[root@emswebserver2 ~]# cat /usr/local/nagios/etc/nsca.cfg
# Sample NSCA Daemon Config File
# Written by: Ethan Galstad (
[email protected])
# Last Modified: 11-23-2007
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# Check Result directory. If passed, skip command pipe and submit
# directly into the checkresult directory. Requires Nagios 3+
# For best results, mount dir on ramdisk.
#check_result_path=/usr/local/nagios/var/spool/checkresults
# PID FILE
# The name of the file in which the NSCA daemon should write it's process ID
# number. The file is only written if the NSCA daemon is started by the root
# user as a single- or multi-process daemon.
pid_file=/var/run/nsca.pid
# PORT NUMBER
# Port number we should wait for connections on.
# This must be a non-priveledged port (i.e. > 1024).
server_port=5667
# SERVER ADDRESS
# Address that NSCA has to bind to in case there are
# more as one interface and we do not want NSCA to bind
# (thus listen) on all interfaces.
#server_address=192.168.1.1
# NSCA USER
# This determines the effective user that the NSCA daemon should run as.
# NOTE: This option is ignored if NSCA is running under either inetd or xinetd
nsca_user=nagios
# NSCA GROUP
# This determines the effective group that the NSCA daemon should run as.
nsca_group=nagios
# NSCA CHROOT
# If specified, determines a directory into which the nsca daemon
# will perform a chroot(2) operation before dropping its privileges.
# for the security conscious this can add a layer of protection in
# the event that the nagios daemon is compromised.
# NOTE: if you specify this option, the command file will be opened
# relative to this directory.
#nsca_chroot=/var/run/nagios/rw
# DEBUGGING OPTION
# This option determines whether or not debugging
# messages are logged to the syslog facility.
# Values: 0 = debugging off, 1 = debugging on
debug=1
# COMMAND FILE
# This is the location of the Nagios command file that the daemon
# should write all service check results that it receives.
command_file=/usr/local/nagios/var/rw/nagios.cmd
# ALTERNATE DUMP FILE
# This is used to specify an alternate file the daemon should
# write service check results to in the event the command file
# does not exist. It is important to note that the command file
# is implemented as a named pipe and only exists when Nagios is
# running. You may want to modify the startup script for Nagios
# to dump the contents of this file into the command file after
# it starts Nagios. Or you may simply choose to ignore any
# check results received while Nagios was not running...
alternate_dump_file=/usr/local/nagios/var/rw/nsca.dump
# AGGREGATED WRITES OPTION
# This option determines whether or not the nsca daemon will
# aggregate writes to the external command file for client
# connections that contain multiple check results. If you
# are queueing service check results on remote hosts and
# sending them to the nsca daemon in bulk, you will probably
# want to enable bulk writes, as this will be a bit more
# efficient.
# Values: 0 = do not aggregate writes, 1 = aggregate writes
aggregate_writes=0
# APPEND TO FILE OPTION
# will open the external command file for writing or appending.
# This option should almost *always* be set to 0!
# Values: 0 = open file for writing, 1 = open file for appending
append_to_file=0
# MAX PACKET AGE OPTION
# This option is used by the nsca daemon to determine when client
# data is too old to be valid. Keeping this value as small as
# possible is recommended, as it helps prevent the possibility of
# "replay" attacks. This value needs to be at least as long as
# the time it takes your clients to send their data to the server.
# Values are in seconds. The max packet age cannot exceed 15
# minutes (900 seconds). If this variable is set to zero (0), no
# packets will be rejected based on their age.
max_packet_age=30
# DECRYPTION PASSWORD
# This is the password/passphrase that should be used to descrypt the
# incoming packets. Note that all clients must encrypt the packets
# they send using the same password!
# IMPORTANT: You don't want all the users on this system to be able
# to read the password you specify here, so make sure to set
# restrictive permissions on this config file!
#password=
# DECRYPTION METHOD
# This option determines the method by which the nsca daemon will
# decrypt the packets it receives from the clients. The decryption
# method you choose will be a balance between security and performance,
# as strong encryption methods consume more processor resources.
# You should evaluate your security needs when choosing a decryption
# method.
# Note: The decryption method you specify here must match the
# encryption method the nsca clients use (as specified in
# the send_nsca.cfg file)!!
# Values:
# 0 = None (Do NOT use this option)
# 1 = Simple XOR (No security, just obfuscation, but very fast)
# 2 = DES
# 3 = 3DES (Triple DES)
# 4 = CAST-128
# 5 = CAST-256
# 6 = xTEA
# 7 = 3WAY
# 8 = BLOWFISH
# 9 = TWOFISH
# 10 = LOKI97
# 11 = RC2
# 12 = ARCFOUR
# 14 = RIJNDAEL-128
# 15 = RIJNDAEL-192
# 16 = RIJNDAEL-256
# 19 = WAKE
# 20 = SERPENT
# 22 = ENIGMA (Unix crypt)
# 23 = GOST
# 24 = SAFER64
# 25 = SAFER128
# 26 = SAFER+
decryption_method=0
