Nagios.service fails to start
I have just installed the latest nagios mointoring server on debian 8.1 (jessie). When trying to restart the nagios service, it fails, see the error below:
[....] Starting nagios (via systemctl): nagios.serviceJob for nagios.service failed. See 'systemctl status nagios.service' and 'journalctl -xn' for details.
failed!
and there is detailed info from executing the command below:
monitor:/usr/local/nagios/etc# journalctl -xn
-- Logs begin at Thu 2015-07-30 10:48:19 SAST, end at Thu 2015-07-30 15:13:30 SAST. --
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: ***> One or more problems was encountered while processing the config files...
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: Check your configuration file(s) to ensure that they contain valid
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: directives and data defintions. If you are upgrading from a previous
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: version of Nagios, you should be aware that some variables/definitions
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: may have been removed or modified in this version. Make sure to read
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: the HTML documentation regarding the config files, as well as the
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: 'Whats New' section to find out what has changed.
Jul 30 15:13:30 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=8
Jul 30 15:13:30 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
-- Subject: Unit nagios.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/li ... temd-devel
-- Unit nagios.service has failed.
-- The result is failed.
Jul 30 15:13:30 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Any help to get through will be appreciated.
Thank you.
failed!
Thank you.
Re: Nagios.service fails to start
Let's run a configuration check against your Nagios Server. Please run the following command:
Show us the output of the above command please. Thanks!
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgRe: Nagios.service fails to start
Hi Jolson,
Below is the output:
monitor:~# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 233 services.
Checked 24 hosts.
Checked 3 host groups.
Checked 0 service groups.
Checked 6 contacts.
Checked 3 contact groups.
Checked 32 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 24 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Nagios Core 4.0.8
License: GPL
Checking objects...
Checked 24 hosts.
Checked 6 contacts.
Checked 24 hosts
Total Warnings: 0
Total Errors: 0
jdalrymple
- Skynet Drone
Please post the output of:
journalctl -a --no-pager | grep -i nagiosRe: Nagios.service fails to start
Below is the output of journalctl -a --no-pager | grep -i nagios
Aug 04 06:34:52 monitor.sanren.ac.za sshd[11076]: Accepted password for nagios from 159.8.74.137 port 63484 ssh2
Aug 04 06:34:52 monitor.sanren.ac.za sshd[11076]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:34:52 monitor.sanren.ac.za systemd-logind[422]: New session 6039 of user nagios.
Aug 04 06:34:52 monitor.sanren.ac.za systemd[1]: Starting Session 6039 of user nagios.
Aug 04 06:34:52 monitor.sanren.ac.za systemd[1]: Started Session 6039 of user nagios.
Aug 04 06:35:14 monitor.sanren.ac.za sshd[11087]: Accepted password for nagios from 159.8.99.200 port 64211 ssh2
Aug 04 06:35:14 monitor.sanren.ac.za sshd[11087]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:35:14 monitor.sanren.ac.za systemd-logind[422]: New session 6040 of user nagios.
Aug 04 06:35:14 monitor.sanren.ac.za systemd[1]: Starting Session 6040 of user nagios.
Aug 04 06:35:14 monitor.sanren.ac.za systemd[1]: Started Session 6040 of user nagios.
Aug 04 06:35:21 monitor.sanren.ac.za sshd[11090]: Accepted password for nagios from 184.173.26.170 port 62244 ssh2
Aug 04 06:35:21 monitor.sanren.ac.za sshd[11090]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:35:21 monitor.sanren.ac.za systemd-logind[422]: New session 6041 of user nagios.
Aug 04 06:35:21 monitor.sanren.ac.za systemd[1]: Starting Session 6041 of user nagios.
Aug 04 06:35:21 monitor.sanren.ac.za systemd[1]: Started Session 6041 of user nagios.
Aug 04 06:35:26 monitor.sanren.ac.za sshd[11054]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:36:02 monitor.sanren.ac.za sshd[11097]: Accepted password for nagios from 184.173.26.170 port 62698 ssh2
Aug 04 06:36:02 monitor.sanren.ac.za sshd[11097]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:36:02 monitor.sanren.ac.za systemd-logind[422]: New session 6042 of user nagios.
Aug 04 06:36:02 monitor.sanren.ac.za systemd[1]: Starting Session 6042 of user nagios.
Aug 04 06:36:02 monitor.sanren.ac.za systemd[1]: Started Session 6042 of user nagios.
Aug 04 06:36:41 monitor.sanren.ac.za sshd[11076]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:36:42 monitor.sanren.ac.za sshd[11087]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:37:03 monitor.sanren.ac.za sshd[11090]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:37:29 monitor.sanren.ac.za sshd[11097]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:38:50 monitor.sanren.ac.za sshd[11151]: Accepted password for nagios from 159.8.74.138 port 63028 ssh2
Aug 04 06:38:50 monitor.sanren.ac.za sshd[11151]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:38:50 monitor.sanren.ac.za systemd-logind[422]: New session 6043 of user nagios.
Aug 04 06:38:50 monitor.sanren.ac.za systemd[1]: Starting Session 6043 of user nagios.
Aug 04 06:38:50 monitor.sanren.ac.za systemd[1]: Started Session 6043 of user nagios.
Aug 04 06:40:36 monitor.sanren.ac.za sshd[11151]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:41:49 monitor.sanren.ac.za sshd[11243]: Accepted password for nagios from 119.81.251.5 port 62738 ssh2
Aug 04 06:41:49 monitor.sanren.ac.za sshd[11243]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:41:49 monitor.sanren.ac.za systemd-logind[422]: New session 6047 of user nagios.
Aug 04 06:41:49 monitor.sanren.ac.za systemd[1]: Starting Session 6047 of user nagios.
Aug 04 06:41:49 monitor.sanren.ac.za systemd[1]: Started Session 6047 of user nagios.
Aug 04 06:43:11 monitor.sanren.ac.za sshd[11243]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:43:47 monitor.sanren.ac.za sshd[11269]: Accepted password for nagios from 159.8.91.135 port 63739 ssh2
Aug 04 06:43:47 monitor.sanren.ac.za sshd[11269]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:43:47 monitor.sanren.ac.za systemd-logind[422]: New session 6048 of user nagios.
Aug 04 06:43:47 monitor.sanren.ac.za systemd[1]: Starting Session 6048 of user nagios.
Aug 04 06:43:47 monitor.sanren.ac.za systemd[1]: Started Session 6048 of user nagios.
Aug 04 06:44:26 monitor.sanren.ac.za sshd[11276]: Accepted password for nagios from 159.8.99.201 port 61664 ssh2
Aug 04 06:44:26 monitor.sanren.ac.za sshd[11276]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:44:26 monitor.sanren.ac.za systemd-logind[422]: New session 6049 of user nagios.
Aug 04 06:44:26 monitor.sanren.ac.za systemd[1]: Starting Session 6049 of user nagios.
Aug 04 06:44:26 monitor.sanren.ac.za systemd[1]: Started Session 6049 of user nagios.
Aug 04 06:44:59 monitor.sanren.ac.za sshd[11269]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:45:44 monitor.sanren.ac.za sshd[11276]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:45:49 monitor.sanren.ac.za sshd[11298]: Accepted password for nagios from 159.8.91.141 port 63362 ssh2
Aug 04 06:45:49 monitor.sanren.ac.za sshd[11298]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:45:49 monitor.sanren.ac.za systemd[1]: Starting Session 6050 of user nagios.
Aug 04 06:45:49 monitor.sanren.ac.za systemd-logind[422]: New session 6050 of user nagios.
Aug 04 06:45:49 monitor.sanren.ac.za systemd[1]: Started Session 6050 of user nagios.
Aug 04 06:46:37 monitor.sanren.ac.za sshd[11298]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:46:43 monitor.sanren.ac.za sshd[11321]: Accepted password for nagios from 161.202.10.196 port 63678 ssh2
Aug 04 06:46:43 monitor.sanren.ac.za sshd[11321]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:46:43 monitor.sanren.ac.za systemd-logind[422]: New session 6051 of user nagios.
Aug 04 06:46:43 monitor.sanren.ac.za systemd[1]: Starting Session 6051 of user nagios.
Aug 04 06:46:43 monitor.sanren.ac.za systemd[1]: Started Session 6051 of user nagios.
Aug 04 06:47:11 monitor.sanren.ac.za sshd[11336]: Accepted password for nagios from 169.53.74.170 port 61301 ssh2
Aug 04 06:47:11 monitor.sanren.ac.za sshd[11336]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:47:11 monitor.sanren.ac.za systemd-logind[422]: New session 6052 of user nagios.
Aug 04 06:47:11 monitor.sanren.ac.za systemd[1]: Starting Session 6052 of user nagios.
Aug 04 06:47:11 monitor.sanren.ac.za systemd[1]: Started Session 6052 of user nagios.
Aug 04 06:48:13 monitor.sanren.ac.za sshd[11321]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:48:27 monitor.sanren.ac.za sshd[11336]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:49:15 monitor.sanren.ac.za sshd[11360]: Accepted password for nagios from 159.8.91.142 port 63139 ssh2
Aug 04 06:49:15 monitor.sanren.ac.za sshd[11360]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:49:15 monitor.sanren.ac.za systemd-logind[422]: New session 6053 of user nagios.
Aug 04 06:49:15 monitor.sanren.ac.za systemd[1]: Starting Session 6053 of user nagios.
Aug 04 06:49:15 monitor.sanren.ac.za systemd[1]: Started Session 6053 of user nagios.
Aug 04 06:50:43 monitor.sanren.ac.za sshd[11360]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:51:14 monitor.sanren.ac.za sshd[11396]: Accepted password for nagios from 184.173.26.170 port 61826 ssh2
Aug 04 06:51:14 monitor.sanren.ac.za sshd[11396]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:51:14 monitor.sanren.ac.za systemd-logind[422]: New session 6055 of user nagios.
Aug 04 06:51:14 monitor.sanren.ac.za systemd[1]: Starting Session 6055 of user nagios.
Aug 04 06:51:14 monitor.sanren.ac.za systemd[1]: Started Session 6055 of user nagios.
Aug 04 06:52:37 monitor.sanren.ac.za sshd[11396]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:54:33 monitor.sanren.ac.za nagios3[540]: Auto-save of retention data completed successfully.
