Unable to write max checks to host config
peter.zanetti
Post by peter.zanetti »
Unrelated to my post about a delete script and on a different instance of Nagios in our environment. This Nagios Server is a fresh install. Today I tried to add a single device through Core for testing purposes. After I added it and tried to apply the configuration I got an error.
The Max Check attempts for this device is defined as 4.
Any Idea what is causing this error?
Re: Unable to write max checks to host config
Just to get the obvious out of the way, are there any spaces in that field (not 100% sure if this would matter) and are you certain you are looking at the correct host?
Also to clarify, when you say "I tried to add a single device through Core" you are talking about the Core Configuration Manager, right?
peter.zanetti
There are no spaces in the field.
It is the only device on the server so I am sure it is the correct one.
Yes I mean Core Configuration Manager.
jdalrymple
Skynet Drone
Post by jdalrymple »
That is a common error, but usually related to having no max_check_attempts defined at all.
Can you find the host in CCM and click the little disk icon and show us the output there?
peter.zanetti
Here is what that file looks like.
# Host configuration file
# Created by: Nagios Core Config Manager 2.3.3
# Date:	      2015-09-02 16:01:34
# Version:    Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
	host_name			cvt3247532
	alias				price checker
	address				cvt3247532
	initial_state			u
	max_check_attempts		4
	check_interval			15
	retry_interval			1
	check_period			24x7
	register			1
# END OF FILE
jdalrymple
Skynet Drone
Everything looks fine - obviously.
Can you save that entire config and PM it to me? I'd like to load it into a lab machine and see if I get the same results.
Check to see if your php and system time is in sync.
Admin->System Profile
Do you get config errors if you run the "reconfigure_nagios.sh" from the CLI?
./reconfigure_nagios.sh
peter.zanetti
jdalrymple wrote:Everything looks fine - obviously.
What Directory can I copy the file from?
peter.zanetti
lmiltchev wrote:Check to see if your php and system time is in sync.
Yes the system time and php time are the same.
Date/Time
PHP Timezone: America/New_York
PHP Time: Thu, 03 Sep 2015 08:14:24 -0400
System Time: Thu, 03 Sep 2015 08:14:24 -0400
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.loginnagiosql.login: Permission denied
LOGIN SUCCESSFUL!
NAGIOSQL LOGIN FAILED!
Im not sure if the error is database permissions or because I don't have root access in the command line.
jdalrymple
Skynet Drone
Has somebody been fiddling with your mysql databse?
Try this from the command line and share the results:
mysql -u nagiosxi -pn@gweb nagiosql
