Upgrade from 3.x to 4.0.8 - maps/trends not working
helloworld304423
Hi there,
we've upgrade our Nagios installation to version 4.0.8. Everything is working like a charm, with the exception of Maps and Trends.
The OS is a Ubuntu 12.04.5 LTS.
For both I get the error: "Error: Could not read object configuration data!".
- The configuration has been verified with -v and no errors came up.
- There is also nothing noted in the nagios.log file.
- The user www-data is in the groups nagios,nagcmd and www-data.
So what else could be wrong?
Thanks for help!
Thanks for help!
Re: Upgrade from 3.x to 4.0.8 - maps/trends not working
Was this a source install or an apt-get install?
What are the permissions on your .../nagios/var directory?
helloworld304423
It was an installation from source.
Permissions are blow. As www-data is in the nagios group, that should be fine, or not?
$ ls -lah /usr/local/nagios/var
drwxrwxr-x 5 nagios nagios 4,0K Aug 18 08:51 .
drwxr-xr-x 9 nagios nagios 4,0K Feb 4 2015 ..
drwxrwxr-x 2 nagios nagios 96K Aug 17 23:59 archives
-rw-r--r-- 1 nagios nagios 5 Aug 17 10:04 nagios.lock
-rw-rw-r-- 1 nagios nagios 117K Aug 18 08:04 nagios.log
-rw-r--r-- 1 nagios nagios 162K Aug 29 2014 nagios.log.old
-rw-r--r-- 1 nagios nagios 704K Aug 17 10:04 objects.cache
-rw-r--r-- 1 nagios nagios 613K Aug 29 2014 objects.cache.old
-rw-rw-r-- 1 nagios nagios 665K Mär 27 15:52 objects.cache.old2
-rw------- 1 nagios nagios 1,1M Aug 18 08:04 retention.dat
-rw-rw-r-- 1 nagios nagios 926K Aug 29 2014 retention.dat.old
-rw------- 1 nagios nagios 1,0M Mär 30 11:52 retention.dat.old2
drwxrwsr-x 2 nagios nagcmd 4,0K Aug 17 10:04 rw
drwxr-xr-x 3 root root 4,0K Mär 5 2010 spool
-rw-rw-r-- 1 nagios nagios 1,1M Aug 18 08:51 status.dat
Could you confirm that Apache is running as www-data and if it isn't, add that account to the nagios group and see if that fixes it for you.
Also, could you check the Apache error_log file for any errors that can help us debug this?
helloworld304423
In the file /var/log/apache2/error.log no errors are listed.
The Access.log says this:
Ip.ad.dr.es - nagiosadmin [19/Aug/2015:03:00:45] "GET /nagios/cgi-bin/statusmap.cgi?host=all HTTP/1.1" 200 1701 "http:// Ip.ad.dr.es /nagios/side.php" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 10.0; WOW64; Trident/8.0; .NET4.0C; .NET4.0E; .NET CLR 2.0.50727; .NET CLR 3.0.30729; .NET CLR 3.5.30729)"
Can you run the following and post the results?
grep nag /etc/passwd
grep nag /etc/group
ps auxBe sure to check out our Knowledgebase for helpful articles and solutions!
