Nagios XI Getting error while installing on linux 6.7 (Santi
nagios999
Post by nagios999 »
RESULT=0
Running './3-dbservers'...
PostgresQL installed OK - continuing...
Initializing PostgresQL...
Starting PostgresQL...
Starting postgresql service: [FAILED]
ERROR: Could not start PostgresQL - exiting.
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
install.log error
Complete!
Fixing php-mcrypt bug...
Prerequisites installed OK
Adding users and groups...
Users and groups added OK
Starting postgresql service: ^[[60G[^[[0;31mFAILED^[[0;39m]^M
"install.log" 1468L, 84142C 1468,1 Bot
Re: Nagios XI Getting error while installing on linux 6.7 (S
Could you try and start the postgres database by running the following and see if there are any errors in /var/log/messages or the postgres logs which by default are in this folder /var/lib/pgsql/data/pg_log and post those here?
service postgresql start
