I've problem compiling Nagios 3.3.1 on Solaris 10 x86.
The ./configure command works fine but when I try to "make", the command return the following error:
nagios@myhost:/appli/nagios/Nagios_Stuffs/nagios> make nagios
cd ./base && make
cc -Wall -g -DHAVE_CONFIG_H -DNSCORE -c broker.c
cc: -W option with unknown program all
*** Error code 1
make: Fatal error: Command failed for target `broker.o'
Current working directory /appli/nagios/Nagios_Stuffs/nagios/base
*** Error code 1
make: Fatal error: Command failed for target `nagios' I must use that compiler. Have you any clue about how to bypass that problem?
