CCM Log Management
angus
CCM Log Management
Post by angus »
I had some unapplied changes to all the services on a host. I did not make the changes and my coworker claims he did not either. I tried to find the events in the log and the ccm log. The normal log was pretty cluttered and i didn't see anything that stood out. The CCM log only had the event of my logging in. Is there a setting i can change to have the CCM keep logs for longer? Is there a place in the logs i can find info about who made a service change?
Thanks.
jolson
Attack Rabbit
Re: CCM Log Management
Post by jolson »
I'm assuming you're viewing the Admin -> System Information -> Audit Log? If you increase the period from 'Last 24h' to 'Last Month' or similar, do you see the logs that you're looking for?
If not, the information may have rotated. We are working on a new setting for Nagios XI that will be included in our next release. This setting will allow you to export the audit log to a file on your disk, at which point you could send it to a log monitoring program (Nagios Log Server) or similar - that may be the solution you're after.
Twits Blog
angus
Post by angus »
This is what i am looking for. I was looking at the wrong log sections. Thank you.
hsmith
Agent Smith
Post by hsmith »
angus wrote:This is what i am looking for. I was looking at the wrong log sections. Thank you.
Is there anything else we can help you with, or are we all right to close this one?
Former Nagios Employee.
me.
angus
Post by angus »
Close please
