Error: Could not stat() command file '/usr/local/nagios/var/
rbuckle
Post by rbuckle »
I have a new install of Nagios Core 4.1.1 on CentOS 6.7
Any time i try to tell nagios to do something like re-check a device now or stop monitoring i get this:
i have confirmed that Nagios is indeed running and have checked the permissions on the file and folder:
drwxrwsr-x. 2 nagios nagcmd 4096 Sep 2 16:48 rw
and:
[root@RBCentos rw]# ll
total 0
prw-rw----. 1 nagios nagcmd 0 Sep 2 16:48 nagios.cmd
srw-rw----. 1 nagios nagcmd 0 Sep 2 16:48 nagios.qh
but i still get the same error, any thoughts?
Running:
Installed Version: 5.8.3
OS: CentOS 7
Nagios XI
Enterprise License
jolson
Attack Rabbit
Re: Error: Could not stat() command file '/usr/local/nagios/
Post by jolson »
My first thought is that SELinux is messing with things. Any chance it's running?
sestatus
If you log in as the nagios user, are you capable of opening the file in question?
su - nagios
cat /usr/local/nagios/var/rw/nagios.cmd
Just to make certain it's not a simple disk space problem, let's check on your disk space:
df -h
df -i
Twits Blog
