migrating nagios to new server causing CHECK_NRPE: Error
sinkak
Post by sinkak »
i migrated nagios from old server to new one.
i copied same config files from old one to new server. just changed paths alone on config files.
UI is working. getting regular updates.
but for some hosts they have CHECK_NRPE: Error - Could not complete SSL handshake.
i checked on old server
/usr/lib/nagios/plugins/check_nrpe -H client1ip
NRPE v2.12
on new server
there are so many clients which have same error.
i suppose old admin might not have edited each clients allowed hosts parameter in nrpe.cfg file.
there must be some other way.
do i have to edit each client nrpe.cfg file?
Please help.
jdalrymple
Skynet Drone
Re: migrating nagios to new server causing CHECK_NRPE: Error
Post by jdalrymple »
sinkak wrote:i suppose old admin might not have edited each clients allowed hosts parameter in nrpe.cfg file.
This might be a good opportunity to roll out some devops?
an every 5 minute cron job that wgets a nrpe.cfg is a great thing.
So - "yes" is the answer to your question, unless assuming the old IP is a possibility. Also note before you go deep into the woods that it may not be nrpe.cfg, it could be inetd.conf.
sinkak
Post by sinkak »
old server has nrpe.cfg files in
ubuntu@monitoring:/etc/nagios3$ sudo find / -name nrpe.cfg
/home/WSA/alexander.lavrenko/devops/storage/etc/nagios/nrpe.cfg
/home/WSA/alexander.lavrenko/devops_/storage/etc/nagios/nrpe.cfg
/home/WSA/alexander.lavrenko/devops__/storage/etc/nagios/nrpe.cfg
/home/WSA/alexey.tkachev/devops_old/storage/etc/nagios/nrpe.cfg
/home/WSA/alexey.tkachev/devops/storage/etc/nagios/nrpe.cfg
/home/WSA/andrey.sviridov/devops/storage/etc/nagios/nrpe.cfg
/home/WSA/dmitriy.dranenko/devops/storage/etc/nagios/nrpe.cfg
/home/ubuntu/nagios/nrpe.cfg
/root/devops/storage/etc/nagios/nrpe.cfg
new server has in
ubuntu@newnagios:~$ sudo find / -name nrpe.cfg
how do we find out where clients are getting nrpe.cfg file from old server?
jdalrymple
Skynet Drone
[jdalrymple@localhost etc]$ ps -ef | grep nrpe
500       50521  40945  0 03:55 pts/0    00:00:00 grep nrpe
If like in my info you get no useful output, try this instead:
[jdalrymple@localhost etc]$ grep nrpe /etc/xinetd.d/nrpe
service nrpe
        server          = /usr/local/nagios/bin/nrpe
        server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
sinkak
Post by sinkak »
ubuntu@ip:~$ grep nrpe /etc/xinetd.d/nrpe
service nrpe
/usr/local/nagios/etc/nrpe.cfg <----- is this the path where client getting nrpe.cfg file ?
Yes, that is where the daemon gets the configuration settings for the NRPE daemon.
If you are running NRPE under xinetd, then you would have to edit this file below to add the IP address of the new server using the only_from option.
/etc/xinetd.d/nrpe
They are a space delimited list of IP address that can connect to the NRPE daemon.
Any chance you can shut down the old server, change the IP address of the new system to the old to fix this?
sinkak
Post by sinkak »
i cant reassign old server ip to new.
but i made all the changes in xinet.d and i am waiting on clients to read it.
That's too bad, let us know if you need any more help.
sinkak
Post by sinkak »
Even after making changes to inetd.
service nrpe
still has same error.
i tried adding new server ip to one of the clients nrpe.cfg file. That removed the error.i have more than 100 hosts. i cant edit on each client.
Is there any thing i can do like that on server side so that it changes all clients config file?
sinkak
Post by sinkak »
i added no ssl option to check_nrpe on server side
        command_name   check_nrpe
        command_line       /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -t 40 -c $ARG1$ -n
this removed SSL error