helloworld304423
Sure, here you are:
$grep nag /etc/passwd
list:x:38:38:Mailing List Manager:/var/list:/bin/sh
nagios:x:1001:1001::/home/nagios:/bin/bash
$grep nag /etc/group
nagios:x:1001:www-data,tomcat6
nagcmd:x:1002:nagios,www-data,tomcat6
$ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.2 24332 1988 ? Ss Aug17 0:00 /sbin/init
root 2 0.0 0.0 0 0 ? S Aug17 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S Aug17 0:17 [ksoftirqd/0]
root 6 0.0 0.0 0 0 ? S Aug17 0:00 [migration/0]
root 7 0.0 0.0 0 0 ? S Aug17 0:00 [watchdog/0]
root 8 0.0 0.0 0 0 ? S< Aug17 0:00 [cpuset]
root 9 0.0 0.0 0 0 ? S< Aug17 0:00 [khelper]
root 10 0.0 0.0 0 0 ? S Aug17 0:00 [kdevtmpfs]
root 11 0.0 0.0 0 0 ? S< Aug17 0:00 [netns]
root 12 0.0 0.0 0 0 ? S Aug17 0:00 [sync_supers]
root 13 0.0 0.0 0 0 ? S Aug17 0:00 [bdi-default]
root 14 0.0 0.0 0 0 ? S< Aug17 0:00 [kintegrityd]
root 15 0.0 0.0 0 0 ? S< Aug17 0:00 [kblockd]
root 16 0.0 0.0 0 0 ? S< Aug17 0:00 [ata_sff]
root 17 0.0 0.0 0 0 ? S Aug17 0:00 [khubd]
root 18 0.0 0.0 0 0 ? S< Aug17 0:00 [md]
root 19 0.0 0.0 0 0 ? S Aug17 0:00 [kworker/u:1]
root 21 0.0 0.0 0 0 ? S Aug17 0:00 [khungtaskd]
root 22 0.0 0.0 0 0 ? S Aug17 0:00 [kswapd0]
root 23 0.0 0.0 0 0 ? SN Aug17 0:00 [ksmd]
root 24 0.0 0.0 0 0 ? SN Aug17 0:00 [khugepaged]
root 25 0.0 0.0 0 0 ? S Aug17 0:00 [fsnotify_mark]
root 26 0.0 0.0 0 0 ? S Aug17 0:00 [ecryptfs-kthrea]
root 27 0.0 0.0 0 0 ? S< Aug17 0:00 [crypto]
root 35 0.0 0.0 0 0 ? S< Aug17 0:00 [kthrotld]
root 37 0.0 0.0 0 0 ? S Aug17 0:00 [scsi_eh_0]
root 38 0.0 0.0 0 0 ? S Aug17 0:00 [scsi_eh_1]
root 39 0.0 0.0 0 0 ? S Aug17 0:02 [kworker/u:2]
root 60 0.0 0.0 0 0 ? S< Aug17 0:00 [devfreq_wq]
root 206 0.0 0.0 0 0 ? S< Aug17 0:00 [ttm_swap]
root 253 0.0 0.0 0 0 ? S< Aug17 0:00 [mpt_poll_0]
root 256 0.0 0.0 0 0 ? S< Aug17 0:00 [mpt/0]
root 261 0.0 0.0 0 0 ? S Aug17 0:00 [scsi_eh_2]
root 321 0.0 0.0 0 0 ? S Aug17 0:06 [jbd2/sda1-8]
root 322 0.0 0.0 0 0 ? S< Aug17 0:00 [ext4-dio-unwrit]
root 557 0.0 0.0 17228 352 ? S Aug17 0:00 upstart-udev-bridge --daemon
root 581 0.0 0.1 22044 972 ? Ss Aug17 0:00 /sbin/udevd --daemon
syslog 590 0.0 0.1 249464 1192 ? Sl Aug17 0:05 rsyslogd -c5
106 591 0.0 0.1 23940 1004 ? Ss Aug17 0:00 dbus-daemon --system --fork --activation=upstart
root 779 0.0 0.0 21768 236 ? S Aug17 0:00 /sbin/udevd --daemon
root 780 0.0 0.0 21768 336 ? S Aug17 0:00 /sbin/udevd --daemon
root 866 0.0 0.0 0 0 ? S< Aug17 0:00 [kpsmoused]
root 905 0.0 0.0 15184 360 ? S Aug17 0:00 upstart-socket-bridge --daemon
root 1013 0.0 0.3 50032 2352 ? Ss Aug17 0:00 /usr/sbin/sshd -D
root 1119 0.0 0.0 0 0 ? S Aug17 0:02 [flush-8:0]