Aug 04 06:56:58 monitor.sanren.ac.za sshd[11492]: Accepted password for nagios from 159.8.74.142 port 61894 ssh2
Aug 04 06:56:58 monitor.sanren.ac.za sshd[11492]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:56:58 monitor.sanren.ac.za systemd-logind[422]: New session 6056 of user nagios.
Aug 04 06:56:58 monitor.sanren.ac.za systemd[1]: Starting Session 6056 of user nagios.
Aug 04 06:56:58 monitor.sanren.ac.za systemd[1]: Started Session 6056 of user nagios.
Aug 04 06:57:17 monitor.sanren.ac.za sshd[11501]: Accepted password for nagios from 159.8.101.75 port 64024 ssh2
Aug 04 06:57:17 monitor.sanren.ac.za sshd[11501]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:57:17 monitor.sanren.ac.za systemd-logind[422]: New session 6057 of user nagios.
Aug 04 06:57:17 monitor.sanren.ac.za systemd[1]: Starting Session 6057 of user nagios.
Aug 04 06:57:17 monitor.sanren.ac.za systemd[1]: Started Session 6057 of user nagios.
Aug 04 06:57:27 monitor.sanren.ac.za sshd[11504]: Accepted password for nagios from 161.202.10.199 port 63383 ssh2
Aug 04 06:57:27 monitor.sanren.ac.za sshd[11504]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:57:27 monitor.sanren.ac.za systemd-logind[422]: New session 6058 of user nagios.
Aug 04 06:57:27 monitor.sanren.ac.za systemd[1]: Starting Session 6058 of user nagios.
Aug 04 06:57:27 monitor.sanren.ac.za systemd[1]: Started Session 6058 of user nagios.
Aug 04 06:57:27 monitor.sanren.ac.za sshd[11506]: Accepted password for nagios from 159.8.91.135 port 63320 ssh2
Aug 04 06:57:27 monitor.sanren.ac.za sshd[11506]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:57:27 monitor.sanren.ac.za systemd[1]: Starting Session 6059 of user nagios.
Aug 04 06:57:27 monitor.sanren.ac.za systemd-logind[422]: New session 6059 of user nagios.
Aug 04 06:57:27 monitor.sanren.ac.za systemd[1]: Started Session 6059 of user nagios.
Aug 04 06:57:30 monitor.sanren.ac.za sshd[11508]: Accepted password for nagios from 161.202.10.196 port 63697 ssh2
Aug 04 06:57:30 monitor.sanren.ac.za sshd[11508]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:57:30 monitor.sanren.ac.za systemd[1]: Starting Session 6060 of user nagios.
Aug 04 06:57:30 monitor.sanren.ac.za systemd-logind[422]: New session 6060 of user nagios.
Aug 04 06:57:30 monitor.sanren.ac.za systemd[1]: Started Session 6060 of user nagios.
Aug 04 06:57:51 monitor.sanren.ac.za sshd[11516]: Accepted password for nagios from 184.173.26.172 port 62393 ssh2
Aug 04 06:57:51 monitor.sanren.ac.za sshd[11516]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:57:51 monitor.sanren.ac.za systemd[1]: Starting Session 6061 of user nagios.
Aug 04 06:57:51 monitor.sanren.ac.za systemd-logind[422]: New session 6061 of user nagios.
Aug 04 06:57:51 monitor.sanren.ac.za systemd[1]: Started Session 6061 of user nagios.
Aug 04 06:58:04 monitor.sanren.ac.za sshd[11492]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:58:40 monitor.sanren.ac.za sshd[11508]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:58:41 monitor.sanren.ac.za sshd[11525]: Accepted password for nagios from 119.81.230.3 port 62044 ssh2
Aug 04 06:58:41 monitor.sanren.ac.za sshd[11525]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:58:41 monitor.sanren.ac.za systemd[1]: Starting Session 6062 of user nagios.
Aug 04 06:58:41 monitor.sanren.ac.za systemd-logind[422]: New session 6062 of user nagios.
Aug 04 06:58:41 monitor.sanren.ac.za systemd[1]: Started Session 6062 of user nagios.
Aug 04 06:58:49 monitor.sanren.ac.za sshd[11537]: Accepted password for nagios from 52.26.125.248 port 53544 ssh2
Aug 04 06:58:49 monitor.sanren.ac.za sshd[11537]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:58:49 monitor.sanren.ac.za systemd[1]: Starting Session 6063 of user nagios.
Aug 04 06:58:49 monitor.sanren.ac.za systemd-logind[422]: New session 6063 of user nagios.
Aug 04 06:58:49 monitor.sanren.ac.za systemd[1]: Started Session 6063 of user nagios.
Aug 04 06:58:54 monitor.sanren.ac.za sshd[11504]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:58:57 monitor.sanren.ac.za sshd[11501]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:59:02 monitor.sanren.ac.za sshd[11506]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:59:20 monitor.sanren.ac.za sshd[11547]: Accepted password for nagios from 161.202.10.201 port 62732 ssh2
Aug 04 06:59:20 monitor.sanren.ac.za sshd[11547]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:59:20 monitor.sanren.ac.za systemd-logind[422]: New session 6064 of user nagios.
Aug 04 06:59:20 monitor.sanren.ac.za systemd[1]: Starting Session 6064 of user nagios.
Aug 04 06:59:20 monitor.sanren.ac.za systemd[1]: Started Session 6064 of user nagios.
Aug 04 06:59:40 monitor.sanren.ac.za sshd[11516]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:59:44 monitor.sanren.ac.za sshd[11547]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:59:53 monitor.sanren.ac.za sshd[11537]: pam_unix(sshd:session): session closed for user nagios
Aug 04 06:59:57 monitor.sanren.ac.za sshd[11557]: Accepted password for nagios from 159.8.91.138 port 63049 ssh2
Aug 04 06:59:57 monitor.sanren.ac.za sshd[11557]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 06:59:57 monitor.sanren.ac.za systemd[1]: Starting Session 6065 of user nagios.
Aug 04 06:59:57 monitor.sanren.ac.za systemd-logind[422]: New session 6065 of user nagios.
Aug 04 06:59:57 monitor.sanren.ac.za systemd[1]: Started Session 6065 of user nagios.
Aug 04 07:00:36 monitor.sanren.ac.za sshd[11525]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:00:40 monitor.sanren.ac.za sshd[11572]: Accepted password for nagios from 161.202.104.188 port 63190 ssh2
Aug 04 07:00:40 monitor.sanren.ac.za sshd[11572]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:00:40 monitor.sanren.ac.za systemd[1]: Starting Session 6067 of user nagios.
Aug 04 07:00:40 monitor.sanren.ac.za systemd-logind[422]: New session 6067 of user nagios.
Aug 04 07:00:40 monitor.sanren.ac.za systemd[1]: Started Session 6067 of user nagios.
Aug 04 07:01:39 monitor.sanren.ac.za sshd[11557]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:02:13 monitor.sanren.ac.za sshd[11612]: Accepted password for nagios from 184.173.26.170 port 61433 ssh2
Aug 04 07:02:13 monitor.sanren.ac.za sshd[11612]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:02:13 monitor.sanren.ac.za systemd-logind[422]: New session 6068 of user nagios.
Aug 04 07:02:13 monitor.sanren.ac.za systemd[1]: Starting Session 6068 of user nagios.
Aug 04 07:02:13 monitor.sanren.ac.za systemd[1]: Started Session 6068 of user nagios.
Aug 04 07:02:28 monitor.sanren.ac.za sshd[11618]: Accepted password for nagios from 52.5.159.1 port 62813 ssh2
Aug 04 07:02:28 monitor.sanren.ac.za sshd[11618]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:02:28 monitor.sanren.ac.za systemd-logind[422]: New session 6069 of user nagios.
Aug 04 07:02:28 monitor.sanren.ac.za systemd[1]: Starting Session 6069 of user nagios.
Aug 04 07:02:28 monitor.sanren.ac.za systemd[1]: Started Session 6069 of user nagios.
Aug 04 07:02:58 monitor.sanren.ac.za sshd[11572]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:03:37 monitor.sanren.ac.za sshd[11618]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:03:48 monitor.sanren.ac.za sshd[11612]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:08:52 monitor.sanren.ac.za sshd[11709]: Accepted password for nagios from 184.173.26.165 port 63226 ssh2
Aug 04 07:08:52 monitor.sanren.ac.za sshd[11709]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:08:52 monitor.sanren.ac.za systemd[1]: Starting Session 6070 of user nagios.
Aug 04 07:08:52 monitor.sanren.ac.za systemd-logind[422]: New session 6070 of user nagios.
Aug 04 07:08:52 monitor.sanren.ac.za systemd[1]: Started Session 6070 of user nagios.
Aug 04 07:09:48 monitor.sanren.ac.za sshd[11755]: Accepted password for nagios from 159.8.99.200 port 62997 ssh2
Aug 04 07:09:48 monitor.sanren.ac.za sshd[11755]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:09:48 monitor.sanren.ac.za systemd[1]: Starting Session 6072 of user nagios.
Aug 04 07:09:48 monitor.sanren.ac.za systemd-logind[422]: New session 6072 of user nagios.
Aug 04 07:09:48 monitor.sanren.ac.za systemd[1]: Started Session 6072 of user nagios.
Aug 04 07:10:03 monitor.sanren.ac.za sshd[11709]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:11:04 monitor.sanren.ac.za sshd[11755]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:13:04 monitor.sanren.ac.za sshd[11817]: Accepted password for nagios from 161.202.10.196 port 62804 ssh2
Aug 04 07:13:04 monitor.sanren.ac.za sshd[11817]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:13:04 monitor.sanren.ac.za systemd-logind[422]: New session 6074 of user nagios.
Aug 04 07:13:04 monitor.sanren.ac.za systemd[1]: Starting Session 6074 of user nagios.
Aug 04 07:13:04 monitor.sanren.ac.za systemd[1]: Started Session 6074 of user nagios.
Aug 04 07:14:01 monitor.sanren.ac.za sshd[11817]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:14:11 monitor.sanren.ac.za sshd[11826]: Accepted password for nagios from 159.8.99.200 port 64015 ssh2
Aug 04 07:14:11 monitor.sanren.ac.za sshd[11826]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:14:11 monitor.sanren.ac.za systemd-logind[422]: New session 6075 of user nagios.
Aug 04 07:14:11 monitor.sanren.ac.za systemd[1]: Starting Session 6075 of user nagios.
