why backup status is partial?
pccwglobalit
Post by pccwglobalit »
Why some backup is partial? can i run manually again to do the backup?
jolson
Attack Rabbit
Re: why backup status is partial?
Post by jolson »
If the backup comes out partial, it typically means one of two things:
1. Your network storage system had a minor disconnection causing the backup to fracture.
2. Your backup was interrupted by a system process on the NLS end of things.
In either case, I recommend simply deleting the partial backup and re-running the backup & maintenance command to recover a working backup.
Twits Blog