root 1121 0.0 0.4 586428 3088 ? Sl Aug17 0:00 /usr/sbin/console-kit-daemon --no-daemon
root 1188 0.0 0.2 186588 2128 ? Sl Aug17 0:00 /usr/lib/policykit-1/polkitd --no-debug
nagios 1208 0.1 0.5 29372 4080 ? Ss Aug17 6:56 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root 1236 0.0 0.1 17288 888 tty4 Ss+ Aug17 0:00 /sbin/getty -8 38400 tty4
root 1244 0.0 0.1 17288 884 tty5 Ss+ Aug17 0:00 /sbin/getty -8 38400 tty5
root 1258 0.0 0.1 17288 888 tty2 Ss+ Aug17 0:00 /sbin/getty -8 38400 tty2
root 1259 0.0 0.1 17288 892 tty3 Ss+ Aug17 0:00 /sbin/getty -8 38400 tty3
root 1261 0.0 0.1 17288 888 tty6 Ss+ Aug17 0:00 /sbin/getty -8 38400 tty6
root 1264 0.0 0.1 14964 912 ? Ss Aug17 0:00 /usr/sbin/xinetd -dontfork -pidfile /var/run/xinetd.pid -stayalive -inetd_compat -inetd_ipv6
root 1265 0.0 0.0 4324 644 ? Ss Aug17 0:00 acpid -c /etc/acpi/events -s /var/run/acpid.socket
root 1266 0.0 0.1 19108 992 ? Ss Aug17 0:00 cron
daemon 1267 0.0 0.0 16904 368 ? Ss Aug17 0:00 atd
nagios 1312 0.0 0.1 27568 1080 ? S Aug17 0:07 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
whoopsie 1360 0.0 0.4 200108 3800 ? Ssl Aug17 0:00 whoopsie
tomcat6 1369 0.0 7.2 1031816 54896 ? Sl Aug17 1:39 /usr/lib/jvm/default-java/bin/java -Djava.util.logging.config.file=/var/lib/tomcat6/conf/logging.propertie
root 1727 0.0 1.3 136224 10232 ? Ss Aug17 0:05 /usr/sbin/apache2 -k start
root 1839 0.0 0.1 25104 1236 ? Ss Aug17 0:00 /usr/lib/postfix/master
postfix 1856 0.0 0.1 27332 1396 ? S Aug17 0:00 qmgr -l -t fifo -u
snmp 1905 0.0 0.5 48620 3836 ? S Aug17 0:17 /usr/sbin/snmpd -Lsd -Lf /dev/null -u snmp -g snmp -I -smux -p /var/run/snmpd.pid
root 1920 0.0 0.1 17288 888 tty1 Ss+ Aug17 0:00 /sbin/getty -8 38400 tty1
www-data 7639 0.0 0.9 136668 7304 ? S 08:22 0:00 /usr/sbin/apache2 -k start
postfix 9753 0.0 0.2 27168 1608 ? S 08:30 0:00 pickup -l -t fifo -u -c
www-data 13613 0.0 0.9 136668 7308 ? S 08:44 0:00 /usr/sbin/apache2 -k start
www-data 14445 0.0 0.9 136668 7300 ? S 08:47 0:00 /usr/sbin/apache2 -k start
nagios 15992 0.0 0.1 10904 1228 ? S Aug19 0:12 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 15993 0.0 0.1 10800 1248 ? S Aug19 0:12 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 15994 0.0 0.1 10772 1216 ? S Aug19 0:12 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 15995 0.0 0.1 10832 1268 ? S Aug19 0:12 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
www-data 16397 0.0 0.9 136668 7292 ? S 08:55 0:00 /usr/sbin/apache2 -k start
www-data 18050 0.0 0.9 136668 7292 ? S 09:01 0:00 /usr/sbin/apache2 -k start
www-data 18469 0.0 0.9 136316 6964 ? S 09:02 0:00 /usr/sbin/apache2 -k start
root 18711 0.0 0.0 0 0 ? S 09:03 0:00 [kworker/0:0]