Aug 04 07:14:11 monitor.sanren.ac.za systemd[1]: Started Session 6075 of user nagios.
Aug 04 07:15:12 monitor.sanren.ac.za sshd[11826]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:16:21 monitor.sanren.ac.za sshd[11865]: Accepted password for nagios from 159.8.91.137 port 63875 ssh2
Aug 04 07:16:21 monitor.sanren.ac.za sshd[11865]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:16:21 monitor.sanren.ac.za systemd-logind[422]: New session 6076 of user nagios.
Aug 04 07:16:21 monitor.sanren.ac.za systemd[1]: Starting Session 6076 of user nagios.
Aug 04 07:16:21 monitor.sanren.ac.za systemd[1]: Started Session 6076 of user nagios.
Aug 04 07:17:20 monitor.sanren.ac.za sshd[11865]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:18:35 monitor.sanren.ac.za sshd[11903]: Accepted password for nagios from 173.193.97.4 port 62395 ssh2
Aug 04 07:18:35 monitor.sanren.ac.za sshd[11903]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:18:35 monitor.sanren.ac.za systemd[1]: Starting Session 6078 of user nagios.
Aug 04 07:18:35 monitor.sanren.ac.za systemd-logind[422]: New session 6078 of user nagios.
Aug 04 07:18:35 monitor.sanren.ac.za systemd[1]: Started Session 6078 of user nagios.
Aug 04 07:19:24 monitor.sanren.ac.za sshd[11903]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:19:34 monitor.sanren.ac.za sshd[11919]: Accepted password for nagios from 159.8.99.201 port 62458 ssh2
Aug 04 07:19:34 monitor.sanren.ac.za sshd[11919]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:19:34 monitor.sanren.ac.za systemd-logind[422]: New session 6079 of user nagios.
Aug 04 07:19:34 monitor.sanren.ac.za systemd[1]: Starting Session 6079 of user nagios.
Aug 04 07:19:34 monitor.sanren.ac.za systemd[1]: Started Session 6079 of user nagios.
Aug 04 07:20:15 monitor.sanren.ac.za sshd[11933]: Accepted password for nagios from 54.173.76.20 port 56207 ssh2
Aug 04 07:20:15 monitor.sanren.ac.za sshd[11933]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:20:15 monitor.sanren.ac.za systemd-logind[422]: New session 6081 of user nagios.
Aug 04 07:20:15 monitor.sanren.ac.za systemd[1]: Starting Session 6081 of user nagios.
Aug 04 07:20:15 monitor.sanren.ac.za systemd[1]: Started Session 6081 of user nagios.
Aug 04 07:20:36 monitor.sanren.ac.za sshd[11937]: Accepted password for nagios from 119.81.251.6 port 63177 ssh2
Aug 04 07:20:36 monitor.sanren.ac.za sshd[11937]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:20:36 monitor.sanren.ac.za systemd[1]: Starting Session 6082 of user nagios.
Aug 04 07:20:36 monitor.sanren.ac.za systemd-logind[422]: New session 6082 of user nagios.
Aug 04 07:20:36 monitor.sanren.ac.za systemd[1]: Started Session 6082 of user nagios.
Aug 04 07:20:41 monitor.sanren.ac.za sshd[11933]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:21:05 monitor.sanren.ac.za sshd[11919]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:21:58 monitor.sanren.ac.za sshd[11937]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:22:04 monitor.sanren.ac.za sshd[11982]: Accepted password for nagios from 159.8.101.78 port 63743 ssh2
Aug 04 07:22:04 monitor.sanren.ac.za sshd[11982]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:22:04 monitor.sanren.ac.za systemd-logind[422]: New session 6083 of user nagios.
Aug 04 07:22:04 monitor.sanren.ac.za systemd[1]: Starting Session 6083 of user nagios.
Aug 04 07:22:04 monitor.sanren.ac.za systemd[1]: Started Session 6083 of user nagios.
Aug 04 07:22:04 monitor.sanren.ac.za sshd[11983]: Accepted password for nagios from 159.8.74.132 port 61940 ssh2
Aug 04 07:22:04 monitor.sanren.ac.za sshd[11983]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:22:04 monitor.sanren.ac.za systemd[1]: Starting Session 6084 of user nagios.
Aug 04 07:22:04 monitor.sanren.ac.za systemd[1]: Started Session 6084 of user nagios.
Aug 04 07:22:04 monitor.sanren.ac.za systemd-logind[422]: New session 6084 of user nagios.
Aug 04 07:23:08 monitor.sanren.ac.za sshd[11983]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:23:49 monitor.sanren.ac.za sshd[11982]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:23:50 monitor.sanren.ac.za sshd[12004]: Accepted password for nagios from 159.8.91.134 port 64225 ssh2
Aug 04 07:23:50 monitor.sanren.ac.za sshd[12004]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:23:50 monitor.sanren.ac.za systemd-logind[422]: New session 6085 of user nagios.
Aug 04 07:23:50 monitor.sanren.ac.za systemd[1]: Starting Session 6085 of user nagios.
Aug 04 07:23:50 monitor.sanren.ac.za systemd[1]: Started Session 6085 of user nagios.
Aug 04 07:25:46 monitor.sanren.ac.za sshd[12004]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:26:02 monitor.sanren.ac.za sshd[12030]: Accepted password for nagios from 52.2.249.120 port 56939 ssh2
Aug 04 07:26:02 monitor.sanren.ac.za sshd[12030]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:26:02 monitor.sanren.ac.za systemd-logind[422]: New session 6086 of user nagios.
Aug 04 07:26:02 monitor.sanren.ac.za systemd[1]: Starting Session 6086 of user nagios.
Aug 04 07:26:02 monitor.sanren.ac.za systemd[1]: Started Session 6086 of user nagios.
Aug 04 07:26:25 monitor.sanren.ac.za sshd[12049]: Accepted password for nagios from 119.81.230.3 port 62437 ssh2
Aug 04 07:26:25 monitor.sanren.ac.za sshd[12049]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:26:25 monitor.sanren.ac.za systemd[1]: Starting Session 6087 of user nagios.
Aug 04 07:26:25 monitor.sanren.ac.za systemd-logind[422]: New session 6087 of user nagios.
Aug 04 07:26:25 monitor.sanren.ac.za systemd[1]: Started Session 6087 of user nagios.
Aug 04 07:27:02 monitor.sanren.ac.za sshd[12030]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:27:13 monitor.sanren.ac.za sshd[12073]: Accepted password for nagios from 119.81.251.5 port 62432 ssh2
Aug 04 07:27:13 monitor.sanren.ac.za sshd[12073]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:27:13 monitor.sanren.ac.za systemd-logind[422]: New session 6088 of user nagios.
Aug 04 07:27:13 monitor.sanren.ac.za systemd[1]: Starting Session 6088 of user nagios.
Aug 04 07:27:13 monitor.sanren.ac.za systemd[1]: Started Session 6088 of user nagios.
Aug 04 07:28:25 monitor.sanren.ac.za sshd[12049]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:28:30 monitor.sanren.ac.za sshd[12073]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:29:41 monitor.sanren.ac.za sshd[12098]: Accepted password for nagios from 161.202.135.4 port 63829 ssh2
Aug 04 07:29:41 monitor.sanren.ac.za sshd[12098]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:29:41 monitor.sanren.ac.za systemd-logind[422]: New session 6089 of user nagios.
Aug 04 07:29:41 monitor.sanren.ac.za systemd[1]: Starting Session 6089 of user nagios.
Aug 04 07:29:41 monitor.sanren.ac.za systemd[1]: Started Session 6089 of user nagios.
Aug 04 07:30:50 monitor.sanren.ac.za sshd[12117]: Accepted password for nagios from 159.8.91.141 port 63304 ssh2
Aug 04 07:30:50 monitor.sanren.ac.za sshd[12117]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:30:50 monitor.sanren.ac.za systemd-logind[422]: New session 6091 of user nagios.
Aug 04 07:30:50 monitor.sanren.ac.za systemd[1]: Starting Session 6091 of user nagios.
Aug 04 07:30:50 monitor.sanren.ac.za systemd[1]: Started Session 6091 of user nagios.
Aug 04 07:30:50 monitor.sanren.ac.za sshd[12098]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:31:36 monitor.sanren.ac.za sshd[12144]: Accepted password for nagios from 159.8.99.200 port 62934 ssh2
Aug 04 07:31:36 monitor.sanren.ac.za sshd[12144]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:31:36 monitor.sanren.ac.za systemd-logind[422]: New session 6092 of user nagios.
Aug 04 07:31:36 monitor.sanren.ac.za systemd[1]: Starting Session 6092 of user nagios.
Aug 04 07:31:36 monitor.sanren.ac.za systemd[1]: Started Session 6092 of user nagios.
Aug 04 07:32:37 monitor.sanren.ac.za sshd[9611]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:32:46 monitor.sanren.ac.za sshd[12170]: Accepted password for nagios from 159.8.99.201 port 62103 ssh2
Aug 04 07:32:46 monitor.sanren.ac.za sshd[12170]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:32:46 monitor.sanren.ac.za systemd-logind[422]: New session 6093 of user nagios.
Aug 04 07:32:46 monitor.sanren.ac.za systemd[1]: Starting Session 6093 of user nagios.
Aug 04 07:32:46 monitor.sanren.ac.za systemd[1]: Started Session 6093 of user nagios.
Aug 04 07:32:57 monitor.sanren.ac.za sshd[12144]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:33:09 monitor.sanren.ac.za sshd[12117]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:34:03 monitor.sanren.ac.za sshd[12170]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:34:04 monitor.sanren.ac.za sshd[12184]: Accepted password for nagios from 159.8.101.78 port 64034 ssh2
Aug 04 07:34:04 monitor.sanren.ac.za sshd[12184]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:34:04 monitor.sanren.ac.za systemd-logind[422]: New session 6094 of user nagios.
Aug 04 07:34:04 monitor.sanren.ac.za systemd[1]: Starting Session 6094 of user nagios.
Aug 04 07:34:04 monitor.sanren.ac.za systemd[1]: Started Session 6094 of user nagios.
Aug 04 07:34:33 monitor.sanren.ac.za sshd[12184]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:35:51 monitor.sanren.ac.za sshd[12205]: Accepted password for nagios from 184.173.26.170 port 62040 ssh2
Aug 04 07:35:51 monitor.sanren.ac.za sshd[12205]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:35:51 monitor.sanren.ac.za systemd-logind[422]: New session 6095 of user nagios.
