During backup_maintenace I get the following error on elasticsearch log:
[2015-08-03 14:36:12,573][DEBUG][action.admin.indices.settings.put] [845bc07c-ed91-4920-8e23-747c9cc699f5] failed to update settings on indices [logstash-2015.07.10]
org.elasticsearch.ElasticsearchIllegalArgumentException: Can't update non dynamic settings[[index.codec.bloom.load]] for open indices [[logstash-2015.07.10]]
at org.elasticsearch.cluster.metadata.MetaDataUpdateSettingsService$2.execute(MetaDataUpdateSettingsService.java:243)
at org.elasticsearch.cluster.service.InternalClusterService$UpdateTask.run(InternalClusterService.java:374)
at org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.runAndClean(PrioritizedEsThreadPoolExecutor.java:188)
at org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.run(PrioritizedEsThreadPoolExecutor.java:158)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Any ideas? Thanx a lot.
Re: Exception: Can't update non dynamic settings
It's possible that the index 2015.07.10 is unhealthy - let's check on the index health by using the following command:
The index may need to be deleted and restored.
curl 'localhost:9200/_cluster/health?level=indices&pretty'Re: Exception: Can't update non dynamic settings
I attach you the "prettty" output.
It looks fine. I had the same issue with 2015.07.09 and the I closed it and then the error message pointed to 2015.07.10.
Today since it closed the 19th it complains about 11!
2015-08-04 09:15:37,699 INFO Attempting to disable bloom filter for index logstash-2015.07.10.
2015-08-04 09:15:37,742 INFO Skipping index logstash-2015.07.10: Already closed.
2015-08-04 09:15:37,742 INFO Attempting to disable bloom filter for index logstash-2015.07.11.
Traceback (most recent call last):
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 736, in <module>
main()
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 731, in main
arguments.func(client, **argdict)
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 585, in command_loop
skipped = op(client, index_name, **kwargs)
File "/usr/lib/python2.6/site-packages/curator/curator.py", line 455, in _bloom_index
client.indices.put_settings(index=index_name, body='index.codec.bloom.load=false')
File "/usr/lib/python2.6/site-packages/elasticsearch/client/utils.py", line 68, in _wrapped
return func(*args, params=params, **kwargs)
File "/usr/lib/python2.6/site-packages/elasticsearch/client/indices.py", line 596, in put_settings
params=params, body=body)
File "/usr/lib/python2.6/site-packages/elasticsearch/transport.py", line 307, in perform_request
status, headers, data = connection.perform_request(method, url, params, body, ignore=ignore, timeout=timeout)
File "/usr/lib/python2.6/site-packages/elasticsearch/connection/http_urllib3.py", line 86, in perform_request
self._raise_error(response.status, raw_data)
File "/usr/lib/python2.6/site-packages/elasticsearch/connection/base.py", line 102, in _raise_error
raise HTTP_EXCEPTIONS.get(status_code, TransportError)(status_code, error_message, additional_info)
elasticsearch.exceptions.RequestError: TransportError(400, u"RemoteTransportException[[7387f4a4-c097-4c4a-9f83-22ae496b3eac][inet[/10.1.11.10:9300]][indices:admin/settings/update]]; nested: ElasticsearchIllegalArgumentException[Can't update non dynamic settings[[index.codec.bloom.load]] for open indices [[logstash-2015.07.11]]]; ")
SUCCESS
main()
SUCCESS
Let's check on the md5sum of your curator package - I'd like to verify that your version of curator was updated properly.
What is your Disable Bloom Filter Cache older than setting? You can find this setting at 'Administration -> Backup & Maintenance'. Try setting it to '0' as a test and see if you have better luck running your backups.
md5sum /usr/lib/python2.6/site-packages/curator/curator.pyRe: Exception: Can't update non dynamic settings
Correct there is a curator version mismatch.
NagiosLogServer1 (fresh setup with the latest version 2015R2.1 from ova file)
[root@NagiosLogServer1 ~]# md5sum /usr/lib/python2.6/site-packages/curator/curator.py
ba8b1fb0d80fd9fbe3de26d162317444 /usr/lib/python2.6/site-packages/curator/curator.py
NagiosLogServer2 (master node - upgraded with source tar file all the way... to the latest 2015R2.1)
[root@NagiosLogServer2 ~]# md5sum /usr/lib/python2.6/site-packages/curator/curator.py
2098632ed35e30491a0a95fc1895d382 /usr/lib/python2.6/site-packages/curator/curator.py
NagiosLogServer3 (fresh setup with the latest version 2015R2.1 from ova file)
[root@NagiosLogServer3 ~]# md5sum /usr/lib/python2.6/site-packages/curator/curator.py
And yes by disabling the Bloom Filter Cache there are no exceptions (as seen on the attached txt).
This definitely appears to be a bug - it could very likely be caused by the following change made in more recent versions of elasticsearch:
https://github.com/elastic/elasticsearch/pull/6959
I have opened up a bug report with our development team - the task ID is 6191.
Regarding the version of curator that you have installed - 2098632ed35e30491a0a95fc1895d382 is the correct md5sum. Feel free to copy this file to your other instances with an incorrect sum and replace the old curator.py file.
Thanx.
Pls close the thread.
teirekos,
In Elasticsearch versions 1.4 and higher, the bloom filter is disabled by default due to the change I mentioned above. In our next release of NLS we will be disabling the bloom filter setting and removing 'BLOOM FILTER' from the backup/maintenance process. Thanks for the bug report!