www-data 18858 0.0 0.9 136316 6868 ? S 09:04 0:00 /usr/sbin/apache2 -k start
www-data 19673 0.0 0.9 136316 6868 ? S 09:07 0:00 /usr/sbin/apache2 -k start
root 20021 0.0 0.5 104084 4276 ? Ss 09:08 0:00 sshd: itservice [priv]
root 20053 0.0 0.0 0 0 ? S 09:08 0:00 [kworker/0:2]
www-data 20088 0.0 0.9 136316 6868 ? S 09:08 0:00 /usr/sbin/apache2 -k start
1002 20245 0.0 0.2 104084 1904 ? S 09:08 0:00 sshd: itservice@pts/0
1002 20246 0.2 1.0 28160 7792 pts/0 Ss 09:08 0:00 -bash
www-data 20695 0.0 0.7 136256 5884 ? S 09:10 0:00 /usr/sbin/apache2 -k start
nagios 20797 0.0 0.1 12872 932 ? S 09:10 0:00 /usr/local/nagios/libexec/check_ping -H 10.215.51.1 -w 3000.0,80% -c 5000.0,100% -p 5
nagios 20798 0.0 0.0 4392 612 ? S 09:10 0:00 /bin/ping -n -U -w 30 -c 5 10.215.51.1
nagios 20801 0.0 0.1 12872 932 ? S 09:10 0:00 /usr/local/nagios/libexec/check_ping -H 10.215.127.1 -w 3000.0,80% -c 5000.0,100% -p 5
nagios 20802 0.0 0.0 4392 612 ? S 09:10 0:00 /bin/ping -n -U -w 30 -c 5 10.215.127.1
nagios 20803 0.0 0.1 12872 932 ? S 09:10 0:00 /usr/local/nagios/libexec/check_ping -H 192.168.194.71 -w 3000.0,80% -c 5000.0,100%
nagios 20804 0.0 0.0 4392 612 ? S 09:10 0:00 /bin/ping -n -U -w 30 -c 5 192.168.194.71
nagios 20805 0.0 0.1 12872 928 ? S 09:10 0:00 /usr/local/nagios/libexec/check_ping -H 10.215.35.1 -w 3000.0,80% -c 5000.0,100% -p 5
nagios 20806 0.0 0.0 4392 616 ? S 09:10 0:00 /bin/ping -n -U -w 30 -c 5 10.215.35.1
nagios 20809 0.0 0.1 12872 924 ? S 09:10 0:00 /usr/local/nagios/libexec/check_ping -H 10.215.62.1 -w 3000.0,80% -c 5000.0,100% -p 5
nagios 20810 0.0 0.0 4392 616 ? S 09:10 0:00 /bin/ping -n -U -w 30 -c 5 10.215.62.1
nagios 20813 0.0 1.7 50632 13056 ? S 09:10 0:00 /usr/bin/perl /usr/local/nagios/libexec/check_rbl --extra-opts=rbl@/usr/local/nagios/libexec/check_rbl.ini
nagios 20815 0.0 0.1 12872 928 ? S 09:10 0:00 /usr/local/nagios/libexec/check_ping -H 10.215.118.5 -w 3000.0,80% -c 5000.0,100% -p 5
nagios 20816 0.0 0.0 4392 616 ? S 09:10 0:00 /bin/ping -n -U -w 30 -c 5 10.215.118.5
nagios 20817 0.0 0.0 12872 708 ? S 09:10 0:00 /usr/local/nagios/libexec/check_nt -H 10.215.2.52 -p 12489 -v MEMUSE -w 90 -c 95
1002 20818 0.0 0.1 19660 1256 pts/0 R+ 09:10 0:00 ps aux
root 27390 0.0 0.0 0 0 ? S Aug19 0:04 [kworker/0:1]
So far, so good
Can you run the following and post back the output?
Can you attach the nagios.cfg file to this post?
ls -l /usr/local/nagios/share
ls -l /usr/local/nagios/sbinBe sure to check out our Knowledgebase for helpful articles and solutions!
helloworld304423
Sorry for the delay, I had a day off on Friday.
Attached the permissions and the nagios.cfg.
Thanks for your help!
