Is there any docs on how to configure different type of traps into different services in XI?
The idea is to setup a service assigned to a hostgroup. All traps will go to the particular host and relevant TRAP service instead of all dumped into a single SNMP TRAP service.
Thanks.
SNMP Traps
SNMP Traps
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
- Box293
- Too Basu
Re: SNMP Traps
We don't have a full document that explains this yet but there are some forum posts that cover it.
The key to it is in the EXEC line.
Have a look at this post I made just recently:
https://support.nagios.com/forum/viewto ... 25#p147925
If the same OID has different data coming in, you can also use a MATCH statement. This means you can have multiple EVENTS for the SAME OID, but based on the match statement it can do different things.
Does this help?
Does this help?
Re: SNMP Traps
Thanks, will check it out now. Nagios official doc just does not go into details.Box293 wrote:We don't have a full document that explains this yet but there are some forum posts that cover it.
Does this help?
I just want to monitor the following traps for all the F5 devices and ignore the rest for the time being.
Any help will be greatly appreciated.
TRAP NAME
bigipServiceDown (.1.3.6.1.4.1.3375.2.4.0.10)
bigipServiceUp (.1.3.6.1.4.1.3375.2.4.0.11)
bigipNodeDown (.1.3.6.1.4.1.3375.2.4.0.12)
bigipNodeUp (.1.3.6.1.4.1.3375.2.4.0.13)
bigipStandby (.1.3.6.1.4.1.3375.2.4.0.14)
bigipStandByFail (.1.3.6.1.4.1.3375.2.4.0.75)
bigipActive (.1.3.6.1.4.1.3375.2.4.0.15)
bigipActiveActive (.1.3.6.1.4.1.3375.2.4.0.16)
bigipFeatureFailed (.1.3.6.1.4.1.3375.2.4.0.17)
bigipFeatureOnline (.1.3.6.1.4.1.3375.2.4.0.18)
bigipPacketRejected (.1.3.6.1.4.1.3375.2.4.0.34)
bigipInetPortExhaustion (.1.3.6.1.4.1.3375.2.4.0.76)
RHEL 6 & 7
RHEL 6 & 7
Re: SNMP Traps
A simple example with be a great help to figure all this out.
RHEL 6 & 7
RHEL 6 & 7
- Box293
- Too Basu
Re: SNMP Traps
Can you post your /etc/snmp/snmptt.conf file, or at least the sections that contain the traps you just highlighted.
Re: SNMP Traps
I am working on it. Need to get hold of network guys to simulate some event.Box293 wrote:Can you post your /etc/snmp/snmptt.conf file, or at least the sections that contain the traps you just highlighted.
Let me test is out first before I engage you with issues.
Here is some extract. Every single one is pointing to the same service.
EVENT bigipGtmLeftGroup .1.3.6.1.4.1.3375.2.4.0.74 "Status Events" Normal
FORMAT BIG-IP GTM left sync group. $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "BIG-IP GTM left sync group. $*"
SDESC
Variables:
1: bigipNotifyObjMsg
EDESC
EVENT bigipStandByFail .1.3.6.1.4.1.3375.2.4.0.75 "Status Events" Normal
FORMAT In failover condition, this standby will not be able to go active. $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "In failover condition, this standby will not be able to go active. $*"
SDESC
Variables:
EDESC
EVENT bigipInetPortExhaustion .1.3.6.1.4.1.3375.2.4.0.76 "Status Events" Normal
FORMAT The TMM has run out of source ports and cannot open new communications channels with other machines. $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The TMM has run out of source ports and cannot open new communications channels with other machines. $*"
SDESC
Variables:
EDESC
RHEL 6 & 7
RHEL 6 & 7
- Box293
- Too Basu
Re: SNMP Traps
Excellent, this was what I am after.
Take this one for example:
I've left off SDESC to EDESC as this is informative only.
In the EXEC line, change "SNMP Traps" to "Port Exhaustion"
Restart the snmptt service.
Now, create a Passive Service in Nagios XI called "Port Exhaustion" and Apply Config. You can just use CCM to duplicate an existing "SNMP Traps" service and change the name to "Port Exhaustion".
This is how this trap will be targeted to this specific service (actually, any host that has a service with this name).
Note: When a trap is received and no service exists, it will appear under Admin > Monitoring Config > Unconfigured Objects. From here you can turn it into a service.
Does that make sense?
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The TMM has run out of source ports and cannot open new communications channels with other machines. $*"In the EXEC line, change "SNMP Traps" to "Port Exhaustion"
Re: SNMP Traps
Yes.Box293 wrote:Excellent, this was what I am after.
I've left off SDESC to EDESC as this is informative only.Code: Select all
EVENT bigipInetPortExhaustion .1.3.6.1.4.1.3375.2.4.0.76 "Status Events" Normal FORMAT The TMM has run out of source ports and cannot open new communications channels with other machines. $* EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The TMM has run out of source ports and cannot open new communications channels with other machines. $*"
So to summarise
1) I just remove the EVENT for the OIDs I am not interested to process. It will end up in the snmpttunknown.log
2) The trap will get processed by the the correct host. I am assuming it will use IP address to match.
Thanks for your help. It does make sense now.
RHEL 6 & 7
RHEL 6 & 7
- Box293
- Too Basu
Re: SNMP Traps
Great.
http://snmptt.sourceforge.net/docs/snmptt.shtml#DNS
Yes, the whole EVENT includes the EVENT, FORMAT, EXEC and SDESC/EDESC lines.rajasegar wrote:1) I just remove the EVENT for the OIDs I am not interested to process. It will end up in the snmpttunknown.log
Yes, it sends the address using the $r value to Nagios. This can be resolved to a DNS name as well, have a look at the SNMPTT documentation for more info on this.rajasegar wrote:2) The trap will get processed by the the correct host. I am assuming it will use IP address to match.
