Permissions on libexec directory
arnab.roy
Post by arnab.roy »
Hi All,
I would like to let you know since the upgarde between r1.2 > r1.6 their seems to be wrong permissions set on the plugin folder as a result you can no longer upload or delete a plugin from the web interface. The issue is the owner of libexec is set to nagios nagios where as the correct permissions should be apache nagios. Changed that and all became normal.
Cheers
Arnab
nscott
Re: Permissions on libexec directory
Post by nscott »
Hey thanks for letting us know! This will definately be corrected.
Nicholas Scott
