Archiving Data
CFT6Server
Archiving Data
Post by CFT6Server »
I need to make sure I keep a couple days of indices to archive. I have the repository configured. What files do I need to grab to ensure that I get everything I need to pull from archive if needed? To be clear, I need to copy from repository to another archive for long term retention.
In the backup repository there is an index file and then metadata-logstash-<date> files and then indices directory of each daily index.
(Also from looking at the repository, looks like the older folders aren't removed. The indices and data is gone but the folders aren't ie. /indices/logstash-2015.05.09 etc.)
jolson
Attack Rabbit
Re: Archiving Data
Post by jolson »
Copy all of the data stored in your backup directory to your archive. This will be your initial archive. For each archive that you need to do beyond the first archive, copy the 'index' file, located at /some/repository/index, as well as the appropriate metadata files and indices files.
Example for initial backup:
Change directory to your current backup:
cd /mnt/nlsback
Copy all files recursively, retaining permissions:
cp -Rp * /mnt/archive
Example for additional backups:
cd /mnt/nlsback
Copy select files, retaining permissions:
cp -R snapshot-logstash-2015.09.07 index indices/logstash-2015.09.07/ /mnt/archive/
You could certainly setup a cron job to achieve this on a schedule. Keep in mind that the 'index' file *does* change sometimes, so it's necessary to copy it over and overwrite the old index file.
Twits Blog
CFT6Server
Re: Archiving Data
I have about 35 backups in the repository, but I only require the middle 3 or 4 daily indices. Do I still need the original copy in the archive?
jolson
Attack Rabbit
Re: Archiving Data
Post by jolson »
No you don't - the only files you need are the up-to-date 'index' file, the metadata-logstash-xxx.xx.xx file, and the indices/logstash-xxxx.xx.xx directory (including all of the files inside of that directory of course).
Twits Blog
CFT6Server
Re: Archiving Data
Thanks. I will give this a try. I'll spin up a test instance and test the restore.
jolson
Attack Rabbit
Re: Archiving Data
Post by jolson »
Let me know how it goes. Thanks!
Twits Blog
