Check Error, SSL Handshake and Return Code 255
gpi
Post by gpi »
I created a new service in order to monitor the free space of unit C: for windows server and attached it to different hosts. Some of them worked like a charm they look ok and send properly the status, but, on the other hand, there're a small amount that are giving error:
- (Return code of 255 is out of bounds) --> This error is returned by server with NSClient++ version 0.4.1.105
- CHECK_NRPE: Error - Could not complete SSL handshake. --> This error is returned by servers with NSClient++ Version: 0.3.9.328
I googled those errors, just for give a try solving them, but all solutions given are not working.
The hosts which are returning those errors have other services configured and working properly.
Here is the service details:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c CheckDriveSize -a MaxWarnUsed=$ARG1$ MaxCritUsed=$ARG2$ Drive=$ARG3$:
All the affected hosts are Windows Server 2008 R2 x64
Here is the contents of one of the NSC.INI (Version 0.3.9.328)
[modules]
NRPEListener.dll
NSClientListener.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
;# NSCLIENT++ MODULES
;# A list with DLLs to load at startup.
;  You will need to enable some of these for NSClient++ to work.
; * N O T I C E ! ! ! - Y O U   H A V E   T O   E D I T   T H I S *
;FileLogger.dll
;CheckSystem.dll
;CheckDisk.dll
;NSClientListener.dll
;NRPEListener.dll
;SysTray.dll
;CheckEventLog.dll
;CheckHelpers.dll
;CheckWMI.dll
;CheckNSCP.dll
; Script to check external scripts and/or internal aliases.
;CheckExternalScripts.dll
; NSCA Agent if you enable this NSClient++ will talk to NSCA hosts repeatedly (so dont enable unless you want to use NSCA)
;NSCAAgent.dll
; LUA script module used to write your own "check deamon".
;LUAScript.dll
; RemoteConfiguration IS AN EXTREM EARLY IDEA SO DONT USE FOR PRODUCTION ENVIROMNEMTS!
;RemoteConfiguration.dll
; Check other hosts through NRPE extreme beta and probably a bit dangerous! :)
;NRPEClient.dll
; Extreamly early beta of a task-schedule checker
;CheckTaskSched.dll
[crash]
; Archive crash dump files if a crash is detected
;archive=1
; Submit crash reports to a crash report server (this overrrides archive)
;submit=0
; Restart service if a crash is detected
;restart=1
[Settings]
;# OBFUSCATED PASSWORD
;  This is the same as the password option but here you can store the password in an obfuscated manner.
;  *NOTICE* obfuscation is *NOT* the same as encryption, someone with access to this file can still figure out the
;  password. Its just a bit harder to do it at first glance.
obfuscated_password=*******
;# PASSWORD
;  This is the password (-s) that is required to access NSClient remotely. If you leave this blank everyone will be able to access the daemon remotly.
;password=secret-password
;# ALLOWED HOST ADDRESSES
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to the all daemons.
;  If leave this blank anyone can access the deamon remotly (NSClient still requires a valid password).
;  The syntax is host or ip/mask so 192.168.0.0/24 will allow anyone on that subnet access
;allowed_hosts=127.0.0.1/32
;# USE THIS FILE
;  Use the INI file as opposed to the registry if this is 0 and the use_reg in the registry is set to 1
;  the registry will be used instead.
use_file=1
allowed_hosts=XXX.XXX.XXX.XXX
; # USE SHARED MEMORY CHANNELS
;  This is the "new" way for using the system tray based on an IPC framework on top shared memmory channels and events.
;  It is brand new and (probably has bugs) so dont enable this unless for testing!
;  If set to 1 shared channels will be created and system tray icons created and such and such...
;shared_session=0
[log]
;# LOG DEBUG
;  Set to 1 if you want debug message printed in the log file (debug messages are always printed to stdout when run with -test)
;debug=1
;# LOG FILE
;  The file to print log statements to
;file=nsclient.log
;# LOG DATE MASK
;  The format to for the date/time part of the log entry written to file.
;date_mask=%Y-%m-%d %H:%M:%S
;# LOG ROOT FOLDER
;  The root folder to use for logging.
;  exe = the folder where the executable is located
;  local-app-data = local application data (probably a better choice then the old default)
;root_folder=exe
[NSClient]
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to NSClient deamon.
;  If you leave this blank the global version will be used instead.
;allowed_hosts=
;# NSCLIENT PORT NUMBER
;  This is the port the NSClientListener.dll will listen to.
