Hi Nagios Support,
Good day.
We have upgraded our BW to 80Mbps.
I tried to add them in Nagios using the Switch/Router wizard but it seems that Nagios is still seeing the old values of Tunnel 0 and Tunnel 1 to 40Mbps.
It is now 80Mbps as shown in our other network monitoring tool.
Tunnel 0
Tunnel 1
Kindly advise why and how to fix this.
Thanks.
Interface Max Spedd Incorrect Value
- Box293
- Too Basu
Re: Interface Max Spedd Incorrect Value
Have you gone into Core Configuration Manager and changed the service definition, it's going to be in the $ARG4$ field.
Nagios Support,
The issue was already resolved.
The values was automatically adjusted after some time.
You can lock this thread now.
Thank you very much.
