Service Status - Nagios XI Dashboard Error
kvaldez
Post by kvaldez »
Im monitoring the activity of a webService using the check_http command.
I created a new command on configure -> Core Config Manager -> Commands using this sentence:
$USER1$/check_http -H $HOSTADDRESS$ -p $ARG1$ -k $ARG2$ -T application/xml -u $ARG3$ -P $ARG4$
After creating the command I created a new service and select the new command from the drop down list.
I added the Host, ARG's and finally the service objects as I normally would (templates, check and alert setting
s, etc).
After that when going to home theres a warning on Service Detail option, the status detail:
(No output on stdout) stderr: /bin/sh: -c: line 0: syntax error near unexpected token `newline'
/bin/sh: -c: line 0: `/usr/local/nagios/libexec/check_http -H 192.168.0.99 -p 8283 -k SOAPAction:enviarDocumento -T application/xml -u /services/ESB_LOG -P <ping>PruebaConectividad</ping>'
Re: Service Status - Nagios XI Dashboard Error
Post by Box293 »
kvaldez wrote:-P <ping>PruebaConectividad</ping>
Either enclose the -P argument in single quotes or escape the <>
-P '<ping>PruebaConectividad</ping>'
-P \<ping\>PruebaConectividad\</ping\>
kvaldez
Post by kvaldez »
Thanks for your reply.
On Services window when I replace the ARG for -P argument on test command I get this output:
For '<ping>PruebaConectividad</ping>' :
COMMAND: /usr/local/nagios/libexec/check_http -H 192.168.0.99 -p 8283 -k SOAPAction:enviarDocumento -T application/xml -u /services/ESB_LOG -P '\PruebaConectividad\'
OUTPUT: CRITICAL - Socket timeout after 10 seconds
For \<ping\>PruebaConectividad\</ping\> :
COMMAND: /usr/local/nagios/libexec/check_http -H 192.168.0.99 -p 8283 -k SOAPAction:enviarDocumento -T application/xml -u /services/ESB_LOG -P \\\PruebaConectividad\\\
Finally for both on Home -> Service Detail, I keep getting the same error
-kvaldez
I think the left single quote was in the wrong place, try running this and see if this resolves it for you.
/usr/local/nagios/libexec/check_http -H 192.168.0.99 -p 8283 -k SOAPAction:enviarDocumento -T application/xml -u /services/ESB_LOG -P '<ping>PruebaConectividad</ping>'
kvaldez
Post by kvaldez »
Keep getting the same error :?
-kvaldez
ssax
Dreams In Code
Post by ssax »
Are you running this command directly from the command line? (not through XI)
Can you access that page/port? Does it require authentication?
kvaldez
Post by kvaldez »
From commad line there's no issue.
But when running from XI there comes the error
-kvaldez
jdalrymple
Skynet Drone
Post by jdalrymple »
The core interface has a handy tool for expanding the command that Nagios is trying to run. Can you grab a screenshot of that for us:
http://yournagiosserver/nagios
Configuration (lower left corner)
Services --> Continue
Locate the appropriate service and click on the highlighted text in the "Check Command" column, there is a search field in the upper right that may be helpful
Send a screenshot of the resulting page.
kvaldez
Post by kvaldez »
I upload the capture screens you want to the post.
Hope this can help.
-kvaldez
That screenshot is from the XI interface, we need you to follow the instructions posted for the Core interface. The XI Test Check Command button is not always an accurate representation and may differ from what is actually run. Please follow @jdalrymple's instructions from his last post.