Aug 04 07:35:51 monitor.sanren.ac.za systemd[1]: Starting Session 6095 of user nagios.
Aug 04 07:35:51 monitor.sanren.ac.za systemd[1]: Started Session 6095 of user nagios.
Aug 04 07:36:09 monitor.sanren.ac.za sshd[12211]: Accepted password for nagios from 119.81.230.5 port 62067 ssh2
Aug 04 07:36:09 monitor.sanren.ac.za sshd[12211]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:36:09 monitor.sanren.ac.za systemd-logind[422]: New session 6096 of user nagios.
Aug 04 07:36:09 monitor.sanren.ac.za systemd[1]: Starting Session 6096 of user nagios.
Aug 04 07:36:09 monitor.sanren.ac.za systemd[1]: Started Session 6096 of user nagios.
Aug 04 07:37:18 monitor.sanren.ac.za sshd[12205]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:37:30 monitor.sanren.ac.za sshd[12211]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:38:52 monitor.sanren.ac.za sshd[12267]: Accepted password for nagios from 119.81.251.5 port 62665 ssh2
Aug 04 07:38:52 monitor.sanren.ac.za sshd[12267]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:38:52 monitor.sanren.ac.za systemd-logind[422]: New session 6097 of user nagios.
Aug 04 07:38:52 monitor.sanren.ac.za systemd[1]: Starting Session 6097 of user nagios.
Aug 04 07:38:52 monitor.sanren.ac.za systemd[1]: Started Session 6097 of user nagios.
Aug 04 07:39:43 monitor.sanren.ac.za sshd[12267]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:40:09 monitor.sanren.ac.za sshd[12321]: Accepted password for nagios from 119.81.251.5 port 63022 ssh2
Aug 04 07:40:09 monitor.sanren.ac.za sshd[12321]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:40:09 monitor.sanren.ac.za systemd-logind[422]: New session 6100 of user nagios.
Aug 04 07:40:09 monitor.sanren.ac.za systemd[1]: Starting Session 6100 of user nagios.
Aug 04 07:40:09 monitor.sanren.ac.za systemd[1]: Started Session 6100 of user nagios.
Aug 04 07:41:05 monitor.sanren.ac.za sshd[12321]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:41:07 monitor.sanren.ac.za sshd[12333]: Accepted password for nagios from 104.197.40.240 port 57562 ssh2
Aug 04 07:41:07 monitor.sanren.ac.za sshd[12333]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:41:07 monitor.sanren.ac.za systemd-logind[422]: New session 6102 of user nagios.
Aug 04 07:41:07 monitor.sanren.ac.za systemd[1]: Starting Session 6102 of user nagios.
Aug 04 07:41:07 monitor.sanren.ac.za systemd[1]: Started Session 6102 of user nagios.
Aug 04 07:42:10 monitor.sanren.ac.za sshd[12369]: Accepted password for nagios from 159.8.91.135 port 62779 ssh2
Aug 04 07:42:10 monitor.sanren.ac.za sshd[12369]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:42:10 monitor.sanren.ac.za systemd-logind[422]: New session 6103 of user nagios.
Aug 04 07:42:10 monitor.sanren.ac.za systemd[1]: Starting Session 6103 of user nagios.
Aug 04 07:42:10 monitor.sanren.ac.za systemd[1]: Started Session 6103 of user nagios.
Aug 04 07:42:27 monitor.sanren.ac.za sshd[12333]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:43:48 monitor.sanren.ac.za sshd[12369]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:44:17 monitor.sanren.ac.za sshd[12393]: Accepted password for nagios from 52.0.147.141 port 50372 ssh2
Aug 04 07:44:17 monitor.sanren.ac.za sshd[12393]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:44:17 monitor.sanren.ac.za systemd-logind[422]: New session 6104 of user nagios.
Aug 04 07:44:17 monitor.sanren.ac.za systemd[1]: Starting Session 6104 of user nagios.
Aug 04 07:44:17 monitor.sanren.ac.za systemd[1]: Started Session 6104 of user nagios.
Aug 04 07:45:10 monitor.sanren.ac.za sshd[12407]: Accepted password for nagios from 161.202.10.201 port 62617 ssh2
Aug 04 07:45:10 monitor.sanren.ac.za sshd[12407]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:45:10 monitor.sanren.ac.za systemd-logind[422]: New session 6105 of user nagios.
Aug 04 07:45:10 monitor.sanren.ac.za systemd[1]: Starting Session 6105 of user nagios.
Aug 04 07:45:10 monitor.sanren.ac.za systemd[1]: Started Session 6105 of user nagios.
Aug 04 07:45:54 monitor.sanren.ac.za sshd[12418]: Accepted password for nagios from 159.8.91.136 port 62098 ssh2
Aug 04 07:45:54 monitor.sanren.ac.za sshd[12418]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:45:54 monitor.sanren.ac.za systemd-logind[422]: New session 6106 of user nagios.
Aug 04 07:45:54 monitor.sanren.ac.za systemd[1]: Starting Session 6106 of user nagios.
Aug 04 07:45:54 monitor.sanren.ac.za systemd[1]: Started Session 6106 of user nagios.
Aug 04 07:46:00 monitor.sanren.ac.za sshd[12421]: Accepted password for nagios from 192.99.81.27 port 52412 ssh2
Aug 04 07:46:00 monitor.sanren.ac.za sshd[12421]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:46:00 monitor.sanren.ac.za systemd-logind[422]: New session 6107 of user nagios.
Aug 04 07:46:00 monitor.sanren.ac.za systemd[1]: Starting Session 6107 of user nagios.
Aug 04 07:46:00 monitor.sanren.ac.za systemd[1]: Started Session 6107 of user nagios.
Aug 04 07:46:33 monitor.sanren.ac.za sshd[12393]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:46:39 monitor.sanren.ac.za sshd[12407]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:47:03 monitor.sanren.ac.za sshd[12418]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:47:37 monitor.sanren.ac.za sshd[12466]: Accepted password for nagios from 161.202.10.203 port 64036 ssh2
Aug 04 07:47:37 monitor.sanren.ac.za sshd[12466]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:47:37 monitor.sanren.ac.za systemd-logind[422]: New session 6108 of user nagios.
Aug 04 07:47:37 monitor.sanren.ac.za systemd[1]: Starting Session 6108 of user nagios.
Aug 04 07:47:37 monitor.sanren.ac.za systemd[1]: Started Session 6108 of user nagios.
Aug 04 07:48:01 monitor.sanren.ac.za sshd[12466]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:49:55 monitor.sanren.ac.za sshd[12490]: Accepted password for nagios from 168.1.110.140 port 63176 ssh2
Aug 04 07:49:55 monitor.sanren.ac.za sshd[12490]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:49:55 monitor.sanren.ac.za systemd-logind[422]: New session 6109 of user nagios.
Aug 04 07:49:55 monitor.sanren.ac.za systemd[1]: Starting Session 6109 of user nagios.
Aug 04 07:49:55 monitor.sanren.ac.za systemd[1]: Started Session 6109 of user nagios.
Aug 04 07:50:16 monitor.sanren.ac.za sshd[12500]: Accepted password for nagios from 161.202.10.203 port 63681 ssh2
Aug 04 07:50:16 monitor.sanren.ac.za sshd[12500]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:50:16 monitor.sanren.ac.za systemd-logind[422]: New session 6111 of user nagios.
Aug 04 07:50:16 monitor.sanren.ac.za systemd[1]: Starting Session 6111 of user nagios.
Aug 04 07:50:16 monitor.sanren.ac.za systemd[1]: Started Session 6111 of user nagios.
Aug 04 07:50:46 monitor.sanren.ac.za sshd[12421]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:52:04 monitor.sanren.ac.za sshd[12490]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:52:19 monitor.sanren.ac.za sshd[12500]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:53:25 monitor.sanren.ac.za sshd[12561]: Accepted password for nagios from 159.8.91.136 port 63345 ssh2
Aug 04 07:53:25 monitor.sanren.ac.za sshd[12561]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:53:25 monitor.sanren.ac.za systemd-logind[422]: New session 6112 of user nagios.
Aug 04 07:53:25 monitor.sanren.ac.za systemd[1]: Starting Session 6112 of user nagios.
Aug 04 07:53:25 monitor.sanren.ac.za systemd[1]: Started Session 6112 of user nagios.
Aug 04 07:54:33 monitor.sanren.ac.za nagios3[540]: Auto-save of retention data completed successfully.
Aug 04 07:54:46 monitor.sanren.ac.za sshd[12588]: Accepted password for nagios from 159.8.99.200 port 63183 ssh2
Aug 04 07:54:46 monitor.sanren.ac.za sshd[12588]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:54:46 monitor.sanren.ac.za systemd-logind[422]: New session 6114 of user nagios.
Aug 04 07:54:46 monitor.sanren.ac.za systemd[1]: Starting Session 6114 of user nagios.
Aug 04 07:54:46 monitor.sanren.ac.za systemd[1]: Started Session 6114 of user nagios.
Aug 04 07:54:47 monitor.sanren.ac.za sshd[12561]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:55:37 monitor.sanren.ac.za sshd[12600]: Accepted password for nagios from 159.8.99.204 port 62194 ssh2
Aug 04 07:55:37 monitor.sanren.ac.za sshd[12600]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:55:37 monitor.sanren.ac.za systemd-logind[422]: New session 6115 of user nagios.
Aug 04 07:55:37 monitor.sanren.ac.za systemd[1]: Starting Session 6115 of user nagios.
Aug 04 07:55:37 monitor.sanren.ac.za systemd[1]: Started Session 6115 of user nagios.
Aug 04 07:55:58 monitor.sanren.ac.za sshd[12606]: Accepted password for nagios from 161.202.10.199 port 63590 ssh2
Aug 04 07:55:58 monitor.sanren.ac.za sshd[12606]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:55:58 monitor.sanren.ac.za systemd-logind[422]: New session 6116 of user nagios.
Aug 04 07:55:58 monitor.sanren.ac.za systemd[1]: Starting Session 6116 of user nagios.
Aug 04 07:55:58 monitor.sanren.ac.za systemd[1]: Started Session 6116 of user nagios.
