2 hosts with almost identical names share servicechecks
rhassing
Post by rhassing »
I have defined two hosts:
define host {
        host_name                       A-ALMEX02
        alias                           Exchange 2010 HUB/CAS ADS
        display_name                    A-ALMEX02
        address                         172.20.0.65
        check_command                   check-host-alive
        initial_state                   o
        max_check_attempts              3
        check_interval                  5
        retry_interval                  1
        active_checks_enabled           1
        passive_checks_enabled          0
        check_freshness                 1
        event_handler                   host-notify-by-email
        process_perf_data               1
        contact_groups                  Standby_pool2
        notification_interval           15
        notification_options            d,u,r
        notifications_enabled           1
        register                        1
define host {
        host_name                       ALMEX02
        display_name                    ALMEX02
        address                         172.20.4.151
        initial_state                   o
        check_interval                  5
        retry_interval                  1
        check_freshness                 1
        process_perf_data               1
        register                        1
One service check:
        #NAGIOSQL_CONFIG_NAME           Disk_usage_D
        host_name                       ALMEX02
        service_description             Disk usage D: - 24x7 Pool 2
        display_name                    Disk usage D: - 24x7 Pool 2
        check_command                   check_snmp_storage!public!^D!90!95
        initial_state                   o
        check_interval                  5
        retry_interval                  1
        check_freshness                 1
        event_handler_enabled           0
        process_perf_data               1
        notification_interval           5
        notification_options            w,u,c,r,f
        contact_groups                  Mail_Standby_Pool_2
        notes_url                       /nagiosgraph/cgi-bin/show.cgi?host=$HOSTNAME$&service=$SERVICEDESC$&db=diskgd%2Cbytesfree&db=diskgd%2Cbytesmax&period=day,week,month,year&expand_period=day,week,month,year
        register                        1
But still I have the servicecheck on both hosts:
How can this be avoided?
Rob Hassing
rhassing
Re: 2 hosts with almost identical names share servicechecks
Post by rhassing »
And this is why we don't want it on one host :D
Rob Hassing
jdalrymple
Skynet Drone
Post by jdalrymple »
I copied and pasted your config into a 4.0.8 (XI 2.7) box and couldn't reproduce the behavior.
I suspect you have some hostgroup foul play going on
rhassing
Post by rhassing »
I'm using Nagios 4.1.1 in this configuration. I will try to reproduce this as well in a smaller setup.
There are hostgroups defined, but not used for this service.
Both hosts have multiple services defined and also overlapping servicechecks, but this check should exist on just the one host.
Rob Hassing
jolson
Attack Rabbit
Post by jolson »
I tested this on a 4.1.1 box as well:
2015-09-03 10_23_17-Nagios Core - Firefox Developer Edition.png (4.66 KiB) Viewed 3022 times
Twits Blog
rhassing
Post by rhassing »
We found the problem. It seems to be possible to use regular expressions in nagios.cfg. If we turn them off, our problem is solved:
# REGULAR EXPRESSION MATCHING
# takes place in the object config files.  Regular expression
use_regexp_matching=0
# "TRUE" REGULAR EXPRESSION MATCHING
# This option controls whether or not "true" regular expression
# matching takes place in the object config files.  This option
# only has an effect if regular expression matching is enabled
# (see above).  If this option is DISABLED, regular expression
# matching only occurs if a string contains wildcard characters
# (* and ?).  If the option is ENABLED, regexp matching occurs
# all the time (which can be annoying).
# Values: 1 = enable true matching, 0 = disable true matching
use_true_regexp_matching=0
Rob Hassing
hsmith
Agent Smith
Post by hsmith »
rhassing wrote:We found the problem. It seems to be possible to use regular expressions in nagios.cfg. If we turn them off, our problem is solved:
Is there anything else we can do to help you out with this issue?
Former Nagios Employee.
me.
rhassing
Post by rhassing »
No, this is solved, thread may be closed :-)
Rob Hassing
