Netapp FAS 2552 monitoring with Nagios XI
shailu2014
Post by shailu2014 »
Hi All,
Please can some one help me how I can configure the Netapp FAS- 2552 for Monitoring with Nagios XI,
Thanks & Appreciation in Advance...
Re: Netapp FAS 2552 monitoring with Nagios XI
Post by Box293 »
Check out these plugins:
https://exchange.nagios.org/index.php?o ... tapp%20fas
Once you get it working then you will need to create a command and service in CCM. Follow the steps in this guide which explains how to do this:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
shailu2014
I got the help from your reply, Thanks for your help...
Shailu
Post by dwhitfield »
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