Aug 04 07:56:00 monitor.sanren.ac.za sshd[12608]: Accepted password for nagios from 173.193.97.5 port 63300 ssh2
Aug 04 07:56:00 monitor.sanren.ac.za sshd[12608]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:56:00 monitor.sanren.ac.za systemd[1]: Starting Session 6117 of user nagios.
Aug 04 07:56:00 monitor.sanren.ac.za systemd-logind[422]: New session 6117 of user nagios.
Aug 04 07:56:00 monitor.sanren.ac.za systemd[1]: Started Session 6117 of user nagios.
Aug 04 07:56:13 monitor.sanren.ac.za sshd[12617]: Accepted password for nagios from 159.8.74.142 port 62008 ssh2
Aug 04 07:56:13 monitor.sanren.ac.za sshd[12617]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 07:56:13 monitor.sanren.ac.za systemd-logind[422]: New session 6118 of user nagios.
Aug 04 07:56:13 monitor.sanren.ac.za systemd[1]: Starting Session 6118 of user nagios.
Aug 04 07:56:13 monitor.sanren.ac.za systemd[1]: Started Session 6118 of user nagios.
Aug 04 07:56:13 monitor.sanren.ac.za sshd[12588]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:56:36 monitor.sanren.ac.za sshd[12608]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:57:05 monitor.sanren.ac.za sshd[12617]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:57:35 monitor.sanren.ac.za sshd[12606]: pam_unix(sshd:session): session closed for user nagios
Aug 04 07:57:39 monitor.sanren.ac.za sshd[12600]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:02:10 monitor.sanren.ac.za sshd[12722]: Accepted password for nagios from 159.8.99.201 port 61482 ssh2
Aug 04 08:02:10 monitor.sanren.ac.za sshd[12722]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:02:10 monitor.sanren.ac.za systemd-logind[422]: New session 6120 of user nagios.
Aug 04 08:02:10 monitor.sanren.ac.za systemd[1]: Starting Session 6120 of user nagios.
Aug 04 08:02:10 monitor.sanren.ac.za systemd[1]: Started Session 6120 of user nagios.
Aug 04 08:02:38 monitor.sanren.ac.za sshd[12732]: Accepted password for nagios from 159.8.74.137 port 62802 ssh2
Aug 04 08:02:38 monitor.sanren.ac.za sshd[12732]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:02:38 monitor.sanren.ac.za systemd[1]: Starting Session 6121 of user nagios.
Aug 04 08:02:38 monitor.sanren.ac.za systemd-logind[422]: New session 6121 of user nagios.
Aug 04 08:02:38 monitor.sanren.ac.za systemd[1]: Started Session 6121 of user nagios.
Aug 04 08:03:22 monitor.sanren.ac.za sshd[12722]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:03:31 monitor.sanren.ac.za sshd[12748]: Accepted password for nagios from 159.8.91.134 port 63454 ssh2
Aug 04 08:03:31 monitor.sanren.ac.za sshd[12748]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:03:31 monitor.sanren.ac.za systemd-logind[422]: New session 6122 of user nagios.
Aug 04 08:03:31 monitor.sanren.ac.za systemd[1]: Starting Session 6122 of user nagios.
Aug 04 08:03:31 monitor.sanren.ac.za systemd[1]: Started Session 6122 of user nagios.
Aug 04 08:04:29 monitor.sanren.ac.za sshd[12732]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:05:05 monitor.sanren.ac.za sshd[12748]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:05:19 monitor.sanren.ac.za sshd[12768]: Accepted password for nagios from 161.202.10.196 port 62716 ssh2
Aug 04 08:05:19 monitor.sanren.ac.za sshd[12768]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:05:19 monitor.sanren.ac.za systemd-logind[422]: New session 6123 of user nagios.
Aug 04 08:05:19 monitor.sanren.ac.za systemd[1]: Starting Session 6123 of user nagios.
Aug 04 08:05:19 monitor.sanren.ac.za systemd[1]: Started Session 6123 of user nagios.
Aug 04 08:05:27 monitor.sanren.ac.za sshd[12771]: Accepted password for nagios from 159.8.74.132 port 63212 ssh2
Aug 04 08:05:27 monitor.sanren.ac.za sshd[12771]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:05:27 monitor.sanren.ac.za systemd-logind[422]: New session 6124 of user nagios.
Aug 04 08:05:27 monitor.sanren.ac.za systemd[1]: Starting Session 6124 of user nagios.
Aug 04 08:05:27 monitor.sanren.ac.za systemd[1]: Started Session 6124 of user nagios.
Aug 04 08:06:01 monitor.sanren.ac.za sshd[12782]: Accepted password for nagios from 161.202.10.201 port 61845 ssh2
Aug 04 08:06:01 monitor.sanren.ac.za sshd[12782]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:06:01 monitor.sanren.ac.za systemd-logind[422]: New session 6125 of user nagios.
Aug 04 08:06:01 monitor.sanren.ac.za systemd[1]: Starting Session 6125 of user nagios.
Aug 04 08:06:01 monitor.sanren.ac.za systemd[1]: Started Session 6125 of user nagios.
Aug 04 08:06:07 monitor.sanren.ac.za sshd[12768]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:06:35 monitor.sanren.ac.za sshd[12802]: Accepted password for nagios from 159.8.91.137 port 64326 ssh2
Aug 04 08:06:35 monitor.sanren.ac.za sshd[12802]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:06:35 monitor.sanren.ac.za systemd-logind[422]: New session 6126 of user nagios.
Aug 04 08:06:35 monitor.sanren.ac.za systemd[1]: Starting Session 6126 of user nagios.
Aug 04 08:06:35 monitor.sanren.ac.za systemd[1]: Started Session 6126 of user nagios.
Aug 04 08:06:41 monitor.sanren.ac.za sshd[12771]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:06:53 monitor.sanren.ac.za sshd[12815]: Accepted password for nagios from 168.1.110.140 port 64165 ssh2
Aug 04 08:06:53 monitor.sanren.ac.za sshd[12815]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:06:53 monitor.sanren.ac.za systemd-logind[422]: New session 6127 of user nagios.
Aug 04 08:06:53 monitor.sanren.ac.za systemd[1]: Starting Session 6127 of user nagios.
Aug 04 08:06:53 monitor.sanren.ac.za systemd[1]: Started Session 6127 of user nagios.
Aug 04 08:07:18 monitor.sanren.ac.za sshd[12815]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:07:39 monitor.sanren.ac.za sshd[12782]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:07:47 monitor.sanren.ac.za sshd[12802]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:11:19 monitor.sanren.ac.za sshd[12909]: Accepted password for nagios from 159.8.91.135 port 63544 ssh2
Aug 04 08:11:19 monitor.sanren.ac.za sshd[12909]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:11:19 monitor.sanren.ac.za systemd-logind[422]: New session 6130 of user nagios.
Aug 04 08:11:19 monitor.sanren.ac.za systemd[1]: Starting Session 6130 of user nagios.
Aug 04 08:11:19 monitor.sanren.ac.za systemd[1]: Started Session 6130 of user nagios.
Aug 04 08:12:35 monitor.sanren.ac.za sshd[12909]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:13:52 monitor.sanren.ac.za sshd[12956]: Accepted password for nagios from 159.8.91.138 port 64085 ssh2
Aug 04 08:13:52 monitor.sanren.ac.za sshd[12956]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:13:52 monitor.sanren.ac.za systemd-logind[422]: New session 6131 of user nagios.
Aug 04 08:13:52 monitor.sanren.ac.za systemd[1]: Starting Session 6131 of user nagios.
Aug 04 08:13:52 monitor.sanren.ac.za systemd[1]: Started Session 6131 of user nagios.
Aug 04 08:14:53 monitor.sanren.ac.za sshd[12967]: Accepted password for nagios from 161.202.10.201 port 62153 ssh2
Aug 04 08:14:53 monitor.sanren.ac.za sshd[12967]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:14:53 monitor.sanren.ac.za systemd-logind[422]: New session 6132 of user nagios.
Aug 04 08:14:53 monitor.sanren.ac.za systemd[1]: Starting Session 6132 of user nagios.
Aug 04 08:14:53 monitor.sanren.ac.za systemd[1]: Started Session 6132 of user nagios.
Aug 04 08:15:23 monitor.sanren.ac.za sshd[12973]: Accepted password for nagios from 161.202.135.9 port 64011 ssh2
Aug 04 08:15:23 monitor.sanren.ac.za sshd[12973]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:15:23 monitor.sanren.ac.za systemd-logind[422]: New session 6133 of user nagios.
Aug 04 08:15:23 monitor.sanren.ac.za systemd[1]: Starting Session 6133 of user nagios.
Aug 04 08:15:23 monitor.sanren.ac.za systemd[1]: Started Session 6133 of user nagios.
Aug 04 08:15:25 monitor.sanren.ac.za sshd[12967]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:16:02 monitor.sanren.ac.za sshd[12956]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:16:17 monitor.sanren.ac.za sshd[12973]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:16:38 monitor.sanren.ac.za sshd[13003]: Accepted password for nagios from 159.8.91.138 port 64904 ssh2
Aug 04 08:16:38 monitor.sanren.ac.za sshd[13003]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:16:38 monitor.sanren.ac.za systemd-logind[422]: New session 6134 of user nagios.
Aug 04 08:16:38 monitor.sanren.ac.za systemd[1]: Starting Session 6134 of user nagios.
Aug 04 08:16:38 monitor.sanren.ac.za systemd[1]: Started Session 6134 of user nagios.
Aug 04 08:17:17 monitor.sanren.ac.za sshd[13024]: Accepted password for nagios from 184.173.26.170 port 62472 ssh2
Aug 04 08:17:17 monitor.sanren.ac.za sshd[13024]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:17:17 monitor.sanren.ac.za systemd[1]: Starting Session 6136 of user nagios.
Aug 04 08:17:17 monitor.sanren.ac.za systemd-logind[422]: New session 6136 of user nagios.
Aug 04 08:17:17 monitor.sanren.ac.za systemd[1]: Started Session 6136 of user nagios.
Aug 04 08:17:23 monitor.sanren.ac.za sshd[13027]: Accepted password for nagios from 173.193.97.5 port 62658 ssh2
Aug 04 08:17:23 monitor.sanren.ac.za sshd[13027]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:17:23 monitor.sanren.ac.za systemd[1]: Starting Session 6137 of user nagios.
Aug 04 08:17:23 monitor.sanren.ac.za systemd-logind[422]: New session 6137 of user nagios.
