Remote Monitoring - Windows Servers
superhik
Post by superhik »
I'm fairly familiar with basic Nagios setup and have used it in my previous company to monitor LAN/servers. Configuring Hosts, templates etc.
I have now changed company and would like to implement Nagios to monitor multiple sites which have windows servers and are behind firewall.
Setup would be [Nagios server (public IP)<>Internet<>Firewalls<>Windows Servers]
Is there any simple guides on using Hosted Nagios (public IP) to communicate with NSclient, I just need to guidance on what needs to be done on Server Side and client sides.
Thanks in advance
Re: Remote Monitoring - Windows Servers
Post by Box293 »
If your firewalls at each end support site to site tunnels you could easily monitor all the servers using NSClient++ as the tunnels would handle all the routing. Might get complicated if you're monitoring more than one customer.
Without any tunnels, you could use one NSClient++ machine and proxy the checks for all the other NRPE machines, I did a write up about it here:
http://sites.box293.com/nagios/guides/n ... le-hopping.
Or you could use Mod-Gearman and have worker(s) at each site executing the checks, would only need the Mod_Gearman ports open. Here's some Mod-Gearman info:
http://sites.box293.com/nagios/guides/m ... man/queues
You could use passive checks like NSCA via NSClient++ which means the clients will be sending the results in, you then only need to open the inbound port for NSCA traffic. Here's a guide:
http://sites.box293.com/nagios/guides/nsca
You need to work out what you want to monitor and what your restrictions are, this will help with your decision making.
superhik
Post by superhik »
Thanks, amazing guides! I will try passive checks NSCA route, basically for now just need to monitor that servers are live nothing complex for time being.
This info is exactly what I needed.
Post by Box293 »
Great stuff :) If you have specific issues for anything create a new post for them and we'll help you out.
