Hi All,
I am installing nagios earlier, however it failed because of file system usage went 100%. it stopped, some of nagios files are already installed.
I tried running ./fullinstall again but it returns below error:
Sleeping...
NOTE: If prompted, enter the MySQL root password
NagiosQL database appears OK - continuing...
NDOUtils database appears OK - continuing...
ls: cannot access /usr/local/nagios/etc/import: No such file or directory
ERROR: No files to import - exiting. Were Nagios Core and NagiosQL installed?
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
How can I install it again? Thank you!
First try of nagios installation failed because of 100%Usage
daniel.c.marcos.jr
Re: First try of nagios installation failed because of 100%U
I guess my first question is: Did you clear up space? If so, what did you remove?
