Issue: BPI Config not updated on deletion of host or service
CatalystX
Post by CatalystX »
Steps to reproduce:
  • Create a BPI group, 'Test'
  • Add several services and hosts
  • Delete some services and/or hosts, e.g. during Service or Server retirement process
  • Results in
    Error: Can't find a service with host:Testserver service:SSL Test, check configuration for group: 'Test'
Re: Issue: BPI Config not updated on deletion of host or ser
Getting an error in BPI after removing hosts/services, members of a BPI group under XI that is normal as there is no "dynamic" integration at this time. You are welcome to submit a feature request for adding this functionality on our public tracker here:
http://tracker.nagios.com/
or I can post an internal feature request for you (if you want me to). Thanks!
ssax
Dreams In Code
Post by ssax »
BPI is a manual process so you would need to edit the BPI config and remove them, I've created a feature request though because it would be nice if it automatically handled that:
NEW TASK ID 6127 created - Nagios XI Feature Request: BPI - When deleting a host it should automatically remove the host from the BPI config
CatalystX
Post by CatalystX »
Thanks, guys.
ssax
Dreams In Code
Post by ssax »
No problem, marking as resolved and locking topic.