$ls -l /usr/local/nagios/share
-rw-rw-r-- 1 nagios nagios 576 Aug 12 12:56 config.inc.php
drwxrwxr-x 2 nagios nagios 4096 Aug 12 12:56 contexthelp
drwxrwxr-x 3 nagios nagios 4096 Nov 9 2010 docs
drwxrwxr-x 3 nagios nagios 4096 Aug 12 12:56 images
drwxrwxr-x 3 nagios nagios 4096 Aug 12 12:56 includes
-rw-rw-r-- 1 nagios nagios 1628 Aug 12 12:56 index.php
drwxrwxr-x 2 nagios nagios 4096 Aug 12 12:56 js
-rw-rw-r-- 1 nagios nagios 1176 Aug 12 12:56 jsonquery.html
drwxr-xr-x 4 root root 4096 Mär 5 2010 locale
-rw-rw-r-- 1 nagios nagios 8697 Aug 12 12:56 main.php
drwxrwxr-x 2 nagios nagios 4096 Mär 5 2010 media
-rw-rw-r-- 1 nagios nagios 26 Aug 12 12:56 robots.txt
-rw-rw-r-- 1 nagios nagios 656 Aug 12 12:56 rss-corebanner.php
-rw-rw-r-- 1 nagios nagios 1064 Aug 12 12:56 rss-corefeed.html
-rw-rw-r-- 1 nagios nagios 895 Aug 12 12:56 rss-corefeed.php
-rw-rw-r-- 1 nagios nagios 540 Aug 12 12:56 rss-newsfeed.html
-rw-rw-r-- 1 nagios nagios 1064 Aug 12 12:56 rss-newsfeed.php
-rw-rw-r-- 1 nagios nagios 6009 Aug 12 12:56 side.php
drwxrwxr-x 2 nagios nagios 4096 Mär 5 2010 ssi
drwxrwxr-x 2 nagios nagios 4096 Aug 12 12:56 stylesheets
$ ls -l /usr/local/nagios/sbin
-rwxrwxr-x 1 nagios nagios 312376 Aug 12 12:56 archivejson.cgi
-rwxrwxr-x 1 nagios nagios 293656 Aug 12 12:56 avail.cgi
-rwxrwxr-x 1 nagios nagios 292064 Aug 12 12:56 cmd.cgi
-rwxrwxr-x 1 nagios nagios 264904 Aug 12 12:56 config.cgi
-rwxrwxr-x 1 nagios nagios 305912 Aug 12 12:56 extinfo.cgi
-rwxrwxr-x 1 nagios nagios 217912 Nov 9 2010 histogram.cgi
-rwxrwxr-x 1 nagios nagios 240384 Aug 12 12:56 history.cgi
-rwxrwxr-x 1 nagios nagios 236264 Aug 12 12:56 notifications.cgi
-rwxrwxr-x 1 nagios nagios 314136 Aug 12 12:56 objectjson.cgi
-rwxrwxr-x 1 nagios nagios 232128 Aug 12 12:56 outages.cgi
-rwxrwxr-x 1 nagios nagios 232144 Aug 12 12:56 showlog.cgi
-rwxrwxr-x 1 nagios nagios 305936 Aug 12 12:56 status.cgi
-rwxrwxr-x 1 nagios nagios 312280 Aug 12 12:56 statusjson.cgi
-rwxrwxr-x 1 nagios nagios 213880 Nov 9 2010 statusmap.cgi
-rwxrwxr-x 1 nagios nagios 252688 Aug 12 12:56 statuswml.cgi
-rwxrwxr-x 1 nagios nagios 236272 Aug 12 12:56 statuswrl.cgi
-rwxrwxr-x 1 nagios nagios 256800 Aug 12 12:56 summary.cgi
-rwxrwxr-x 1 nagios nagios 248600 Aug 12 12:56 tac.cgi
-rwxrwxr-x 1 nagios nagios 222008 Nov 9 2010 trends.cgi
nagios.cfg- nagios.cfg
- (43.23 KiB) Downloaded 378 times
When you compiled Nagios 4.0.8, it looks like it did not update these 3 cgi files which is causing the problem.
In the folder where you compiled the software, can you check the log file for any errors when it was compiled and post them here?
-rwxrwxr-x 1 nagios nagios 222008 Nov 9 2010 trends.cgiBe sure to check out our Knowledgebase for helpful articles and solutions!