Aug 04 08:17:23 monitor.sanren.ac.za systemd[1]: Started Session 6137 of user nagios.
Aug 04 08:18:19 monitor.sanren.ac.za sshd[13003]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:18:47 monitor.sanren.ac.za sshd[13054]: Accepted password for nagios from 159.8.91.142 port 61821 ssh2
Aug 04 08:18:47 monitor.sanren.ac.za sshd[13054]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:18:47 monitor.sanren.ac.za systemd-logind[422]: New session 6138 of user nagios.
Aug 04 08:18:47 monitor.sanren.ac.za systemd[1]: Starting Session 6138 of user nagios.
Aug 04 08:18:47 monitor.sanren.ac.za systemd[1]: Started Session 6138 of user nagios.
Aug 04 08:18:48 monitor.sanren.ac.za sshd[13027]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:18:54 monitor.sanren.ac.za sshd[13024]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:19:02 monitor.sanren.ac.za sshd[13059]: Accepted password for nagios from 161.202.10.201 port 62390 ssh2
Aug 04 08:19:02 monitor.sanren.ac.za sshd[13059]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:19:02 monitor.sanren.ac.za systemd-logind[422]: New session 6139 of user nagios.
Aug 04 08:19:02 monitor.sanren.ac.za systemd[1]: Starting Session 6139 of user nagios.
Aug 04 08:19:02 monitor.sanren.ac.za systemd[1]: Started Session 6139 of user nagios.
Aug 04 08:19:29 monitor.sanren.ac.za sshd[13066]: Accepted password for nagios from 159.8.99.206 port 62011 ssh2
Aug 04 08:19:29 monitor.sanren.ac.za sshd[13066]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:19:29 monitor.sanren.ac.za systemd-logind[422]: New session 6140 of user nagios.
Aug 04 08:19:29 monitor.sanren.ac.za systemd[1]: Starting Session 6140 of user nagios.
Aug 04 08:19:29 monitor.sanren.ac.za systemd[1]: Started Session 6140 of user nagios.
Aug 04 08:19:50 monitor.sanren.ac.za sshd[13054]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:20:00 monitor.sanren.ac.za sshd[13074]: Accepted password for nagios from 173.193.97.4 port 62083 ssh2
Aug 04 08:20:00 monitor.sanren.ac.za sshd[13074]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:20:00 monitor.sanren.ac.za systemd-logind[422]: New session 6141 of user nagios.
Aug 04 08:20:00 monitor.sanren.ac.za systemd[1]: Starting Session 6141 of user nagios.
Aug 04 08:20:00 monitor.sanren.ac.za systemd[1]: Started Session 6141 of user nagios.
Aug 04 08:20:25 monitor.sanren.ac.za sshd[13059]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:21:02 monitor.sanren.ac.za sshd[13074]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:22:01 monitor.sanren.ac.za sshd[13066]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:22:13 monitor.sanren.ac.za sshd[13125]: Accepted password for nagios from 159.8.101.78 port 63418 ssh2
Aug 04 08:22:13 monitor.sanren.ac.za sshd[13125]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:22:13 monitor.sanren.ac.za systemd-logind[422]: New session 6143 of user nagios.
Aug 04 08:22:13 monitor.sanren.ac.za systemd[1]: Starting Session 6143 of user nagios.
Aug 04 08:22:13 monitor.sanren.ac.za systemd[1]: Started Session 6143 of user nagios.
Aug 04 08:23:15 monitor.sanren.ac.za sshd[13140]: Accepted password for nagios from 159.8.99.201 port 62636 ssh2
Aug 04 08:23:15 monitor.sanren.ac.za sshd[13140]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:23:15 monitor.sanren.ac.za systemd[1]: Starting Session 6144 of user nagios.
Aug 04 08:23:15 monitor.sanren.ac.za systemd-logind[422]: New session 6144 of user nagios.
Aug 04 08:23:15 monitor.sanren.ac.za systemd[1]: Started Session 6144 of user nagios.
Aug 04 08:23:44 monitor.sanren.ac.za sshd[13125]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:23:58 monitor.sanren.ac.za sshd[13153]: Accepted password for nagios from 159.8.91.134 port 63621 ssh2
Aug 04 08:23:58 monitor.sanren.ac.za sshd[13153]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:23:58 monitor.sanren.ac.za systemd-logind[422]: New session 6145 of user nagios.
Aug 04 08:23:58 monitor.sanren.ac.za systemd[1]: Starting Session 6145 of user nagios.
Aug 04 08:23:58 monitor.sanren.ac.za systemd[1]: Started Session 6145 of user nagios.
Aug 04 08:24:53 monitor.sanren.ac.za sshd[13140]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:25:55 monitor.sanren.ac.za sshd[13153]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:26:25 monitor.sanren.ac.za sshd[13186]: Accepted password for nagios from 159.8.99.206 port 62411 ssh2
Aug 04 08:26:25 monitor.sanren.ac.za sshd[13186]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:26:25 monitor.sanren.ac.za systemd-logind[422]: New session 6146 of user nagios.
Aug 04 08:26:25 monitor.sanren.ac.za systemd[1]: Starting Session 6146 of user nagios.
Aug 04 08:26:25 monitor.sanren.ac.za systemd[1]: Started Session 6146 of user nagios.
Aug 04 08:26:58 monitor.sanren.ac.za sshd[13206]: Accepted password for nagios from 159.8.99.200 port 63310 ssh2
Aug 04 08:26:58 monitor.sanren.ac.za sshd[13206]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:26:58 monitor.sanren.ac.za systemd-logind[422]: New session 6147 of user nagios.
Aug 04 08:26:58 monitor.sanren.ac.za systemd[1]: Starting Session 6147 of user nagios.
Aug 04 08:26:58 monitor.sanren.ac.za systemd[1]: Started Session 6147 of user nagios.
Aug 04 08:27:15 monitor.sanren.ac.za sshd[13215]: Accepted password for nagios from 159.8.91.135 port 63359 ssh2
Aug 04 08:27:15 monitor.sanren.ac.za sshd[13215]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:27:15 monitor.sanren.ac.za systemd-logind[422]: New session 6148 of user nagios.
Aug 04 08:27:15 monitor.sanren.ac.za systemd[1]: Starting Session 6148 of user nagios.
Aug 04 08:27:15 monitor.sanren.ac.za systemd[1]: Started Session 6148 of user nagios.
Aug 04 08:28:05 monitor.sanren.ac.za sshd[13206]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:28:34 monitor.sanren.ac.za sshd[13186]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:28:53 monitor.sanren.ac.za sshd[13241]: Accepted password for nagios from 173.193.97.5 port 63374 ssh2
Aug 04 08:28:53 monitor.sanren.ac.za sshd[13241]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:28:53 monitor.sanren.ac.za systemd-logind[422]: New session 6149 of user nagios.
Aug 04 08:28:53 monitor.sanren.ac.za systemd[1]: Starting Session 6149 of user nagios.
Aug 04 08:28:53 monitor.sanren.ac.za systemd[1]: Started Session 6149 of user nagios.
Aug 04 08:29:01 monitor.sanren.ac.za sshd[13215]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:29:14 monitor.sanren.ac.za sshd[13245]: Accepted password for nagios from 173.193.97.4 port 62778 ssh2
Aug 04 08:29:14 monitor.sanren.ac.za sshd[13245]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:29:14 monitor.sanren.ac.za systemd-logind[422]: New session 6150 of user nagios.
Aug 04 08:29:14 monitor.sanren.ac.za systemd[1]: Starting Session 6150 of user nagios.
Aug 04 08:29:14 monitor.sanren.ac.za systemd[1]: Started Session 6150 of user nagios.
Aug 04 08:29:23 monitor.sanren.ac.za sshd[13252]: Accepted password for nagios from 161.202.10.199 port 64344 ssh2
Aug 04 08:29:23 monitor.sanren.ac.za sshd[13252]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:29:23 monitor.sanren.ac.za systemd-logind[422]: New session 6151 of user nagios.
Aug 04 08:29:23 monitor.sanren.ac.za systemd[1]: Starting Session 6151 of user nagios.
Aug 04 08:29:23 monitor.sanren.ac.za systemd[1]: Started Session 6151 of user nagios.
Aug 04 08:30:06 monitor.sanren.ac.za sshd[13266]: Accepted password for nagios from 159.8.74.132 port 61821 ssh2
Aug 04 08:30:06 monitor.sanren.ac.za sshd[13266]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:30:06 monitor.sanren.ac.za systemd[1]: Starting Session 6153 of user nagios.
Aug 04 08:30:06 monitor.sanren.ac.za systemd-logind[422]: New session 6153 of user nagios.
Aug 04 08:30:06 monitor.sanren.ac.za systemd[1]: Started Session 6153 of user nagios.
Aug 04 08:30:25 monitor.sanren.ac.za sshd[13245]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:30:46 monitor.sanren.ac.za sshd[13241]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:30:49 monitor.sanren.ac.za sshd[13252]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:31:00 monitor.sanren.ac.za sshd[13266]: pam_unix(sshd:session): session closed for user nagios
Aug 04 08:31:03 monitor.sanren.ac.za sshd[13275]: Accepted password for nagios from 119.81.166.93 port 62393 ssh2
Aug 04 08:31:03 monitor.sanren.ac.za sshd[13275]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:31:03 monitor.sanren.ac.za systemd-logind[422]: New session 6154 of user nagios.
Aug 04 08:31:03 monitor.sanren.ac.za systemd[1]: Starting Session 6154 of user nagios.
Aug 04 08:31:03 monitor.sanren.ac.za systemd[1]: Started Session 6154 of user nagios.
Aug 04 08:31:18 monitor.sanren.ac.za sshd[13287]: Accepted password for nagios from 159.8.99.204 port 63710 ssh2
Aug 04 08:31:18 monitor.sanren.ac.za sshd[13287]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:31:18 monitor.sanren.ac.za systemd[1]: Starting Session 6155 of user nagios.
Aug 04 08:31:18 monitor.sanren.ac.za systemd-logind[422]: New session 6155 of user nagios.
Aug 04 08:31:18 monitor.sanren.ac.za systemd[1]: Started Session 6155 of user nagios.
