I need some guidance on the right configuration to get Nagios working correctly as thus far i seem to doing an injustice to what appears to be a very powerfull application.
Many thanks
Okay, i have managed to connect to the remote NSClient and retrieve uptime data using the basic check_nt command of sudo /usr/local/nagios/libexec/check_nt -H 172.91.91.11 -s 'passwordhere' -p 12489 -v UPTIME but from within Nagios itself where i look under the Service Detail everything shows in red with the warning message of 'Name or service not known' and the following:
CPU Load
CRITICAL 2010-04-29 12:28:09 2d 19h 51m 8s 4/4 Name or service not known
Explorer
CRITICAL 2010-04-29 12:25:25 2d 19h 53m 17s 4/4 Name or service not known
Memory Usage
CRITICAL 2010-04-29 12:25:40 2d 19h 50m 47s 4/4 Name or service not known
NSClient++ Version
CRITICAL 2010-04-29 12:25:56 2d 19h 52m 56s 4/4 Name or service not known
Uptime
CRITICAL 2010-04-29 12:26:12 2d 19h 50m 26s 4/4 Name or service not known
W3SVC
CRITICAL 2010-04-29 12:26:28 2d 19h 52m 34s 4/4 Name or service not known
Also, specifically where i click on the NSClient++ service i get a page stating as follows:
It appears as though you do not have permission to view information for this service...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file
UPDATE,
okay i fixed it, it turned out to be that i had specified an ip address instead of using a $HOSTADDRESS$ arguement inside one of the .cfg files, phew finally nagios3 is pulling data from the nsclient program on remote hosts. Onto new ideas now, i am now trying to retrieve RAID array data from HP array cards using NRPE, so far no luck but i will stick at it
