?? New Feature
dxf1
?? New Feature
Post by dxf1 »
HI Would it be possible to view the current data by flying over the test i.e., in a grouped view a test changes colour holding the cursor over the test will show the current value, a bit like many search engins provide
Best Regards
Dave
tonyyarusso
Re: ?? New Feature
Post by tonyyarusso »
I'm not sure I understand what you're looking for. Currently there is both a background color and a status, for instance "Up" on green. Are you asking for "Up" to also be mouseover text? Or the info from the "Status information" field? If something else, any chance you could provide a mockup of what you have in mind?
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
mmestnik
Re: ?? New Feature
Post by mmestnik »
This would be possible, but it should already be available.
What screen and what item? We could guess, but perhaps if you know the data you think should be displayed that would help too.
http://go.nagios.com/forum/320/1389