Aug 04 08:32:16 monitor.sanren.ac.za sshd[13317]: Accepted password for nagios from 159.8.91.135 port 63293 ssh2
Aug 04 08:32:16 monitor.sanren.ac.za sshd[13317]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 08:32:16 monitor.sanren.ac.za systemd-logind[422]: New session 6156 of user nagios.
Aug 04 08:32:16 monitor.sanren.ac.za systemd[1]: Starting Session 6156 of user nagios.
Aug 04 08:32:16 monitor.sanren.ac.za systemd[1]: Started Session 6156 of user nagios.
Aug 04 08:32:18 monitor.sanren.ac.za sshd[13275]: pam_unix(sshd:session): session closed for user nagios
Reason: Please use [code][/code] tags around long output
jdalrymple
- Skynet Drone
Your journal wrapped from the last time you tried to start Nagios, there is no useful data there.
Please try to restart nagios, then immediately thereafter run the journalctl command I specified.
Aug 04 16:58:46 monitor.sanren.ac.za systemd[1]: Started Session 6746 of user nagios.
Aug 04 16:58:48 monitor.sanren.ac.za sshd[25768]: pam_unix(sshd:session): session closed for user nagios
Aug 04 17:00:14 monitor.sanren.ac.za sshd[25808]: pam_unix(sshd:session): session closed for user nagios
Aug 04 17:01:29 monitor.sanren.ac.za sshd[25883]: Accepted password for nagios from 119.81.230.3 port 61472 ssh2
Aug 04 17:01:29 monitor.sanren.ac.za sshd[25883]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 17:01:29 monitor.sanren.ac.za systemd-logind[422]: New session 6748 of user nagios.
Aug 04 17:01:29 monitor.sanren.ac.za systemd[1]: Starting Session 6748 of user nagios.
Aug 04 17:01:29 monitor.sanren.ac.za systemd[1]: Started Session 6748 of user nagios.
Aug 04 17:02:44 monitor.sanren.ac.za sshd[25927]: Accepted password for nagios from 130.211.163.87 port 59535 ssh2
Aug 04 17:02:44 monitor.sanren.ac.za sshd[25927]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 17:02:44 monitor.sanren.ac.za systemd-logind[422]: New session 6749 of user nagios.
Aug 04 17:02:44 monitor.sanren.ac.za systemd[1]: Starting Session 6749 of user nagios.
Aug 04 17:02:44 monitor.sanren.ac.za systemd[1]: Started Session 6749 of user nagios.
Aug 04 17:03:24 monitor.sanren.ac.za sshd[25947]: Accepted password for nagios from 119.81.166.92 port 64244 ssh2
Aug 04 17:03:24 monitor.sanren.ac.za sshd[25947]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 17:03:24 monitor.sanren.ac.za systemd-logind[422]: New session 6750 of user nagios.
Aug 04 17:03:24 monitor.sanren.ac.za systemd[1]: Starting Session 6750 of user nagios.
Aug 04 17:03:24 monitor.sanren.ac.za systemd[1]: Started Session 6750 of user nagios.
Aug 04 17:03:32 monitor.sanren.ac.za sshd[25883]: pam_unix(sshd:session): session closed for user nagios
Aug 04 17:04:02 monitor.sanren.ac.za sshd[25927]: pam_unix(sshd:session): session closed for user nagios
Aug 04 17:04:37 monitor.sanren.ac.za sshd[25947]: pam_unix(sshd:session): session closed for user nagios
Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 04 17:04:38 monitor.sanren.ac.za nagios[25998]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 04 17:04:46 monitor.sanren.ac.za sshd[26011]: Accepted password for nagios from 159.8.91.136 port 63065 ssh2
Aug 04 17:04:46 monitor.sanren.ac.za sshd[26011]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 17:04:46 monitor.sanren.ac.za systemd-logind[422]: New session 6752 of user nagios.
Aug 04 17:04:46 monitor.sanren.ac.za systemd[1]: Starting Session 6752 of user nagios.
Aug 04 17:04:46 monitor.sanren.ac.za systemd[1]: Started Session 6752 of user nagios.
Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 04 17:04:47 monitor.sanren.ac.za nagios[26019]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 04 17:04:47 monitor.sanren.ac.za nagios[26027]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 04 17:05:29 monitor.sanren.ac.za nagios[26051]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 04 17:06:03 monitor.sanren.ac.za sshd[26011]: pam_unix(sshd:session): session closed for user nagios
Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 04 17:06:14 monitor.sanren.ac.za nagios[26091]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 04 17:06:17 monitor.sanren.ac.za sshd[26112]: Accepted password for nagios from 159.8.99.200 port 62620 ssh2
Aug 04 17:06:17 monitor.sanren.ac.za sshd[26112]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 04 17:06:17 monitor.sanren.ac.za systemd[1]: Starting Session 6753 of user nagios.
Aug 04 17:06:17 monitor.sanren.ac.za systemd-logind[422]: New session 6753 of user nagios.
Aug 04 17:06:17 monitor.sanren.ac.za systemd[1]: Started Session 6753 of user nagios.
jdalrymple
- Skynet Drone
Re: Nagios.service fails to start
It seems something has changed between here:
and here:shadebe wrote:monitor:/usr/local/nagios/etc# journalctl -xn
-- Logs begin at Thu 2015-07-30 10:48:19 SAST, end at Thu 2015-07-30 15:13:30 SAST. --
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: ***> One or more problems was encountered while processing the config files...
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: Check your configuration file(s) to ensure that they contain valid
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: directives and data defintions. If you are upgrading from a previous
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: version of Nagios, you should be aware that some variables/definitions
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: may have been removed or modified in this version. Make sure to read
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: the HTML documentation regarding the config files, as well as the
Jul 30 15:13:30 monitor.sanren.ac.za nagios[32281]: 'Whats New' section to find out what has changed.
Jul 30 15:13:30 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=8
Jul 30 15:13:30 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
-- Subject: Unit nagios.service has failed
How is it that you're trying to start the daemon?shadebe wrote:Code: Select all
Aug 04 16:58:46 monitor.sanren.ac.za systemd[1]: Started Session 6746 of user nagios. Aug 04 16:58:48 monitor.sanren.ac.za sshd[25768]: pam_unix(sshd:session): session closed for user nagios Aug 04 17:00:14 monitor.sanren.ac.za sshd[25808]: pam_unix(sshd:session): session closed for user nagios Aug 04 17:01:29 monitor.sanren.ac.za sshd[25883]: Accepted password for nagios from 119.81.230.3 port 61472 ssh2 Aug 04 17:01:29 monitor.sanren.ac.za sshd[25883]: pam_unix(sshd:session): session opened for user nagios by (uid=0) Aug 04 17:01:29 monitor.sanren.ac.za systemd-logind[422]: New session 6748 of user nagios. Aug 04 17:01:29 monitor.sanren.ac.za systemd[1]: Starting Session 6748 of user nagios. Aug 04 17:01:29 monitor.sanren.ac.za systemd[1]: Started Session 6748 of user nagios. Aug 04 17:02:44 monitor.sanren.ac.za sshd[25927]: Accepted password for nagios from 130.211.163.87 port 59535 ssh2 Aug 04 17:02:44 monitor.sanren.ac.za sshd[25927]: pam_unix(sshd:session): session opened for user nagios by (uid=0) Aug 04 17:02:44 monitor.sanren.ac.za systemd-logind[422]: New session 6749 of user nagios. Aug 04 17:02:44 monitor.sanren.ac.za systemd[1]: Starting Session 6749 of user nagios. Aug 04 17:02:44 monitor.sanren.ac.za systemd[1]: Started Session 6749 of user nagios. Aug 04 17:03:24 monitor.sanren.ac.za sshd[25947]: Accepted password for nagios from 119.81.166.92 port 64244 ssh2 Aug 04 17:03:24 monitor.sanren.ac.za sshd[25947]: pam_unix(sshd:session): session opened for user nagios by (uid=0) Aug 04 17:03:24 monitor.sanren.ac.za systemd-logind[422]: New session 6750 of user nagios. Aug 04 17:03:24 monitor.sanren.ac.za systemd[1]: Starting Session 6750 of user nagios. Aug 04 17:03:24 monitor.sanren.ac.za systemd[1]: Started Session 6750 of user nagios. Aug 04 17:03:32 monitor.sanren.ac.za sshd[25883]: pam_unix(sshd:session): session closed for user nagios Aug 04 17:04:02 monitor.sanren.ac.za sshd[25927]: pam_unix(sshd:session): session closed for user nagios Aug 04 17:04:37 monitor.sanren.ac.za sshd[25947]: pam_unix(sshd:session): session closed for user nagios Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server... Aug 04 17:04:38 monitor.sanren.ac.za nagios[25998]: Executable file /opt/nagios/bin/nagios not found. Exiting. Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1 Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server. Aug 04 17:04:38 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state. Aug 04 17:04:46 monitor.sanren.ac.za sshd[26011]: Accepted password for nagios from 159.8.91.136 port 63065 ssh2 Aug 04 17:04:46 monitor.sanren.ac.za sshd[26011]: pam_unix(sshd:session): session opened for user nagios by (uid=0) Aug 04 17:04:46 monitor.sanren.ac.za systemd-logind[422]: New session 6752 of user nagios. Aug 04 17:04:46 monitor.sanren.ac.za systemd[1]: Starting Session 6752 of user nagios. Aug 04 17:04:46 monitor.sanren.ac.za systemd[1]: Started Session 6752 of user nagios. Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server... Aug 04 17:04:47 monitor.sanren.ac.za nagios[26019]: Executable file /opt/nagios/bin/nagios not found. Exiting. Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1 Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server. Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state. Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server... Aug 04 17:04:47 monitor.sanren.ac.za nagios[26027]: Executable file /opt/nagios/bin/nagios not found. Exiting. Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1 Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server. Aug 04 17:04:47 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state. Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server... Aug 04 17:05:29 monitor.sanren.ac.za nagios[26051]: Executable file /opt/nagios/bin/nagios not found. Exiting. Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1 Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server. Aug 04 17:05:29 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state. Aug 04 17:06:03 monitor.sanren.ac.za sshd[26011]: pam_unix(sshd:session): session closed for user nagios Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server... Aug 04 17:06:14 monitor.sanren.ac.za nagios[26091]: Executable file /opt/nagios/bin/nagios not found. Exiting. Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1 Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server. Aug 04 17:06:14 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state. Aug 04 17:06:17 monitor.sanren.ac.za sshd[26112]: Accepted password for nagios from 159.8.99.200 port 62620 ssh2 Aug 04 17:06:17 monitor.sanren.ac.za sshd[26112]: pam_unix(sshd:session): session opened for user nagios by (uid=0) Aug 04 17:06:17 monitor.sanren.ac.za systemd[1]: Starting Session 6753 of user nagios. Aug 04 17:06:17 monitor.sanren.ac.za systemd-logind[422]: New session 6753 of user nagios. Aug 04 17:06:17 monitor.sanren.ac.za systemd[1]: Started Session 6753 of user nagios.
