
