Need detailed port monitoring for target server
sushant4tech
Post by sushant4tech »
Hi All,
I am monitoring a remote server (Windows Server 2008) with basic nrpe commands. I need to add services to this server. On this remote server i receive data from my 3rd parties. They send the data to specific ports on this server. E.g. party a sends their data on 5555, party b sends it on 6666 and so on. There are about 30 parties that send data to the port assigned to them. I need to configure services for all these 3rd parties (each assigned to a specific port on this remote server) if any of these ports stops receiving data, i want to get notification.
I can further break it down which is if i receive no data for 15mins for any configured port then i should get warning notification and if it exceeds 45 mins then i need critical notification. can anyone tell me how should i configure these services.
- $u$h@nT
hsmith
Agent Smith
Re: Need detailed port monitoring for target server
Post by hsmith »
sushant4tech wrote:Hi All,
Have you looked into this plugin? It looks like it could do exactly what you are looking for.
Former Nagios Employee.
me.
sushant4tech
Ok. That sounds about right partially. I do want to know if the port is open or not and for that this plugin is perfect, but i need to dig a little deeper.
I actually need two tasks done here.
1. Need to know if the port is open and listening, which is covered in the plugin you suggested.
2. Assuming the port is open and listening, are we receiving any data. If not then i want to get warning notification if this state lasts for 15 mins and critical notification for lets say 30 mins even though the port is open and listening. This is something i am primarily looking for in the plugin.
- $u$h@nT
I haven't heard of a plugin that can check to see if there is traffic on a specified port, but you could look for something like that on the exchange site.
http://exchange.nagios.com
jdalrymple
Skynet Drone
Post by jdalrymple »
To expand on what tgriep said - I don't even know how to gather those particular metrics from Windows without pcap, is it even possible? I think you're going to be going down the netflow road and looking at your switches, not the Windows box... or at least I think that's going to be the easiest road.
