Changed plugins and now perf data's broken
snapon_admin
Post by snapon_admin »
I recently switched our ASA CPU monitoring plugin and ever since I did that the perf data for that check is broken. I believe I've run into this issue before but can't for the life of me remember how to fix it. Thoughts?
Re: Changed plugins and now perf data's broken
snapon_admin
Yeah that does sound like it. I'll give that a shot and see if that fixes it, thanks!
hsmith
Agent Smith
Post by hsmith »
snapon_admin wrote:Yeah that does sound like it. I'll give that a shot and see if that fixes it, thanks!
Let us know! Thanks.
Former Nagios Employee.
me.
snapon_admin
Well it did fix the perfdata on some hosts, but not the couple that I was hoping it'd fix the issue on, those still seem broken.
jolson
Attack Rabbit
Post by jolson »
Is the new plugin certainly reporting perfdata? You can check by viewing the following tab:
Twits Blog
snapon_admin
Ah, no. Guess that'd explain that. I think what confused me was that I assumed running that script would remove the graphs from that check since I figured it'd remove the old plugin's data sources, but I suppose that might not be how it works. Pretty handy script either way, though.
snapon_admin, is it safe to close this topic?