I don't get what you are asking, please rephrase.
Below is the output when I try to restart the service:
monitor:~# /etc/init.d/nagios restart
[....] Restarting nagios (via systemctl): nagios.serviceJob for nagios.service failed. See 'systemctl status nagios.service' and 'journalctl -xn' for details.
failed!
Then I ran the suggested command journalctl -xn to see the details:
monitor:~# journalctl -xn
-- Logs begin at Wed 2015-08-05 04:06:48 SAST, end at Wed 2015-08-05 08:46:56 SAST. --
Aug 05 08:46:21 monitor.sanren.ac.za sshd[4058]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:46:21 monitor.sanren.ac.za systemd[1]: Starting Session 7827 of user nagios.
-- Subject: Unit session-7827.scope has begun with start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/li ... temd-devel
-- Unit session-7827.scope has begun starting up.
Aug 05 08:46:21 monitor.sanren.ac.za systemd-logind[422]: New session 7827 of user nagios.
-- Subject: A new session 7827 has been created for user nagios
-- Documentation: http://www.freedesktop.org/wiki/Softwar ... /multiseat
-- A new session with the ID 7827 has been created for the user nagios.
-- The leading process of the session is 4058.
Aug 05 08:46:21 monitor.sanren.ac.za systemd[1]: Started Session 7827 of user nagios.
-- Subject: Unit session-7827.scope has finished start-up
-- Unit session-7827.scope has finished starting up.
-- The start-up result is done.
Aug 05 08:46:27 monitor.sanren.ac.za sshd[4029]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:46:27 monitor.sanren.ac.za systemd-logind[422]: Removed session 7824.
-- Subject: A session 7824 has been terminated
-- A session with the ID 7824 has been terminated.
Aug 05 08:46:43 monitor.sanren.ac.za sshd[4019]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:46:43 monitor.sanren.ac.za systemd-logind[422]: Removed session 7823.
-- Subject: A session 7823 has been terminated
-- A session with the ID 7823 has been terminated.
Aug 05 08:46:56 monitor.sanren.ac.za sshd[4040]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:46:56 monitor.sanren.ac.za systemd-logind[422]: Removed session 7826.
-- Subject: A session 7826 has been terminated
-- A session with the ID 7826 has been terminated.
Then I executed the command as per your request:
Aug 05 08:39:00 monitor.sanren.ac.za sshd[3779]: Accepted password for nagios from 184.173.26.165 port 63173 ssh2
Aug 05 08:39:00 monitor.sanren.ac.za sshd[3779]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:39:00 monitor.sanren.ac.za systemd[1]: Starting Session 7818 of user nagios.
Aug 05 08:39:00 monitor.sanren.ac.za systemd-logind[422]: New session 7818 of user nagios.
Aug 05 08:39:00 monitor.sanren.ac.za systemd[1]: Started Session 7818 of user nagios.
Aug 05 08:39:15 monitor.sanren.ac.za systemd-sysv-generator[3825]: Overwriting existing symlink /run/systemd/generator.late/nagios.service with real service
Aug 05 08:39:17 monitor.sanren.ac.za sshd[3765]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:39:33 monitor.sanren.ac.za sshd[3772]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:39:56 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 05 08:39:56 monitor.sanren.ac.za nagios[3852]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 05 08:39:56 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 05 08:39:56 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 05 08:39:56 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 05 08:40:01 monitor.sanren.ac.za sshd[3873]: Accepted password for nagios from 159.8.101.75 port 63582 ssh2
Aug 05 08:40:01 monitor.sanren.ac.za sshd[3873]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:40:01 monitor.sanren.ac.za systemd[1]: Starting Session 7820 of user nagios.
Aug 05 08:40:01 monitor.sanren.ac.za systemd-logind[422]: New session 7820 of user nagios.
Aug 05 08:40:01 monitor.sanren.ac.za systemd[1]: Started Session 7820 of user nagios.
Aug 05 08:40:17 monitor.sanren.ac.za sshd[3779]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:41:28 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 05 08:41:28 monitor.sanren.ac.za nagios[3918]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 05 08:41:28 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 05 08:41:28 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 05 08:41:28 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 05 08:41:49 monitor.sanren.ac.za sshd[3873]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:44:31 monitor.sanren.ac.za systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
Aug 05 08:44:31 monitor.sanren.ac.za nagios[3992]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 05 08:44:31 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 05 08:44:31 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 05 08:44:31 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
Aug 05 08:45:01 monitor.sanren.ac.za sshd[4019]: Accepted password for nagios from 159.8.101.78 port 64895 ssh2
Aug 05 08:45:01 monitor.sanren.ac.za sshd[4019]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:45:01 monitor.sanren.ac.za systemd-logind[422]: New session 7823 of user nagios.
Aug 05 08:45:01 monitor.sanren.ac.za systemd[1]: Starting Session 7823 of user nagios.
Aug 05 08:45:01 monitor.sanren.ac.za systemd[1]: Started Session 7823 of user nagios.
Aug 05 08:45:09 monitor.sanren.ac.za sshd[4029]: Accepted password for nagios from 161.202.10.199 port 64028 ssh2
Aug 05 08:45:09 monitor.sanren.ac.za sshd[4029]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:45:09 monitor.sanren.ac.za systemd-logind[422]: New session 7824 of user nagios.
Aug 05 08:45:09 monitor.sanren.ac.za systemd[1]: Starting Session 7824 of user nagios.
Aug 05 08:45:09 monitor.sanren.ac.za systemd[1]: Started Session 7824 of user nagios.
Aug 05 08:45:13 monitor.sanren.ac.za sshd[4031]: Accepted password for nagios from 119.81.251.6 port 64024 ssh2
Aug 05 08:45:13 monitor.sanren.ac.za sshd[4031]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:45:13 monitor.sanren.ac.za systemd[1]: Starting Session 7825 of user nagios.
Aug 05 08:45:13 monitor.sanren.ac.za systemd-logind[422]: New session 7825 of user nagios.
Aug 05 08:45:13 monitor.sanren.ac.za systemd[1]: Started Session 7825 of user nagios.
Aug 05 08:45:47 monitor.sanren.ac.za sshd[4040]: Accepted password for nagios from 159.8.91.135 port 63802 ssh2
Aug 05 08:45:47 monitor.sanren.ac.za sshd[4040]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:45:47 monitor.sanren.ac.za systemd-logind[422]: New session 7826 of user nagios.
Aug 05 08:45:47 monitor.sanren.ac.za systemd[1]: Starting Session 7826 of user nagios.
Aug 05 08:45:47 monitor.sanren.ac.za systemd[1]: Started Session 7826 of user nagios.
Aug 05 08:46:20 monitor.sanren.ac.za sshd[4031]: pam_unix(sshd:session): session closed for user nagios
Aug 05 08:46:21 monitor.sanren.ac.za sshd[4058]: Accepted password for nagios from 159.8.99.200 port 62489 ssh2
Aug 05 08:47:10 monitor.sanren.ac.za sshd[4083]: Accepted password for nagios from 159.8.91.142 port 62268 ssh2
Aug 05 08:47:10 monitor.sanren.ac.za sshd[4083]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:47:10 monitor.sanren.ac.za systemd[1]: Starting Session 7828 of user nagios.
Aug 05 08:47:10 monitor.sanren.ac.za systemd-logind[422]: New session 7828 of user nagios.
Aug 05 08:47:10 monitor.sanren.ac.za systemd[1]: Started Session 7828 of user nagios.
Aug 05 08:47:38 monitor.sanren.ac.za sshd[4135]: Accepted password for nagios from 161.202.104.188 port 62739 ssh2
Aug 05 08:47:38 monitor.sanren.ac.za sshd[4135]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:47:38 monitor.sanren.ac.za systemd[1]: Starting Session 7829 of user nagios.
Aug 05 08:47:38 monitor.sanren.ac.za systemd-logind[422]: New session 7829 of user nagios.
Aug 05 08:47:38 monitor.sanren.ac.za systemd[1]: Started Session 7829 of user nagios.
Aug 05 08:47:46 monitor.sanren.ac.za sshd[4141]: Accepted password for nagios from 161.202.10.203 port 64825 ssh2
Aug 05 08:47:46 monitor.sanren.ac.za sshd[4141]: pam_unix(sshd:session): session opened for user nagios by (uid=0)
Aug 05 08:47:46 monitor.sanren.ac.za systemd-logind[422]: New session 7830 of user nagios.
Aug 05 08:47:46 monitor.sanren.ac.za systemd[1]: Starting Session 7830 of user nagios.
Aug 05 08:47:46 monitor.sanren.ac.za systemd[1]: Started Session 7830 of user nagios.
Aug 05 08:47:54 monitor.sanren.ac.za sshd[4058]: pam_unix(sshd:session): session closed for user nagios
I normally use service nagios restart to start, stop or restart the nagios service.
monitor:~# service nagios restart
monitor:~# systemctl status nagios.service
● nagios.service - LSB: Starts and stops the Nagios monitoring server
Loaded: loaded (/etc/init.d/nagios)
Active: failed (Result: exit-code) since Wed 2015-08-05 08:49:50 SAST; 33s ago
Process: 4239 ExecStart=/etc/init.d/nagios start (code=exited, status=1/FAILURE)
Aug 05 08:49:50 monitor.sanren.ac.za nagios[4239]: Executable file /opt/nagios/bin/nagios not found. Exiting.
Aug 05 08:49:50 monitor.sanren.ac.za systemd[1]: nagios.service: control process exited, code=exited status=1
Aug 05 08:49:50 monitor.sanren.ac.za systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
Aug 05 08:49:50 monitor.sanren.ac.za systemd[1]: Unit nagios.service entered failed state.
It is first time I am getting this but after upgrading to 4.0.8. Really I am not sure what to fix this.
failed!
It seems working now..
I executed this command below and it fixed everything:
/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Thank you for your willingness to help