;port=12489
;# BIND TO ADDRESS
;  Allows you to bind server to a specific local address. This has to be a dotted ip adress not a hostname.
;  Leaving this blank will bind to all avalible IP adresses.
;bind_to_address=
;# SOCKET TIMEOUT
;  Timeout when reading packets on incoming sockets. If the data has not arrived withint this time we will bail out.
;socket_timeout=30
[NRPE]
;# NRPE PORT NUMBER
;  This is the port the NRPEListener.dll will listen to.
port=5666
;# COMMAND TIMEOUT
;  This specifies the maximum number of seconds that the NRPE daemon will allow plug-ins to finish executing before killing them off.
command_timeout=60
;# COMMAND ARGUMENT PROCESSING
;  This option determines whether or not the NRPE daemon will allow clients to specify arguments to commands that are executed.
allow_arguments=1
;# COMMAND ALLOW NASTY META CHARS
;  This option determines whether or not the NRPE daemon will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow_nasty_meta_chars=1
;# USE SSL SOCKET
;  This option controls if SSL should be used on the socket.
use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
;  This is a comma-delimited list of IP address of hosts that are allowed to talk to NRPE deamon.
;allowed_hosts=
;# SCRIPT DIRECTORY
;  All files in this directory will become check commands.
;  *WARNING* This is undoubtedly dangerous so use with care!
;script_dir=scripts\
;# SOCKET TIMEOUT
;socket_timeout=30
[Check System]
;# CPU BUFFER SIZE
;  Can be anything ranging from 1s (for 1 second) to 10w for 10 weeks. Notice that a larger buffer will waste memory
;  so don't use a larger buffer then you need (ie. the longest check you do +1).
;CPUBufferSize=1h
;# CHECK RESOLUTION
;  The resolution to check values (currently only CPU).
;  The value is entered in 1/10:th of a second and the default is 10 (which means ones every second)
;CheckResolution=10
;# CHECK ALL SERVICES
;  Configure how to check services when a CheckAll is performed.
;  ...=started means services in that class *has* to be running.
;  ...=stopped means services in that class has to be stopped.
;  ...=ignored means services in this class will be ignored.
;check_all_services[SERVICE_BOOT_START]=ignored
;check_all_services[SERVICE_SYSTEM_START]=ignored
;check_all_services[SERVICE_AUTO_START]=started
;check_all_services[SERVICE_DEMAND_START]=ignored
;check_all_services[SERVICE_DISABLED]=stopped
[External Script]
;# COMMAND TIMEOUT
;command_timeout=60
;allow_arguments=0
;allow_nasty_meta_chars=0
;# SCRIPT DIRECTORY
;script_dir=c:\my\script\dir
[Script Wrappings]
vbs=cscript.exe //T:30 //NoLogo scripts\lib\wrapper.vbs %SCRIPT% %ARGS%
ps1=cmd /c echo scripts\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
bat=scripts\%SCRIPT% %ARGS%
[External Scripts]
;check_es_long=scripts\long.bat
;check_es_ok=scripts\ok.bat
;check_es_nok=scripts\nok.bat
;check_vbs_sample=cscript.exe //T:30 //NoLogo scripts\check_vb.vbs
;check_powershell_warn=cmd /c echo scripts\powershell.ps1 | powershell.exe -command -
[External Alias]
alias_cpu=checkCPU warn=80 crit=90 time=5m time=1m time=30s
alias_cpu_ex=checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
alias_mem=checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
alias_up=checkUpTime MinWarn=1d MinWarn=1h
alias_disk=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
alias_disk_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
alias_volumes=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
alias_volumes_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
alias_service=checkServiceState CheckAll
alias_service_ex=checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
alias_process=checkProcState "$ARG1$=started"
alias_process_stopped=checkProcState "$ARG1$=stopped"
alias_process_count=checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
alias_process_hung=checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
alias_event_log=CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
alias_file_size=CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
alias_file_age=checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
alias_sched_all=CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
alias_sched_long=CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_sched_task=CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_updates=check_updates -warning 0 -critical 0
check_ok=CheckOK Everything is fine!
[Wrapped Scripts]
;check_test_vbs=check_test.vbs /arg1:1 /arg2:1 /variable:1
;check_test_ps1=check_test.ps1 arg1 arg2
;check_test_bat=check_test.bat arg1 arg2
;check_battery=check_battery.vbs
;check_printer=check_printer.vbs
;check_updates=check_updates.vbs
; [includes]
;# The order when used is "reversed" thus the last included file will be "first"
;# Included files can include other files (be carefull only do basic recursive checking)
; myotherfile.ini
; real.ini
[NSCA Agent]
;# CHECK INTERVALL (in seconds)
;   How often we should run the checks and submit the results.
