Log server 2.2 and SSL
CFT6Server
Just spinning up some newer 2.2 Log Servers and noticed that it doesn't have the SSL.conf files in /etc/httpd/conf.d anymore. When I add that back in, the httpd service complains about the ssl module. I see that mod_ssl and openssl is installed. Am I missing something here? I am trying to security the nodes and force SSL. Thanks.
Re: Log server 2.2 and SSL
All that I had to do to get https working is as follows.
Modify nagioslogserver.conf:
UNCOMMENT SSLRequireSSL
Install openssl requirements:
Restart httpd:
Access NLS GUI:
This worked like a charm for me on version R2.2. Let me know if you're having any troubles. Thanks!
vi /etc/httpd/conf.d/nagioslogserver.confInstall openssl requirements:
yum install openssl openssl-devel mod_sslCode: Select all
service httpd restartCode: Select all
https://192.168.x.x/nagioslogserver-
CFT6Server
Since this changed, what is the recommended method for permanent SSL redirect?
I can't imagine this was intentional if they were there before. Might have just been a missed step when we built the install script. I'll confirm with the devs.
Was this a fullinstall from source or a pre-built VM?
Sorry about the earlier information, I actually got this working by using the following procedure:
Change to:
Replace 192.168.x.x with the IP if your nagios instance.
After running through the above, everything is working as expected. Are your results different than mine? It looks like ssl.conf was generated when I ran yum install mod_ssl, so you may need to reinstall it.
This was from an OVF template, which does not include the mod_ssl package by default - hence why ssl.conf was not available initially.
vi /etc/httpd/conf.d/nagioslogserver.confCode: Select all
<VirtualHost *:80> # Add this line
<Directory "/var/www/html/nagioslogserver/www/">
Options None
AllowOverride None
Order allow,deny
Allow from all
Redirect permanent / https://192.168.x.x/
</Directory>
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /etc/pki/tls/certs/ca.crt
SSLCertificateKeyFile /etc/pki/tls/private/ca.key
<Directory "/usr/local/nagiosxi/html">
AllowOverride All
</Directory>
</VirtualHost>
Alias /nagioslogserver "/var/www/html/nagioslogserver/www/"Code: Select all
yum install mod_ssl
openssl genrsa -out ca.key 2048
openssl req -new -key ca.key -out ca.csr
openssl x509 -req -days 365 -in ca.csr -signkey ca.key -out ca.crt
cp ca.crt /etc/pki/tls/certs
cp ca.key /etc/pki/tls/private/ca.key
cp ca.csr /etc/pki/tls/private/ca.csr
yum remove mod_ssl
yum install mod_ssl-
CFT6Server
This worked. Thanks for the instructions.
No problem - I'll close the thread and mark it as resolved. Thanks!
