Hello Experts,
I need to run
./installdb command to install the ndoutils database but I cannot specify port no. in it. Can you please help how can i get this command work if my port is other than the default port.
For example my port no for mysql is 5628 so ./installdb gives error that it cant connect to mysql as it is looking on port 3306.
Please help how can this work.
ndoutils database install on different mysql port
yunushaikh
Re: ndoutils database install on different mysql port
Please post the ./installdb file that you are attempting to run, and we'll take a look at it and modify it as necessary.
Are you running Nagios Core or Nagios XI?
jdalrymple
- Skynet Drone
I've created a modified installdb for you. I'll see if the maintainers want to pull it in.
Had to be tarred so PHPBB would allow it.
- installdb.tar
- (10 KiB) Downloaded 136 times
yunushaikh
Thanks a lot sir for your help.
You can lock this case.
