does there exist an option to suppress the log-entries "SERVICE ALERT:" in the Nagios-core-Logfile?
No one of the logging-options in the nagios.cfg - file seems to be handle this, to avoid this output. We have thousand of services and that's why we would like to suppress this log-entries, because we handle this service-states already and we would like to reduce the redundant I/O-traffic.
Regards
How to suppress "SERVICE ALERT:"-entries in nagios.log-file
Re: How to suppress "SERVICE ALERT:"-entries in nagios.log-f
Do you want the logging of the alerts all together to stop, or just the logging saying that a notification was sent out?Schmatte wrote:Hello,
Regards
Former Nagios Employee.
me.
me.
I would like to stop this alerts all together. Option log_notifications=0 has been set already, but this doesn't suppress this log-entries.
Did you restart the nagios process after the change was made?
Run this to see if the logging stops.
If not, could you post your nagios.cfg file so we can review it?
service nagios restartChanging log_notifications to 0 will just suppress Notifications.Format: log_notifications=<0/1>
Example: log_notifications=1
This variable determines whether or not notification messages are logged. If you have a lot of contacts or regular service failures your log file will grow relatively quickly. Use this option to keep contact notifications from being logged.
0 = Don't log notifications
1 = Log notifications
I set all possible "log_*"-options to 0. I also restarted nagios every time (checked PID in nagios.lock) .
At this time I think the logging-problem depends on the "is_volatile=1" - option of the configured services.
see https://assets.nagios.com/downloads/nag ... vices.html
Here is a hint:
"[..] Volatile services differ from "normal" services in three important ways. Each time they are checked when they are in a hard non-OK state, and the check returns a non-OK state (i.e. no state change has occurred)...
•The non-OK service state is logged [..]"
So I would substantiate the question: How could I suppress this logging of non-OK service states of a volatile-service ?
Here is a hint:
That's not currently possible in Core, as logging is one of the three things that take place for a volatile service (the other two being event handlers and notifications). You would need to do this at a syslog/rsyslog level:
http://www.rsyslog.com/discarding-unwanted-messages/
