Some SNMP Traps arriving as IPADDRESS, not HOSTNAME
rkymtnhigh
Post by rkymtnhigh »
This whole SNMP trap thing has been quite a journey, and I'm almost there.
Some of my traps show up as HOSTNAME, and some show up as IPADDRESS. Is that a setting on the device somewhere?
These are Cisco switches and F5 load balancers.
I've looked through the configurations on these devices and can't immediately tell where I need to specify this.
Have any of you run into this?
Any help is greatly appreciated,
RMH
ssax
Dreams In Code
Re: Some SNMP Traps arriving as IPADDRESS, not HOSTNAME
Post by ssax »
It's usually a setting on the device, I'm unsure of where it would be set on those specific devices (maybe someone else can chime in), I do know that you can configure snmptt to try to resolve hostnames by edit your /etc/snmp/snmptt.ini file and set dns_enable = 1 and if you want to strip the domain set strip_domain = 1.
ssax
Dreams In Code
Post by ssax »
You could always reach out to Cisco and F5 to see how you do it. Make sure to post the solutions here! :)
