I have a check that checks bandwidth on one of our fiber switches.
One of the ports is no longer being used (fc1/27) and was set to off on the switch. Naturally Nagios is reporting it as being down.
And I want to disable the check for that.
As it stands now, Nagios reports:
DC-N5K-S2 fc1/27 Status CRITICAL 08-20-2015 11:30:24 16d 9h 25m 0s 5/5 CRITICAL - Interface fc1/27 (index 16883712) is down Code: Select all
DC-N5K-S2 fc1/26 Bandwidth Yes Applied 2360
DC-N5K-S2 fc1/26 Status Yes Applied 2361
DC-N5K-S2 fc1/28 Bandwidth Yes Applied 2364
DC-N5K-S2 fc1/28 Status Yes Applied 2365When I go to Nagios core / system/configuration, it is:
DC-N5K-S2 fc1/27 Bandwidth 0 5 0h 5m 0s 0h 1m 0s check_xi_service_mrtgtraf!dc-n5k-s2_16883712.rrd!2,2!3,3!G xi_timeperiod_24x7 Yes No Yes Yes Yes No Auto-determined value Dave Harmon, Dave Harmon_txt Yes 0h 30m 0s 0h 0m 0s Unknown, Warning, Critical, Recovery, Flapping, Downtime xi_timeperiod_24x7 Yes None Yes Program-wide value Program-wide value Ok, Warning, Unknown, Critical Yes Status Information, Non-Status Information
DC-N5K-S2 fc1/27 Status 0 5 0h 5m 0s 0h 1m 0s check_xi_service_ifoperstatusnag!16883712!-v3 -u sanswitchmonitor.svc -A k%pLk304UZ-J -a MD5 -l authNoPriv xi_timeperiod_24x7 Yes No Yes Yes Yes No Auto-determined value Dave Harmon, Dave Harmon_txt Yes 0h 30m 0s 0h 0m 0s Unknown, Warning, Critical, Recovery, Flapping, Downtime xi_timeperiod_24x7 Yes None Yes Program-wide value Program-wide value Ok, Warning, Unknown, Critical Yes Status Information, Non-Status Information
Any ideas on how to fix?
