XI Error: Command name of command line is NULL
Episodio1
Post by Episodio1 »
Hi!
I have added a few individual services and hosts with Wizard and the work OK. But when I try to use "Windows SNMP" wizard, no matter what config I use there is an error when "checking configuration".
If I check "Test Check Command" in each invididual SNMP they works OK.
Config data:
Read main config file okay...
Error: Could not register command (config file [b]'/usr/local/nagios/etc/commands.cfg', starting on line 291[/b])
Line 291 of commands.cfg starts in:
       command_name                             check_xi_by_ssh
       command_line                             $USER1$/check_by_ssh -H $HOSTADDRESS$ $ARG1$ $ARG2$
291: define command {
       command_name                             check_xi_deface
       command_line                             $USER1$/check_http -H $HOSTADDRESS$ -r '$ARG1$' -u '$ARG2$' $ARG3$
       command_name                             check_xi_domain_v2
       command_line                             $USER1$/check_domain.php -d $ARG1$ $ARG2$ $ARG3$
       command_name                             check_xi_host_http
       command_line                             $USER1$/check_http -H $HOSTADDRESS$ $ARG1$
System profile:
System:
Nagios XI Version : 2014R2.7
localhost.localdomain 2.6.32-573.3.1.el6.x86_64 x86_64
CentOS release 6.7 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.46 Safari/537.36
Server Name: 172.26.xxx.xxx
Server Address: 172.26.xxx.xxx
Server Port: 80
Date/Time
PHP Timezone: Atlantic/Canary
PHP Time: Mon, 24 Aug 2015 10:06:48 +0100
System Time: Mon, 24 Aug 2015 10:06:48 +0100
Nagios XI Data
License ends in:
Days left in Trial: 51
nagios (pid 29605) is running...
NPCD running (pid 1356).
ndo2db (pid 1435) is running...
CPU Load 15: 0.09
Total Hosts: 29
Total Services: 37
Function 'get_base_uri' returns: http://172.26.xxx.xxx/nagiosxi/
Function 'get_base_url' returns: http://172.26.xxx.xxx/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://172.26.xxx.xxx/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
* If I run: ./reconfigure_nagios.sh same error shows up.
* I removed "sudo" from /usr/local/nagiosxi/scripts/restart_nagios_with_export.sh in line: sudo $BASEDIR/manage_services.sh restart nagios
* I have installed Centos 6.7 basic Server and Nagios manual installation with no problems at all.
Episodio1
Re: XI Error: Command name of command line is NULL
Post by Episodio1 »
I have even restored a previous backup config (which was OK), but same error happens.
Let's try and reset the permissions on the files to see if that resolves it. Run this in a shell as root.
/usr/local/nagiosxi/scripts/reset_config_perms
If that doesn't fix it, run this tail command, Apply the Configuration and post the output of the tail command.
tail -f /usr/local/nagiosxi/var/cmdsubsys.log
Episodio1
Post by Episodio1 »
Before I run 'reset_config_perms' I was getting GREEN both items in "Config File Permissions Check"
After I ran script and tried again the Wizard now I've got new error when I apply Windows SNMP to host 172.26.50.3
Reading configuration data...
Error: Could not find any host matching '172.26.50.3' (config file '/usr/local/nagios/etc/services/172.26.50.3.cfg', starting on line 80)
Error: Failed to expand host list '172.26.50.3' for service 'TeamViewer 10' (/usr/local/nagios/etc/services/172.26.50.3.cfg:80)
172.26.50.3.cfg ends in line 38. There is no 80.
More from the log...
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1440407222.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1440407222.tar.gz
tar: usr/local/nagios/etc/hosts: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/hosts: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/static: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/static: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/services: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/services: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/pnp/check_commands: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/pnp/check_commands: Cannot change mode to rwxrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/pnp/pages: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/pnp/pages: Cannot change mode to rwxrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/pnp: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/pnp: Cannot change mode to rwxrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/import: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/import: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: Exiting with failure status due to previous errors
RESETTING PERMS
SETUID ROOT OK
OUTPUT=SETUID ROOT OK
RETURNCODE=1
PROCESSED 1 COMMANDS
File: 172.26.50.3.cfg:
# Service configuration file
# Created by: Nagios Core Config Manager 2.3.3
# Date:       2015-08-17 16:55:23
# Version:    Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
        host_name                       172.26.50.3
        service_description             Ping
        use                             xiwizard_windowsserver_ping_service
        max_check_attempts              5
        check_interval                  5
        retry_interval                  1
        check_period                    xi_timeperiod_24x7
        notification_interval           60
        notification_period             xi_timeperiod_24x7
        notifications_enabled           0
        _xiwizard                       windowssnmp
        register                        1
# END OF FILE
Can you run the following and post the output here?
ls -l /usr/local/nagios/etc
Episodio1
Post by Episodio1 »
I send you screenshot (easyviewing with colors) :)
Try putting that back, that could be causing the issue.
Can you upload the following file?
/etc/sudoers
Can you run the following and post the output?
chage -l nagios
grep nag /etc/passwd
grep nag /etc/group
Episodio1
Post by Episodio1 »
Most important lines from sudoers:
## Allow root to run any commands anywhere
root    ALL=(ALL)       ALL
myuser ALL=(ALL)      ALL
## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
User_Alias      NAGIOSXI=nagios
User_Alias              NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/nmap *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/nmap *
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
[root@localhost etc]# chage -l nagios
  Last password change                                    : Aug 14, 2015
  Password expires                                        : never
  Password inactive                                       : never
  Account expires                                         : never
  Minimum number of days between password change          : 0
  Maximum number of days between password change          : 99999
  Number of days of warning before password expires       : 7
[root@localhost etc]# grep nag /etc/passwd
   nagios:x:501:100::/home/nagios:/bin/bash
[root@localhost etc]# grep nag /etc/group
   nagios:x:501:nagios,apache
   nagcmd:x:502:nagios,apache
I put "sudo" again in that file and same error happens.
I restored a previous snapshot backup and same error happens.
BUT I tried to restore first bakcup in history and it worked.
I added the "Windows SNMP" with a few services and they worked.
ssax
Dreams In Code
Post by ssax »
So are you saying you're no longer experiencing the issue?
Episodio1
Post by Episodio1 »
Yes.
All is OK now.
