Where to find/query current and historical alert data?
gormank
Post by gormank »
I'm looking for a way to gather info on the current and historical status of some hosts and services in my system. The goal is to send a very brief status email to users telling them that the vital systems we monitor are in good shape or if they need attention.
I'm not looking for a standard report that attaches a pdf or provides a link to fetch a pdf, or log into the system. This doesn't need to be a standard part of Nagios. I'm happy to locate the data, query it, and send the email myself via a script.
The question is where is the data?
jdalrymple
Skynet Drone
Re: Where to find/query current and historical alert data?
Post by jdalrymple »
The *convenient* place is /usr/local/nagios/var/status.dat - but that's only realtime.
The historical (and realtime) data is in a couple of spots:
1) mysql database 'nagios'
2) /usr/local/nagios/var/nagios.log and /usr/local/nagios/var/archives/
gormank
Post by gormank »
Thanks. I'll look at status.dat and in archives.
I also see that tables nagios_hoststatus and nagios_servicestatus (I guess in the nagios DB) should have most of the info I need. If I can join on hostgroup_members, I think I'll also be able to limit to my hosts.
jdalrymple
Skynet Drone
Nailing the DB would be the best way to do it, that was in fact the intended purpose of implementing NDO2db in the first place.
gormank
Post by gormank »
My preference is also via SQL.
Sorry to have asked yet another dumb question but the documentation style isn't really conducive to figuring out how to do things creatively.
I eventually found a pointer to the NDOUtils docs via google. http://assets.nagios.com/downloads/nagi ... /ndoutils/
This can be closed.
