Can Not Access Nagios Xi from network
After I install Nagios Xi on CentOS7 it can access from browser in CentOS server normal, but when i try access from network it not work. (network ping work normal). How to make it can access from network?
Reason: I have moved your post to the appropriate section of the forum.
Re: Can Not Access Nagios Xi from network
What is the error that you are getting? Is there a firewall in place that could be causing the issue? Is SELinux enabled?
getenforceBe sure to check out our Knowledgebase for helpful articles and solutions!