;interval=5
;# ENCRYPTION METHOD
;   This option determines the method by which the send_nsca client will encrypt the packets it sends
;   to the nsca daemon. The encryption method you choose will be a balance between security and
;   performance, as strong encryption methods consume more processor resources.
;   You should evaluate your security needs when choosing an encryption method.
; Note: The encryption method you specify here must match the decryption method the nsca daemon uses
;       (as specified in the nsca.cfg file)!!
; Values:
;	0 = None	(Do NOT use this option)
;	1 = Simple XOR  (No security, just obfuscation, but very fast)
;   2 = DES
;   3 = 3DES (Triple DES)
;	4 = CAST-128
;	6 = xTEA
;	8 = BLOWFISH
;	9 = TWOFISH
;	11 = RC2
;	14 = RIJNDAEL-128 (AES)
;	20 = SERPENT
;encryption_method=14
;# ENCRYPTION PASSWORD
;  This is the password/passphrase that should be used to encrypt the sent packets.
;password=
;# BIND TO ADDRESS
;  Leaving this blank will bind to "one" local interface.
; -- not supported as of now --
;bind_to_address=
;# LOCAL HOST NAME
;  The name of this host (if empty "computername" will be used.
;hostname=
;# NAGIOS SERVER ADDRESS
;  The address to the nagios server to submit results to.
;nsca_host=192.168.0.1
;# NAGIOS SERVER PORT
;  The port to the nagios server to submit results to.
;nsca_port=5667
;# CHECK COMMAND LIST
;  The checks to run everytime we submit results back to nagios
;  Any command(alias/key) starting with a host_ is sent as HOST_COMMAND others are sent as SERVICE_COMMANDS
;  where the alias/key is used as service name.
[NSCA Commands]
;my_cpu_check=checkCPU warn=80 crit=90 time=20m time=10s time=4
;my_mem_check=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=page
;my_svc_check=checkServiceState CheckAll exclude=wampmysqld exclude=MpfService
;host_check=check_ok
;# REMOTE NRPE PROXY COMMANDS
;  A list of commands that check other hosts.
;  Used by the NRPECLient module
[NRPE Client Handlers]
check_other=-H 192.168.0.1 -p 5666 -c remote_command -a arguments
;# LUA SCRIPT SECTION
;  A list of all Lua scripts to load.
;[LUA Scripts]
;scripts\test.lua
And here the contents of the INI file for 0.41 version:
# If you want to fill this file with all avalible options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 1
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 1
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 1
; Check NSCP - Checkes the state of the agent
CheckNSCP = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; NRPE server - A simple server that listens for incoming NRPE connection and handles them.
NRPEServer = 1
[/settings/NRPE/server]
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = 1
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = 1
; PORT NUMBER - Port to use for NRPE.
port = 5666
NSClient]
allowed_hosts = XXX.XXX.XXX.XXX
port = 12489
[/settings/log]
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/log_nsclient.log
; LOG LEVEL - Log level to use. Avalible levels are error,warning,info,debug,trace
level = debug
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = XXX.XXX.XXX.XXX
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = checkCPU warn=80 crit=90 time=5m time=1m time=30s
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = checkProcState "$ARG1$=started"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = checkProcState "$ARG1$=stopped"
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = checkServiceState CheckAll
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = checkUpTime MinWarn=1d MinWarn=1h
; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates
alias_updates = check_updates -warning 0 -critical 0
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
; default - Alias for default. To configure this item add a section called: /settings/external scripts/alias/default
default =
I followed found solutions like allowed_host, enabling NRPE SSL and allowing arguments, but nothing changed.
If you need more detailed information just let me know.
Thanks in advance and best regards,
J.
Reason: Please use [code][/code] tags around long output, not [quote][/quote] tags
Re: Check Error, SSL Handshake and Return Code 255
Under this section in the nsclient.ini file
Add the following and restart the Nsclient++ service and see if that helps.
ssl options =
verify mode = none
insecure = true
gpi
Post by gpi »
Hello tgriep,
Thanks for your reply. I performed the changes but it keeps giving the same errors.
