Is there any document to upgrade nagios core 4.0.8 to nagios core 4.1.1. I did installation of Nagios core 4.0.8 by compiling through source code. I have pnp4nagios ndoutils configured with my Nagios. There are some resources defined in resource.cfg. Please advice how should I upgrade my Nagios without loosing my configurations.
It will be great help. Thanks a lot.
Nagios upgrade to 4.1.1
Re: Nagios upgrade to 4.1.1
This article by @Box293 is very good.yunushaikh wrote:Is there any document to upgrade nagios core 4.0.8 to nagios core 4.1.1. I did installation of Nagios core 4.0.8 by compiling through source code. I have pnp4nagios ndoutils configured with my Nagios. There are some resources defined in resource.cfg. Please advice how should I upgrade my Nagios without loosing my configurations.
Former Nagios Employee.
me.
me.
yunushaikh
Ok sir,
Thanks I will try this and let you know if it works for me.
It's worked for me in the pastyunushaikh wrote:Ok sir,
Let us know if you need any help!
me.
me.
yunushaikh
This worked for me.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
