TwitsBlog Show me a man who lives alone and has a perpetually clean kitchen, and 8 times out of 9 I'll show you a man with detestable spiritual qualities.
The 'nagios' user will need appropriate permissions to tunnel through the above directories to the log files in question. I got this working on my test box, so I'm not sure what the problem could be here. Is the configuration certainly in place on the server?
I get what you are referring to, but I have a specific purpose for this. I just have some log files I need to input into LS. so putting in in nagios:nagios is fine as this is a copy of the logs and eliminate any permission issues. Since I am grabbing all the logs, I just wanted to use *.
Now it should be able to import the files if it is new, and once imported, it will know the previous location where the logs are last read and will not try to reimport them into LS. At least that's how I think it works?
service logstash restart
tail /var/log/logstash/logstash.log