On the nsclient++ version 0.39:
[NRPE]
;# NRPE PORT NUMBER
port=5666
;# COMMAND TIMEOUT
command_timeout=60
allow_arguments=1
;# USE SSL SOCKET
use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
;allowed_hosts=
;# SCRIPT DIRECTORY
;# SOCKET TIMEOUT
;socket_timeout=30
ssl options =
verify mode = none
insecure = true
On the nsclient++ version 0.41:
use_ssl = 1
ssl options =
verify mode = none
insecure = true
allow arguments = true
allow nasty characters = true
port = 8899
[/settings/log]
level = trace
Any other Ideas?
J.
Lets stick with the NSClient 0.41 version for now.
In your example, the port specified is incorrect. Change this from
port = 8899
to
port = 5666
And you should remove the line.
use_ssl = 1
Do you have the Nagios servers IP address defined for the
allowed hosts =
in the file?
gpi
Post by gpi »
Hello tgriep,
You were right regarding the port. Looks like version 0.41 default port is 8899, once I changed it to 5666 worked properly. I had to add a -n in the check since it was giving the SSL Handshake error even taking out the use_ssl = 1.
I do have the allowed_hosts=XXX.XXX.XXX.XXX in the [Settings] section. This appends to all sections if not defined in them, right?
Version 0.41 -> Solved
Regarding version 0.39, I have still 3 servers giving the following error:
I launched the command directly on the nagios server to see which was the error prompted, and this was the result, from each server:
[root@nagiosxi libexec]# ./check_nrpe -H XXX.XXX.XXX.XXX -t 30 -c CheckDriveSize -a MaxWarnUsed=85% MaxCritUsed=90% Drive=C:
If I add the -n parameter on the command, keeps loading until the timeout (-t 30) is reached and prompts the following, for each server:
[root@nagiosxi libexec]# ./check_nrpe -H XXX.XXX.XXX.XXX -t 30 -n -c CheckDriveSize -a MaxWarnUsed=85% MaxCritUsed=90% Drive=C:
CHECK_NRPE: Socket timeout after 30 seconds.
Here's the INI file for the nsclient++ version 0.39:
[modules]
NRPEListener.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
;FileLogger.dll
;CheckSystem.dll
;CheckDisk.dll
;NRPEListener.dll
;SysTray.dll
;CheckEventLog.dll
;CheckHelpers.dll
;CheckWMI.dll
;CheckNSCP.dll
;NSCAAgent.dll
;LUAScript.dll
;NRPEClient.dll
;CheckTaskSched.dll
[crash]
;archive=1
;submit=0
;restart=1
[Settings]
;obfuscated_password=***************
;# PASSWORD
;# USE THIS FILE
use_file=1
;shared_session=0
[log]
;# LOG DEBUG
;debug=1
;# LOG FILE
;file=nsclient.log
;# LOG DATE MASK
;# LOG ROOT FOLDER
;root_folder=exe
[NSClient]
;allowed_hosts=
;port=12489
;# BIND TO ADDRESS
;bind_to_address=
;# SOCKET TIMEOUT
;socket_timeout=30
[NRPE]
;# NRPE PORT NUMBER
port=5666
;# COMMAND TIMEOUT
command_timeout=60
allow_arguments=1
;# USE SSL SOCKET
use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
;allowed_hosts=
;# SCRIPT DIRECTORY
;# SOCKET TIMEOUT
;socket_timeout=30
[Check System]
;# CPU BUFFER SIZE
;CPUBufferSize=1h
;# CHECK RESOLUTION
;CheckResolution=10
[External Script]
;# COMMAND TIMEOUT
;command_timeout=60
;allow_arguments=0
;# SCRIPT DIRECTORY
[Script Wrappings]
[External Scripts]
[External Alias]
[Wrapped Scripts]
; [includes]
; myotherfile.ini
; real.ini
[NSCA Agent]
;interval=5
; Values:
;   2 = DES
;	4 = CAST-128
;	6 = xTEA
;	8 = BLOWFISH
;	9 = TWOFISH
;	11 = RC2
;	20 = SERPENT
;password=
;# BIND TO ADDRESS
;bind_to_address=
;# LOCAL HOST NAME
;hostname=
;nsca_port=5667
[NSCA Commands]
;[LUA Scripts]
;scripts\test.lua
I tried commenting the line in the [NRPE] section of use_ssl=1 like this:
;# USE SSL SOCKET
;use_ssl=1
but it was still giving the error of SSL Handshake if the command was send without the -n parameter and timed out with it.
Any ideas?
Thanks!
J.
jdalrymple
Skynet Drone
Post by jdalrymple »
Stop here and now with the thought that it's actually an SSL problem - it's not. This is unfortunately just the error you get when you have communication problems.
I would highly recommend upgrading to 4.1 or newer (preferably the newest). The reason is that this problem is difficult to troubleshoot mostly because it's using the old style configs and the older modules that are missing some components. It's possible that CheckDriveSize didn't exist in the version you're using. It's hard to be certain because the documentation has vanished from the Internet (mostly)
To check that, try your check_nrpe with only the -H argument and see what you get... that's a good place to start your troubleshooting.
[root@localhost libexec]# ./check_nrpe -H 192.168.x.x
I (0.4.3.131 2015-02-15) seem to be doing fine...
gpi
Post by gpi »
I tried to update the client to the newer version, but that messed up the checks that are already configured in the hosts. I'l give another chance updating it today.
Answering your recommendations, here are the results on executing the check_nrpe plainly:
Same output for the 3 affected servers. If i add the -n option ends by timeout.
Regards,
J.
jdalrymple
Skynet Drone
From this point I recommend you straight copy the nsclient.ini file from your working host(s) to the non-working host(s). Get check_nrpe -H <upgraded host> working then from there we'll work on getting your broken services plunked back in.
gpi
Post by gpi »
jdalrymple wrote:From this point I recommend you straight copy the nsclient.ini file from your working host(s) to the non-working host(s). Get check_nrpe -H <upgraded host> working then from there we'll work on getting your broken services plunked back in.
I already though about doing that, the problem is that clients are of different version (0.39 vs 0.41) and the .ini file parameters are different.
I tried to update the client version to the latest one (0.43):
and I'm getting the same error:
Here is the contents of the nsclient.ini file:
[/settings/default]
; TIMEOUT - Timeout when reading packets on incoming sockets. If the data has not arrived within this time we will bail out.
timeout = 30
[/modules]
CheckHelpers = 0
Scheduler = 0
; NRPEServer - A server that listens for incoming NRPE connection and processes incoming requests.
NRPEServer = enabled
CheckSystem = enabled
; NSClientServer - A server that listens for incoming check_nt connection and processes incoming requests.
NSClientServer = 1
; CheckExternalScripts - Execute external scripts
CheckExternalScripts = enabled
; NSCAClient - NSCA client can be used both from command line and from queries to submit passive checks via NSCA
NSCAClient = 1
; CheckEventLog - Check for errors and warnings in the event log.
CheckEventLog = 1
; CheckNSCP - Use this module to check the healt and status of NSClient++ it self
CheckNSCP = enabled
CheckDisk = enabled
; Section for NRPE (NRPEServer.dll) (check_nrpe) protocol options.
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = false
port = 5666
; ALLOW INSECURE CHIPHERS and ENCRYPTION - Only enable this if you are using legacy check_nrpe client.
insecure = false
; EXTENDED RESPONSE - Send more then 1 return packet to allow response to go beyond payload size (requires modified client if legacy is true this defaults to false).
extended response = true
; ALIAS - Query alias
alias_volumes_loose = check_drivesize
alias_volumes = check_drivesize
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
alias_event_log = check_eventlog
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
alias_disk = check_drivesize
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
alias_service = check_service
default =
alias_cpu = check_cpu
alias_mem = check_memory
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
alias_up = check_uptime
alias_disk_loose = check_drivesize
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
; SCRIPT - For more configuration options add a dedicated section (if you add a new section you can customize the user and various other advanced features)
default =
; A list of templates for wrapped scripts.
[/settings/external scripts/wrappings]
; WRAPPING - An external script wrapping
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
bat = scripts\\%SCRIPT% %ARGS%
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
; A set of filters to use in real-time mode
[/settings/eventlog/real-time/filters]
; FILTER DEFENITION - For more configuration options add a dedicated section
default =
Regards,
J.
jdalrymple
Skynet Drone
Cleaned up and modified slightly - please try:
[/settings/default]
timeout = 30
[/modules]
CheckHelpers = 0
Scheduler = 0
NSClientServer = 1
NSCAClient = 1
CheckEventLog = 1
CheckNSCP = enabled
CheckDisk = enabled
use ssl = true
port = 5666
insecure = true
default =
default =
default =
Also note all 4.0+ versions of nsclient use the same nsclient.ini config file syntax. I strongly recommend you get all your hosts to a more current version so you're not maintaining both the old style and the new style config files. 0.3.x has been deprecated by the developer for some time.
